xtrans vs bayer sensor aperture priority mode
Started Jan 14, 2018 | Discussions
Dwiptrlatief Regular Member • Posts: 286
hai i wanna ask you guys,i have X-A1 (bayer sensor) and X-T1 (xtrans ii),i mainly use apeture priority,but i feel that +1 on my xt1 is brighter than my +1 xa1,is xt1 +1 ,is it normal?and why i feel like my xa1 is sharper
Fujifilm X-A1 Fujifilm X-T1
Sjak
Sjak Veteran Member • Posts: 7,318
Re: xtrans vs bayer sensor aperture priority mode
With +1, do you mean +1 on the EV-dial?
Sharpness: Do some tests if you are curious. Use a tripod. Same lens, same composition same shutterspeed, aperture etc. Then switch cameras. Best is to use a remore, or the self-timer, to exclude any vibrations from you operating the camera.
You can also use that setup to test your EV-question
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
Charles2
Charles2 Veteran Member • Posts: 6,810
Just to be sure (and assuming that you compare camera JPGs), did you check that you set Sharpness the same in the two cameras?
carylee2002
carylee2002 Regular Member • Posts: 360
Check to make sure your shutter speed is the same on both cameras for comparison.
 carylee2002's gear list:carylee2002's gear list
Fujifilm X100F Fujifilm X-Pro1 Fujifilm X-E1 Nikon D7100 Fujifilm X-M1 +29 more
(unknown member) Forum Pro • Posts: 16,732
I suspect there are slight differences in the default JPEG settings. One is a consumer camera and the other is a semi-pro enthusiast camera. Enthusiasts are usually happier to retain more highlights and start with less sharp images, especially if they plan to tweak them later.
Canon Rebels always had garish over-sharpened JPEGs from memory. It's apparently what consumers want. Their pro models were much more restrained.
Reporter: "Mr Gandhi, what do you think of Western Civilisation?"
Mahatma Gandhi: "I think it would be a very good idea!"
Ed B
Ed B Forum Pro • Posts: 12,575
Great answer and soooooo true.
I've tried to explain this, more than once, in a couple of these forums but it seems to be a hard thing for many people to understand.
Even when an enthusiast or a pro is shooting JPEG they don't want to see an over sharpened image or an image with too much contrast coming straight out of the camera and Canon point & shoots/entry level DSLRs, compared to their upper level cameras, are a perfect example.
Canon, Nikon and Fuji all seem to be designed this way because their upper level cameras are geared more towards the enthusiast rather than the casual photographer.
People should consider the fact that just because they can afford to buy an expensive or upper level camera doesn't mean that camera will be the best camera for them.
The X-A1 is an entry level camera and whether people on these forum want to admit it or not, most people who buy an entry level camera shoot JPEG, and use one of the auto picture functions more than anything else.
A great many of them don't want to mess with post processing and want an image that pleases them, straight out of the camera.
