Robin Wong G9 Review - Thoughts?
Started Jan 22, 2018 | Discussions
slartz
slartz Senior Member • Posts: 2,103
I've read through it... it has some interesting bits and pieces in it
(you can read the full review here - https://blog.mingthein.com/2018/01/22/review-the-2018-panasonic-lumix-g9/)
There are a few weird parts to this review, and I'd like to hear people with G9 where they stand on this:
  • "There were moments when the AF failed to lock focus, and then the EVF/LCD screen went completely black for a couple seconds, before returning to normal. I’m not sure what caused this temporary black-out, but I have not observed this with any other camera, not even with the other Panaosnic cameras I have used (LX100, GH4 and GM1). The EVF black-out happened only when the camera struggled to acquire focus repeatedly." - Did anybody experience that?
    Also - he claims AF is great (and faster even on an Oly lens than on the EM1.2) but then says it has all those limitations. I'm trying to understand if it's just nitpicking or if there are real issues here worse than in other cameras?
  • "The continuous AF is one of the best I have seen on a Micro Four Thirds camera" - This is also interesting in his conclusion. He does not say it out right, but he essentially claims the new DFD C-AF is better than the PDAF on the EM1.2...
  • "There is no easy way of saying this, but I dislike the color profile of the G9. The default JPEG color and the white balance engine don’t work for me. I find the reds unnatural with strong hints of magenta and the green channel is off as well. Skin tones don’t look close to real life and the overall balance is not pleasing. Perhaps the problem is not with the camera, but my own preference." - This is also very weird as ALL other reviews claims this camera has finally great JPGs. Any ideas?
  • "The default JPEG engine does a poor job at managing the high ISO noise and details balance. There are noticeable traces of over-sharpening and artificial blurring of details at ISO3200 and higher. I also observed random, stray color fringes in shadow areas that look ugly. I tried various noise reduction settings in camera and they all produced undesirable results. In summary, at high ISO, shoot RAW."
    This is also not inline with a lot of other reviews. In fact I read claims by other reviewers they were unable to replicate the excellent noise reduction of Panasonic with LR.
Happy to hear thoughts of G9 owners here...
 slartz's gear list:slartz's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 8-18mm F2.8-4 +10 more
Brian Wadie
Brian Wadie Forum Pro • Posts: 11,017
Re: Robin Wong G9 Review - Thoughts?
15
""The continuous AF is one of the best I have seen on a Micro Four Thirds camera" - This is also interesting in his conclusion. He does not say it out right, but he essentially claims the new DFD C-AF is better than the PDAF on the EM1.2..."
"One of the Best"
Not
"The Best"
So he just as easily be saying it now matches or comes close to the EM-! mk2 PDAF system?
Please note - I am in the process of ordering a G9 so have no axe to grind, just pointing out what he said vs your interpretation
So much to learn, so little time left to do it!
 Brian Wadie's gear list:Brian Wadie's gear list
Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-45mm F4 Pro +1 more
brentbrent Veteran Member • Posts: 5,766
I had a couple of instances of focus racking-- I'm pretty sure I was trying to get AF on something on my desk closer than the minimum focus distance of the lenses -- where the AF was going back and forth without locking focus, and the EVF never went black.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
slartz
OP slartz Senior Member • Posts: 2,103
"One of the Best"
Not
"The Best"
yeah... u are right.... reading too fast and missing stuff. I take it back
so we still don't have a direct test comparison of CAF between EM1.2 and G9.... although I think from everything we are seeing - even if the EM1.2 is better, it is probably very marginally so...
If, on the other hand SAF is much better in low light, it kinda balances it out unless you shoot mainly BIF.
drj3 Forum Pro • Posts: 12,632
He also says he rarely photographs fast action and doesn't use continuous autofocus in his usual photography and suggest you look at other reviews for flying birds....
A dog swimming in a pool is not a difficult target and I suspect his few misses were more user error than the camera focus problems.  My 8 year old E5 would have no problem with this target.
Imaging Resource also mentions this..., but since it is jpeg, one can always change the defaults so I do not see why either would be a serious problem.
"Again, I'm basing all this just on in-camera JPEGs (at camera default picture style settings), but it can look a bit unnatural at close-inspection with a kind of artificial-looking smoothing of detail. JPEG sharpening also felt a bit too strong for my taste, depending on the subject. "
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
slartz wrote:
"One of the Best"
Not
"The Best"
If one uses SAF the majority of the time and often photographs things in very low illumination, then SAF performance would be far more important than CAF performance.
For those of us who find SAF rarely offers any advantage over CAF and almost never use it for stationary or moving targets, CAF performance it far more critical.
drj3
slartz
This is a kinda "obvious" statement. But the reality is that MOST people use a combination. I use CAF when I shoot kids running around, wild life or BIF. I use SAF for pretty much everything else. How much is that in percentages? Depending on time... I'd say usually 80/20 for SAF, but in 2015-2016 I did two trips to Africa where CAF was obviously a huge part of the deal (and my older EM1.1 delivered, albeit barely in that perspective...).
I think most people focus on CAF because SAF is much easier and generally very good in most cameras today. My EM1.2 has terrific SAF, and is only getting a little slower in really dim situations. Would I be happier for even better SAF? sure... but it's a "nice to have feature". Whereas in therms of CAF, my EM1.2 is the first m43 that makes it to a performance that does not make me cringe for my old Canon 7D. So.... being better here would be awesome. Being good here as the EM1.2 would be very good. Being just a tad worse - maybe agreeable. More than that - deal breaker for me.
I DO think, that a lot of people (and to some degree me included) put a LOT into the CAF performance (again, because it's a touchy subject in m43). The point I tried to make earlier, that while CAF is important, unless you are MOSTLY looking for an action camera, it should be treated as one more thing to consider, esp if it's "good enough" for most tasks. The feeling I'm getting from all the reviewers here, is that it's definitely "good enough". Which means it's not becoming a deal breaker, which means I can look at all the rest...
wolfychi Senior Member • Posts: 1,158
The EVF pincushion is quite severe, also the smear of the display towards the corners looks terrible, I wonder if that is common as I read some other poster report the same on this forum.
But the Dual IS seems to be really good!
I do think either the E-M1.2 or G9 will perform very well for most users and I haven't yet decided if I will get the G9.  I will wait to see more reports on its CAF performance.  However, I really don't know why I would want a far more expensive camera aimed at sports/wildlife photography instead of one of the other excellent mFTs cameras other than the for better CAF performance.
drj3
slartz
Well - two reasons....
  1. There are far more capabilities in the G9 (or EM1.2) than just the "wildlife/sports" angle. Before even going to "features", just the new, better, 20MP sensor with better DR and the better IBIS. Also - bigger EVF, better mechanical shutter (1/8000), less rolling shutter when shooting electronic shutter, better video AF, and then of course Ergonomics, button customisation, AF Joystick (for G9), Top LCD Screen (G9 again), and probably a hundred items more I forget...  I own both a GX85 and an EM1.2. Naturally I will always pick my EM1.2 if I go shooting something CAF. But I will also pick my EM1.2 for anything where I do "serious" photography like landscapes (and not because of the 20MP sensor. I took the EM1.1 too over it). Simply because I like shooting it much better than a smaller body like the GX85.
  2. The other kinda obvious reason is that you are not looking "just" for CAF, but you are looking for an ALL AROUND camera. If I go to Africa, I shoot wildlife but also landscapes. Also street. Also people. Also architecture and urban. I want a camera as versatile as possible. The G9 (and the EM1.2) is this. And I'm willing to pay the price for that.
drj3
BostonBoy
BostonBoy Senior Member • Posts: 2,493
I do have a G9 for tests in my arsenal since Friday afternoon. I plan to use it mainly with my PL100-400. I can NOT confirm Robin's EVF blackouts, but I DO confirm that in low light, especially with this lens, AF gets tricky. I run some tests in my home environment with not entirely consistent but similar enough conditions, and the G9 fails to lock focus once you get below a certain light threshold - this is no Nikon D500. I have run these tests with literally dozens of cameras and the G9 is no slouch in AF speed in good light, but breaks down fairly quickly in low light. Granted, I have only tested PinPoint AF so far, so this is therefore non-conclusive. I can also confirm that I changed the JPEG profile from "standard" to "neutral" since I like the color rendering better (early Sat morning shot attached).
That being said - I like the camera much better than I thought I would, and I seriously consider to keep it. It's a photographers camera (unlike my Sony A7RII). I like (and still keep) the Panasonic GM1/GM5 models (just for sheer size and fun of it) but have been mostly in the Olympus m4/3rd camp for travel and m4/3rd 'reach'. The G9 is a positive surprise for me. Very positive actually.
The EVF pin cushion distortion for me as an eye-glass wearer is pretty severe - that being said it's still better of an EVF as for instance my Leica Q. Pretty amazing actually.
C-AF Test and BIF etc. still outstanding - the weather was not cooperative here over the weekend, and I did not want to test the weather sealing on a camera I don't own - yet.
G9 and early morning light - initial tests w/ PL 100-400 - original size OOC JPEG
 BostonBoy's gear list:BostonBoy's gear list
Canon PowerShot G1
Brian Wadie
"it kinda balances it out unless you shoot mainly BIF."
That's me, except when I'm shooting action, water-sports, aircraft or macro
Wu Jiaqiu
Wu Jiaqiu Forum Pro • Posts: 29,319
6
it should have been GOLD!
 Wu Jiaqiu's gear list:Wu Jiaqiu's gear list
Fujifilm FinePix X100 Nikon D2Xs Nikon 1 V1 Nikon 1 J3 Nikon AF-S Nikkor 300mm f/4D ED-IF +3 more
jrsforums Senior Member • Posts: 1,859
5
Either some people notice it more than others or trying to photograph it close up distorts it.
i do not notice it at all.  Viewfinder is beautiful.
 jrsforums's gear list:jrsforums's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GH6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +17 more
5
I'm with you - I have to look for pincushion to see a tiny bit on the edges of the screen, but I haven't seen it in vertical lines in the subject.  As far as "smearing" in corners, the EVF is so big that I wonder if people who observe that are not using their macular vision to evaluate the corners, and it's more a function of their eyesight than anything else.  I think it's an amazingly beautiful EVF.
Brent
CharlesB58 Veteran Member • Posts: 9,829
"All those limitations..." He mentioned just one situation where there was a problem, one that would challenge many cameras.
No, it's not weird. He said plainly it's his personal preference, even admitting the problem may be him.
Photography is not about the thing photographed. It is about how that thing looks photographed. Quote by Garry Winogrand
http://eyeguessphotography.com
http://livegigshots.com
TheMixMan Regular Member • Posts: 145
As a JPEG shooter, I was disappointed to read this, but then got a bit confused when I looked at his example:
From Robin: "ISO6400, RAW processed (left) vs SOOC JPEG (right). Pay attention to the yellow color patches on the eye-brows on the JPEG image."
I find the SOOC JPEG superior - the processed RAW appears much noisier with smeared details(microphone grill, necklace, earring). The JPEG skin and skin tone look more pleasing to me as well. Arguably too smooth but the result achieves better transitions/gradations).
I always enjoy Robin's reviews, and am blown away by his photos. As with most things, I guess this JPEG color/NR/detail issue comes down to subjective preference - or I'm just WEIRD Still planning on slowly embezzling from the kids' college fund to buy my G9! Don't tell my wife!
 TheMixMan's gear list:TheMixMan's gear list
Panasonic Lumix DMC-G7 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Leica Nocticron 42.5mm Panasonic Lumix DC-G9 Olympus M.Zuiko Digital 45mm F1.8 +4 more
CincNY New Member • Posts: 2
12
I just received a G9 earlier this week. I was originally a Nikon shooter (D70 through D810), and switched to Olympus a few years ago after noticing that the Nikon came out only for a very few family events and only car-oriented vacations. I have both versions of the EM-1, and received my G9 this week. I much prefer the ergonomics of the G9 - the larger grip is much more comfortable for my size fingers, and don’t cause the cramping I’ve experienced with EM-1’s after a long day of carrying the camera.
Now on to your question - I have indeed experienced the blackout that Robin Wong mentioned. It occurred when I was comparing the lowlight focusing capabilities of both cameras - the G9 (mounting the PL 12-60) locked up and blacked out after racking back and forth repeatedly without being able to establish focus. Not only was the light very low, but the target was low contrast - a folded blanket across the room. I then shut the camera down and tried again, with the same result. I then mounted the Oly 12-40 2.8, and repeated the exercise, and the G9was able to immediately lock focus. Interestingly, I haven’t experienced the blackout in other very lowlight situations I tested, where the objects (trees, etc.) incorporated more contrast. This leads me to conclude that the result was unique to the target, and not something I’d likely experience in normal use.
Back to my other initial observations:
- I’m disappointed in the light-gathering capability of the PL 12-60 on the G9. My plan had been to sell the Oly 12-40, as I prefer PL’s slightly lighter weight (particularly on the slightly heavier G9 relative to the EM1.2) and its greater reach. Interestingly, the G9 with the Oly lens performed at least as well in low light as the EM-1.2 with the Oly lens - this is what leads me to conclude that the problem is the PL lens, and to agree with Robin Wong’s opinion that the G9’s focusing and low light capabilities are at least as good as the EM-1.2’s.
- As noted above, I love the ergonomics of the G9, the dedicated button layout, the menu organization, and the top lcd readout in addition to the size of the grip. These are all superior to the EM’s FOR ME, and others will have different reactions.
- I also love the G9’s bright, crisp EVF - it’s much superior to that of Olympus. It’s true that there’s noticeable pincushion distortion (particularly if you’re looking for it), but it’s relatively minor and nothing that impacts my use.
That about sums up my initial reactions. I haven’t had a chance to out and really test its images against those of the Olympus yet , but if the results are what others are reporting I’ll be very happy, as I’ve been quite happy with my EM-1.2. It certainly isn’t the equal of the D810, but it gets much more use, and I’m nowhere the photographer to extract or need the extra margin of capability the 810has over MFT...
Brian Wadie
I agree with you, I wonder if his monitor calibration was off?
I cycled through some of my calibration standards on my Eizo monitor and in all of them the RH image looked better and I couldn't see those yellow colour patches.
Should get my G9 tomorrow so will be able to see for myself
Dick Barbour
Dick Barbour Senior Member • Posts: 1,880
I'm enjoying all of this info from you early adopters! Now the big question for us G85 owners is whether to go for the G9 at all. I've enjoyed the G85 and my newly acquired E-m5II so much that it's hard to see what the G9 will provide that they don't, from a realistic viewpoint. I know I would like to have it from the sheer pleasure in owning a nice piece of hardware, but I'm not sure that's enough to sway me. The reviews are inconsistent and the comments in this thread and others on the forum are very welcome.
Dick
 Dick Barbour's gear list:Dick Barbour's gear list
Panasonic Lumix DMC-ZS50 Sony RX10 IV Sony a6500 Panasonic Lumix DC-G9 Sony E 10-18mm F4 OSS +4 more
