L Bracket for M5 / M6
Started Jan 21, 2018 | Discussions
bmike
bmike Senior Member • Posts: 2,644
Re: Solid L-Bracket from China
Looks great. Can you change the battery with it on?
HaroldC3
HaroldC3 Veteran Member • Posts: 3,067
Yep.  Full access to the battery and all ports.
 HaroldC3's gear list:HaroldC3's gear list
Canon EOS M6 Nikon Z7 Canon EF-M 22mm f/2 STM Canon EF-M 15-45mm F3.5-6.3 IS STM Nikon Z 14-30mm F4 +3 more
bmike
Thank you!
lumierephotography Regular Member • Posts: 153
Re: L Bracket for M5 / M6
This is off topic but I wondered what was involved in modifying the Black Rapid strap to use the MagPul connector?  I don't have a Black Rapid strap and use the heavy strap I got from RRS with the MagPul.  I would prefer to use a Black Rapid strap but wasn't sure if the conversion was feasible.
Mark
 lumierephotography's gear list:lumierephotography's gear list
Canon EOS M Canon EOS M3 Canon EOS M5 Canon EOS R Canon EF 400mm f/4.0 DO IS USM +18 more
Steve Siegel
Steve Siegel Regular Member • Posts: 400
Mark
BR straps are set up as a continuous loop. Somewhere in the strap the two ends are sewn together. To remove the supplied connector and install the Magpul, you'll need to separate the sewn ends, make the swap, then re-sew the ends. I used my wife's seam ripper from her sewing supplies to separate the sewn ends (X-acto or razor blade should work too). Before starting, make sure you take note of how the strap threads through the several adjustment pieces so you can duplicate the setup (I took photos to avoid any confusion).
Once reassembled, you can use a dab of glue and a clamp to temporarily hold the ends together. Next, you need to re-sew the ends. My wife said the material and thickness was beyond the limits of her sewing machine, so I went to a boat canvas/sail repair shop to have the strap sewn. Took them about a minute and they charged $2. Any place with a commercial quality sewing machine should do.
 Steve Siegel's gear list:Steve Siegel's gear list
Canon PowerShot G1 Canon G1 X II Canon EOS M6 Canon EOS M50 Canon EOS RP +14 more
Thanks Steve.  This was very helpful but also confirmed my thinking that the only way to modify the Black Rapid strap was to take it apart.  I may do so, at some point, following your directions.
Mark
bluefoam
bluefoam Regular Member • Posts: 236
Sorry for raising a zombie thread... Came across it randomly.
Theres other threads about it, but SmallRig have launched a cage for the M6/M3, it has ARCA mounts on two sides as well as a cold shoe mount on the side, so that an external mic doesn't interfere with the flip up screen.
It might be overkill, but I have it on my M6 for the past week and quite like it. Fits perfectly without modification.
https://www.smallrig.com/smallrig-cage-for-canon-eos-m3-and-m6-2130.html
 bluefoam's gear list:bluefoam's gear list
Canon EOS M6 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +5 more
Crutch New Member • Posts: 1
I’m looking for a L-bracket for a Canon M50. Will this bracket work?
