How much better is 50mm 1.8 over 22mm 2.0 in terms of taking portraits?
Started Jan 14, 2018 | Questions
doraemon784 New Member • Posts: 4
Hi, I recently got my M10 and 22mm 2.0 but I have been quite disappointed with the amount of bokeh that I get when I am taking portraits. So I have been looking into some other lenses that may give better results and after extensive searching online, it seems like either 50mm 1.8 or 1.4 is a reasonable option for me. But seeing that 50mm 1.8 is only 0.2 different from my 22mm in terms of focal length, I was wondering if this would still make a whole difference in terms of bokeh.. or would 50mm 1.4 be a wiser choice for me?
Thanks!
Canon EF 50mm F1.8 STM Canon EF-M 22mm f/2 STM Canon EOS M10
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: How much better is 50mm 1.8 over 22mm 2.0 in terms of taking portraits?
Thanks!
I think you're talking about the amount of background separation, rather than bokeh. This is determined by the depth of field at a given focal length, aperture, and subject distance. The 50 is only 1/3 stop faster than the 22, but it is much longer. You will be able to get considerably thinner depth of field with the 50 F1.8 than with the 22. However, you could also experiment with different backgrounds in your portraits. If the background is far enough away, and relatively uncluttered, even the 22 can give a pleasing background separation shot wide open (at F2). The 50 F1.8 STM is definitely worth getting. It's small, light, and sharp. Even with the adapter, it's about the same size as some of the EF-M lenses. I use the 22, the 35 F2 IS, and the 50STM for portraits. Depending on what I'm looking for, they all work really well with the M cameras.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
007peter
007peter Forum Pro • Posts: 12,933
NIGHT & DAY, 50/1.8 is enough, 50/1.4 is a soft lens with whiny AF motor
6
The problem with 22mm are 3 folds:
1. You can't get sufficiently Thin DOF without shooting CLOSE to the subject
2. but shooting Close to the Subject induce unpleasant Facial Distortion (nose)
3. 22mm (too wide) doesn't compress background enough
Where as 50mm f/1.8 are
1. Telephoto enough to induce background compression
2. You don't need to shoot NEAR your subject to produce decent Bokeh
My only recommendation is to avoid the nasty Canon 50/1.4 @all cost:
  • This lens is OLD
  • It has a FAKE USM (Micro-USM)
  • F/1.4 is horribly SOFT, and GHOSTING
  • 50/1.4 require stepping down past f/2.8 to achieve decent sharpness
  • 50/1.4 @1.8 is much softer than 50/1.8 wide open
Good 50/1.4 review and studied it, you're discover its weakness.  I bought one and return it for 50/1.8 II.  It cannot compete against the newest Canon 50/1.8 STM in any IQ  test.
 007peter's gear list:007peter's gear list
Panasonic Lumix DMC-GF6 Panasonic 20mm F1.7 II
chrisno Contributing Member • Posts: 925
Thanks!
22mm on M system is 35mm and not a decent portrait focal length
50mm f/1.8 is an excellent choice for the price
if you do not mind soft edges, corners and no autofocus, take this 50mm f/1.1:
50mm f/1.1 - Bokeh Beast for $160!
mpressed Contributing Member • Posts: 950
Im gonna ditto ali's comments.  The 50 1.8 will give you much better separation and ultimately the "bokeh" you are looking for.  i went the same route thinking i like the 22 a lot but its design does limit it in certain areas like DOF.  And without a doubt the 50 1.8 is a great lens for the M line its light and small, i owned the 50 1.4, but shortly after getting my M5 canon had the 50 1.8 on sale so i scooped it up.  BUT i found the 50  little long for many situations so i played with and fell in love with he 35 IS F2 , and it is now the lens usually on the m5.  Its more expensive but worth it and you can sometimes find a good used or canon refurb around, although as its become more popular its becoming hard to find the deals...
mp
 mpressed's gear list:mpressed's gear list
Leica C Canon EOS 5D Mark II Canon EOS 40D Canon EOS M Canon EOS M5 +15 more
lumenite Senior Member • Posts: 1,207
chrisno wrote:
Thanks!
Wow, I did not know that there was such a lens. Thank you for your input.
At Ebay, I found some light,cheap,fast lenses (manual, though)
7artisans 25mm f/1.8 @70
7artisans 55mm f/1.4 @121
Kamlan 50mm f/1.1 @$180
Meike 35mm f/1.7 @80
Great!
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
RA40 Contributing Member • Posts: 706
The 40mm STM is also one to consider. My 50/1.4 I'm pleased though YMMV for the look.
Mike:)
 RA40's gear list:RA40's gear list
Canon PowerShot G6 Canon EOS M3 Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 24-70mm f/2.8L USM +10 more
Lenny_D Forum Member • Posts: 55
An good alternative is the EF-M 28mm F 3.5.
A sharp lens (probably the best in the EF-M line), good for portrait and macro as a bonus.
 Lenny_D's gear list:Lenny_D's gear list
Canon PowerShot S90 Canon EOS 20D Canon EOS 6D Canon EOS M6 Canon EF 50mm F1.4 USM +5 more
Phily Regular Member • Posts: 134
Re: NIGHT & DAY, 50/1.8 is enough, 50/1.4 is a soft lens with whiny AF motor
Nothing wrong with my 50mm F/1.4
caterpillar Veteran Member • Posts: 7,649
I believe the 28mm f3.5 is a macro lens.  You may decide to go 3rd party. I think there is a Sigma 30 f1.4 DCDN.  it's a fast lens and very sharp. It should equal to around 48mm in 35FF.
- Caterpillar
'Always in the process of changing, growing, and transforming.'
 caterpillar's gear list:caterpillar's gear list
Panasonic FZ1000 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 70-200mm f/2.8L IS USM Canon EF-S 18-135mm F3.5-5.6 IS STM Panasonic Lumix DMC-TS4 +24 more
brightcolours Forum Pro • Posts: 15,885
A few points
The amount of BLUR. Bokeh is a term used when describing the quality of how "blur" (out of focus areas) are rendered.
Yes, they are reasonable options. The 50mm f1.8 STM is very affordable, and pretty good wide open.
You must mean f-stop, not focal length?
The f-stop number means focal length divided by this number = aperture diameter.
For the 22mm f2 that means: aperture of 22 / 2 = 11mm maximum aperture diameter.
For the 50mm f1.8 STM that means: aperture of 50 / 1.8 =  27.8mm maximum aperture diameter.
That means that the 50mm lens will give almost 3 times (2.53x) the amount of blur at the same distance. And with the same subject magnification (you have to get closer for that with the 22mm lens) 1.7x the amount of blur.
The Canon EF 50mm f1.4 USM is not the sharpest lens wide open, with also quite low contrast. It also is not of the best mechanical design (easily damaged internals). The Sigma 50mm f1.4 EX DG HSM has very nice bokeh, but I am not sure how well it focusses on EOS M, and it has been out of production for a long time now. The replacement Sigma 50mm f1.4 Art is big and heavy, so because of that not the most logical partner for an EOS M10. The Tamron 45mm f1.8 IS USD is an ok lens, but I do not know how well it behaves on EOS M.
The Canon EF 50mm f1.8 STM is a cheap and quite good lens, the bokeh not too smooth but not that bad either. So, quite a logical, light and small choice.
Thanks!
R2D2 Forum Pro • Posts: 26,528
Another vote for the 50 STM.
Or for even great background blur, the 85 f/1.8.
R2
Alastair Norcross
A quick illustration of the difference between 22, 35, and 50
Here are two shots from each, at, or very close to, wide open, just to give you an idea of the difference for portraits. These are all casual shots of friends, using just available light and no posing:
First, a couple with the 22:
Next, a couple with the 35 F2 IS, adapted:
And finally, a couple from the 50 F1.8 STM, adapted:
Alastair
matrix44 Forum Member • Posts: 86
Thanks for the recommendation. I spent a lot of time researching this lens after you mentioned it, and I ended up ordering it last night for $173 shipped. Hope it doesn't take too long to get here from China (it has already been shipped).
This will be my first manual focus lens for the M6. I spent some time with my 22mm and 18-150mm (at 150mm for shallow DOF) in manual focus mode to see if I can live without AF. I was able to take plenty of sharp shots with focus peaking and some practice.
Since I only bought this lens for it's supposedly great bokeh, I will be shooting it wide open a lot. It will definitely take a lot more practice and patience to get used to MF at F/1.1. Looking forward to the challenge!
Oh, and I also just picked up a 50 1.8 STM, and my ef-m adapter arrives tomorrow, so it will be interesting to compare the two. I'll post on this forum as soon as I am able to do that comparison.
ps: This is my first post here!
beagle1 Forum Pro • Posts: 11,740
Thanks!
try the 50mm 1.8 STM - it's better bokeh that 22mm but longer focal lengths - 85, 100, 135, etc will be better
www.flickr.com/photos/mmirrorless
You are welcomed!
I will get a piece of mine also just for the bokeh difference between 1.8 and 1.1.
Besides bokeh, 1.1 is very useful in tight areas because dof is so thin, you can blur the background behind the subjects even its a few inches apart.
My Kamlan 50mm F/1.1 arrived today, which was a lot earlier than expected. I'll post a more detailed review later, but initial impressions after playing around with it for an hour or so are very positive. I am really enjoying the bokeh and shallow DOF. I also received my 50mm F/1.8 STM and Canon EF adapter, and that is another incredible combination. I'm happy I bought both and they fulfill totally different needs. More soon (including sample photos, photos with lenses mounted on my M6, etc.).
aeronium Regular Member • Posts: 143
How's manual focusing on with it? I imagine f1.1 to be super shallow so getting sharp photos might be a challenge.
 aeronium's gear list:aeronium's gear list
Canon EOS 5D Mark IV Canon EOS M6 II Canon EOS R5 Canon EF 24mm f/1.4L II USM Canon EF 50mm F1.4 USM +10 more
With a camera offering focus peaking and/or "magic zoom" (EOS M + Magic/Tragic Lantern) it should be pretty easy.
From the video it is not totally clear if indeed the lens offers f1.1... The odd behavior of no real change in blur from f1.1 to f2 either points to an issue with the aperture stopping down, or with it not really being f1.1.
This lens are reviewed numerous times and everyone seem to agree it is legit f1.1.
One of biggest plus besides bokeh is the extreme low light performances, you can gather about 3 times more light than  50mm F/1.8.
The biggest downside is that it is really hard to nail perfect focus. When you focus the eyes, the nose already got blurry.
But for the price it is really hard to complain, it does remind me a lot of 50mm F/1.2 and 50mm F/1.0 from Canon, which costs 10 times+ and weigh like a brick.
