Read Error or Card Error? Any PERMANENT fix?
Started Jan 23, 2018 | Discussions
GarySFBCN
GarySFBCN Forum Member • Posts: 72
Re: Read Error or Card Error? Any PERMANENT fix?
robert1955 wrote:
GarySFBCN wrote:
There is one more possibility, and even though it seems remote, it could have some bearing:
I occasionally used the Fujifilm mobile app to access photos. And a few times, the app would not close properly. I wonder if there is an internal SD Card Reader status setting set by the app and not being reset to 'not in use' or whatever when one exits the app using the exit function? I've had to stop the app via the app functions in the Android system because it would not exit and as it happened twice, I decided not to use the app again.
Interesting thought, but I think unlikely the app locks the card. Did you encounter card errors directly after using the app?
No errors after using the app.
 GarySFBCN's gear list:GarySFBCN's gear list
Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Samsung Galaxy S9+
robert1955 Veteran Member • Posts: 7,299
FWIW [and I realize that not having problems does not mean no problems exist] here is my workflow for W7 with currently a USB3 card reader; some of my cards are the same as the OP's. Several cameras, including currently Fuji.
I use a software utility called Downloader Pro which is highly customizable, including the degree to which you want to automate. It works by copying, in my case to two HD's with folders for each date being created on the fly.
The files get a name consisting of a prefix depending on the camera used, folllowed by the original sequence number. For this, it makes no difference whether the file on the card has a sRGB profile/name or an aRGB one, or custom, these are ignored.
After the copying, I have two options.
For important shoots. I'll leave all photos on the card [which is stored for the moment]. I let Windows do a soft eject. At a later date, I'll delete all folders and what is in them through Explorer [basically your classic del *.* command]
For day to day shots, I let Downloader Pro delete after copying and after that do a soft eject. Everything means the DCIM folder and the folder under that (FUJI103 and so on, which contain the images) are deleted. The camera creates those folders anew when you insert the card, that takes no time.
I realize many will think this workflow heterodox to say the least. But it works.
nikkor35f2 Contributing Member • Posts: 779
Aiyo , just change e file name n the problem is solved.
OK.  Enough said. Off to take more photos; )
surge
 nikkor35f2's gear list:nikkor35f2's gear list
Fujifilm X-T1 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR +4 more
maltmoose Veteran Member • Posts: 3,050
Not read the whole thread but just wanted to add that i use Sandisk Extreme Pro 32GB in my xt20 and never had a problem ever. I use the same cards in all cameras and no problems ever either.
I always transfer the files and then format in camera. never had card failures.
eric333 Senior Member • Posts: 1,434
surge
“E file name”?  You’ve used that before.  Can you elaborate?
harpo95993 Regular Member • Posts: 123
He thinks he's texting.  The E means the.  Hard to read this guys posts most the time.
 harpo95993's gear list:harpo95993's gear list
Nikon D7100 Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +27 more
Oh.  Wouldn’t have guessed that.  He uses “e” and “the” in the same sentence so I assumed “e” meant...something else.  E File is how I do my taxes.
As I said, no problems. Not with IMG or _MG not 11- or whatever. I'm quite sure that has no influence
Geoff Chesh
Geoff Chesh Forum Member • Posts: 56
Thanks - I was getting confused !
 Geoff Chesh's gear list:Geoff Chesh's gear list
Fujifilm X-T2 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm XF 16mm F1.4 R WR +6 more
Shane Ellerton New Member • Posts: 12
I’m getting the same Propblem with a 64 gigabyte San disc ultra
it keeps saying card error
120 MB/s  tried moving the record
stop facility everything taking in and out everything
what do people is wrong
I agree
