Replacement for my ageing S90
Started Jan 18, 2018 | Discussions
boblister Junior Member • Posts: 43
My S90 is getting a bit long in the tooth and is missing things like wireless image transfer and full HD video. Although I have an iPhone on me all the time which is reasonable it's not comfortable to use as a pocket camera like the S90 was. I also have a 7DmkII and a M3 both of which I don't consider an easy carry pocketable. So the S90 is the target for replacement. I am trying to keep within the Canon eco system but as it's a fixed lens it's not mandatory. I have been reading about the G9,7,5 and 3-X's but without holding one not sure how they compare. The G5-X looks interesting but seems to have the digic 6 processor where some of the others mentioned above have digic 7. Also not sure if the lump on the top would get in the way. I think I would like a better zoom than the S90 but without sacrificing pocket-ability. Any suggestions appreciated.
 boblister's gear list:boblister's gear list
Canon PowerShot SX50 HS Canon G7 X II Canon EOS 7D Mark II Canon EOS M3 Canon EF 100-400mm f/4.5-5.6L IS USM +2 more
Canon EOS M3 Canon PowerShot S90 Panasonic Lumix DC-G9
TryAgain New Member • Posts: 19
Re: Replacement for my ageing S90
I'm in a similar situation to you as I'm looking for a replacement for my trusty old S95 which is very similar to the S90. I'm sure that, like me, you've looked at all the other threads on this topic and
As ever it depends what you want to do with the camera but it looks like you are in the same market as me for a pocketable camera to supplement the 7D2 and M series cameras so I'll summarise my decision process.
The obvious candidates are the Canon G9X ii, G7Xii and the Sony RX100 series. There are a couple of Panasonic cameras but they are a bit larger. The Canon G5X is also a contender but the viewfinder, for me, eliminates it as it sticks out of the top of the camera making it feel much larger.
You will find on the other threads lengthy comparisons but basically the choice comes down to a compromise on size, zoom range and availabilty of a viewfinder.
My ideal camera would be a full frame sensor, 10-600mm f1.4 lens camera in an S95 form factor. Unfortunately I couldn't find a camera that met my ideal spec.
Based on spec alone I came down to either the G9X ii, G7X ii or the Sony RX100 iii or iv and shortlisted that to the G7Xii or RX100 iv. Nevertheless I decided that, as the reason I wanted this camera was so that I would carry it more frequently, that handling the camera for myself was probably key and I couldn't make a decision purely on the specification.
As a result I spent time in the camera dept of my local John Lewis store in the UK on Saturday. A very helpful assistant who was herself in the market for a similar spec camera helped me choose. She had opted for the RX100 as she was primarlly interested in vlogging whereas I decided on the Canon G7X as I liked the feel, ergonomics and the wider zoom range which I thought made it more suited to my usage.
The closest match I could find to the S series was the G9X ii. It's a comparable size to the S90/95 with an up to date spec. The downside is that it has a more limited zoom range - only up to 70mm or so and a slow lens. For me that was an elimination but it was the only camera that really "felt" like the S95. I thought long and hard before rejecting it but finally decided that the other cameras weren't so much larger or heavier that I wouldn't carry them as much as the G9. It really is a nice very pocketable camera and it was a hard choice to eliminate it.
I eliminated the Panasonics as I found them to be over the limit of what I would consider pocketable.
I liked the Sony and didn't have any problem with the menus which others have found to be confused. I liked the fact it had a viewfinder but didn't like the compromise on zoom range - again stopping at around 70mm whereas the G7X runs to 100mm. It has a quality feel and In all honesty I'm sure I would have been very pleased with it if I'd bought it. I am primarily looking for a camera for stills with the occasional video, if my usage had been more skewed to video I would have bought the Sony without hesitation.
For me the G7X ii was the best compromise. It's a little larger and heavier than the S95 but not greatly so and similar in size to the Sony. It does fit into a trouser pocket and easily into a jacket pocket. I liked the handling and the articulated screen and decided that a viewfinder wasn't really a key feature for me.
Your needs may be different of course so I would recommend handling the cameras yourself if you possibly can. You've probably seen that DPReview have also published a guide to Enthusiasts Pocket sized cameras which is in the "Buying Guide"section of the site.
The final barrier to my making a decision was the fact that there are rumours of imminent upgrades to these cameras. I concluded that there will always be better cameras in the pipeline and have bought the G7X ii.
Hope that helps.
 TryAgain's gear list:TryAgain's gear list
Olympus C-2020 Zoom Olympus Tough TG-4 Canon G7 X II Canon EOS 6D Canon EOS 7D Mark II +5 more
saaber1 Senior Member • Posts: 2,164
I've been comparing lots of small canon P and shoots and have held several at best buy.  I think it depends on what physical size you can live with.  The g9x II is almost the identical size and weight of the s90.  The g7X II has more features but is substantially heavier and feels "chunky" to me.  I think the g9X II is jeans-pocketable and the g7X II is a little too big and really heavy for that (IMO, other's personal preferences may differ).  Both the G9x II and the g7X II pictures on flickr look excellent to me for this size of a camera.  I would suggest checking those out.
Of course the larger-sized sensor cameras will be even better but cost more and are larger (g1x III etc).  If you are willing to live with a camera larger than the g7x II there are tons of cameras to choose from including g1x III, mirorless DSLRs, DSLRs, etc. etc.
So maximum size you can live with is a key factor IMO.  For me jeans-pocketable means I can take it anywhere when traveling and forget it's there almost.  Jacket pocketable is a whole other story and may mean carrying it on a sling strap (I don't like neck straps).  And if I'm carrying it on a sling strap I might as well have a full frame DSLR for the huge increase in image quality.  That's just how I think about it though and other people of course have different preferences.  I was very impressed with the g7X II, it is just a little heavy and big for my preference with this type of camera.
OP boblister Junior Member • Posts: 43
Hope that helps.
That's helped a great deal and confirmed some of my own thoughts. I'm in the UK too at the southern edge of the Lake District which, unfortunately hasn't many camera shops to go and try things. I have a choice of order and take a chance or travel to try before buy.
One of the reasons I liked the G5X is the extra controls and articulating screen as otherwise it seems to have exactly the same spec as the G7X. I like to try and keep as many controls as I can as opposed to muttons and menus. I'm still old school having being brought up on film cameras. The two things that are now putting me off it are the older Digic 6 processor and with having the hump on the top starts to take it out of the realm of pocketable and begins to come nearer to the size of the M3. The G7x ii is stating to look as the better bet.
It's mainly going used where I would normally  use a phone camera. The camera on my iPhone X is superb but lacks so many features that a dedicated camera has. Plus it feels like I am holding a phone and not a camera. I wanted something with a decent oom but that doesn't go hand in hand with compact size. I have a Panasonic TZ60 tucked away somewhere for compact high zoom work, sacrificing a bit of quality.
I did look at the RX100 but like you said it has a smaller zoom range and doesn't seem as intuitive as the Canon for me.
Might see if I can get to a camera shop over the weekend.
The G7 has the edge on the G9 for me with it having a more acceptable zoom range. I don't think there is a massive difference in size between the two. I tend to think more jacket pocket anyway. I'm a little reluctant carrying a camera in a trouser or jeans pocket due to a problem I had a few years ago. This involved an Ixus predecessor to the S90 I had. The lens retraction failed due to dust etc in my pocket. It did get repaired but I only carry a camera in some sort of case now. The S90 lives in a tight Crumpler case for example. I am hoping to get the chance to handle a G7 to help make my mind up.
One other point that I didn't mention is just how useful the "touch to select focus point" feature is. I've only picked up on that point while using the camera since I got it.  So far, in use,  I would rate that feature well above having a viewfinder.
I hope you manage to find a store with them all in stock.
My next challenge is to find a case that doesn't bulk the camera up so much that it can't be carried in my pocket. I used the soft case from my old Olympus mu on the S95 but the G7X won't fit in it.
Good luck.
I really like the touch focus on the M3 so it will be a great bonus having that on the G7 as the S90 didn't have that feature.
I wont carry without a case of some sort. I had a nice Crumpler for the S90 which I don't think will fit the G7.
https://www.amazon.co.uk/Crumpler-Compact-Camera-Pouch-Strap/dp/B001LGZDXQ
