50mm 1.8 STM AF Noise... Really?!
Started Jan 22, 2018 | Discussions
XeroJay Senior Member • Posts: 2,341
I just picked up a 50mm 1.8 STM for my EOS M6, since I just gave away my trusty old 50mm 1.4 to one of my assistants. I was thinking that the 1.8 STM AF would be a better fit for the M6, since canon claims the STM motor is smooth and silent...
Have a look at the video here, and please let me know if this is "smooth & silent" : 50mm 1.8 STM AF Noise
Is this normal for this lens?! I have the 22mm EF-M, and it literally is smooth and silent, but the 50mm seems anything but. It also feels extremely slow.
 XeroJay's gear list:XeroJay's gear list
Canon EOS M6 Sony a9 Sony a7 III Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM +7 more
Canon EF 50mm F1.8 STM Canon EOS M6
mkphoto79 Regular Member • Posts: 450
Re: 50mm 1.8 STM AF Noise... Really?!
Maybe I have bad lenses too but my EFS 24f/2.8 STM and my EF 50 f/1.8 STM are both noticably louder to focus than my EFS 10-22 which uses a USM motor.   I know the STM  lenses focus smoother and don't have the fast start/stop of a USM  motor but I don't believe the silent part at all.
-Mike
 mkphoto79's gear list:mkphoto79's gear list
Canon PowerShot A590 IS Canon EOS 1200D Canon EF 300mm f/4.0L IS USM Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +5 more
juanmaasecas Senior Member • Posts: 1,501
I use this lens as well in my A7RII and the focus is slow and sometimes not accurate, mostly if you're not using the central point. And outside the center is less sharp than my manual Canon FD 50 1.4 until f4 or so. You should have better kept the AF 50 1.4 I guess...
The 85 1.8 with the USM focusing system is awesome though.
 juanmaasecas's gear list:juanmaasecas's gear list
Canon EOS M50 Canon EOS R5 Canon EF 50mm f/1.2L USM Canon EF-M 22mm f/2 STM Sigma 35mm F1.4 DG HSM Art +4 more
OP XeroJay Senior Member • Posts: 2,341
It's certainly accurate enough, but it is definitely slow, hesitant, and man... That motor noise... Wow.
FooHead Contributing Member • Posts: 546
Yep, mine sounds like that too...kinda dissapointing...and slow focusing..but quieter than the old version ii...but not as fast to focus.
My 18-135 stm and 10-18 stm are both silent.
 FooHead's gear list:FooHead's gear list
Canon EOS 1100D Canon EOS 80D Canon EF 35mm F2.0 Canon EF 100mm f/2.8 Macro USM Canon EF-S 18-135mm F3.5-5.6 IS STM +2 more
jizzy32
jizzy32 Regular Member • Posts: 112
I just tested mine, and mine is not that loud at all.  Maybe you got a bad copy?  Did you buy it new or used?  I'm assuming new since they are dirt cheap anyways.  If so try returning it and getting another copy.  If it happens again, either you have bad luck or your camera is recording the noise louder than it's supposed to be.
 jizzy32's gear list:jizzy32's gear list
Canon EOS M5 Canon EOS M6 GoPro Hero5 Black Canon EF-S 17-55mm f/2.8 IS USM Canon EF-M 22mm f/2 STM +5 more
jizzy32
sorry previous post was directed to OP, my bad
Thomas Richter Regular Member • Posts: 137
Yea, mine is that noisy too. I guess Canon engineers got a requirement from marketing to only improve things gradually over the 50mm/1.8II. That also goes for the optical performance...
Steve Balcombe Forum Pro • Posts: 15,582
I don't have any personal experience of it so I can't comment on whether it's normal for that lens. However there are two types of STM mechanism, "lead screw STM" which is used in the STM zoom lenses, and gear-type STM which is used in the shorter lenses where lead screw STM wouldn't fit. See https://www.canon.co.uk/lenses/tech-guide/focusing/ - doesn't give a lot of information, just the basics, but the animations (Flash required) illustrate the mechanisms quite nicely.
I think you're right; it's less noisy than the 50 1.8 II, so that's likely the bar they're referencing.
This was helpful, as it specifically mentions the 50 1.8 STM. Looks like it's just the way this lens is.
Tazz93
Tazz93 Veteran Member • Posts: 3,484
It's a $100 lens
It is no doubt not a quiet lens. It also isn't terribly fast in the light you would use a 1.8 lens in. The accuracy isn't terribly great in low light either. I'd have to test it to confirm, but I remember this lens being quite adequate in good light (focus-wise). But ultimately, I keep reverting back to the fact... it's a $100'ish lens that optically punches well above its weight. Honestly, I'd argue even with its problems, it punches well above its weight.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
quiquae Senior Member • Posts: 2,265
It's slow, yes, but I would not call it hesitant. The old one was acceptably fast [i]if[/i] it nailed the focus exactly on the first try; if it overshot, which it did in many cases, it would start to grind and whine on and on and on for what seemed like an eternity, causing you to reach for the focus ring, only to curse when you remember that the lens wouldn't allow full-time AF.
At least the STM never does that.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
