S90 vs. G5X
Started Jan 13, 2018 | Discussions
Seedeich Veteran Member • Posts: 3,034
S90 vs. G5X
I’m like most on these forum - I like new cameras and I like to upgrade.
Just for fun I went out and shot the same stuff with my old S90 and the G5X. The light comes from a handheld Metz 28 CS-2, which was triggered by the pop-up flashes in TTL mode (dialed to -1 flash comp.)
The G5X was shot in M mode, the S90 in A mode with exp comp dialed down, because you can’t use TTL flash in M mode.
Same postprocessing in DxO from RAW files.
This is not meant as a scientific comparison - I just find it thought provoking, how little difference there is in real life.
Canon PowerShot G5 X Canon PowerShot S90
Chaplain Mark
Chaplain Mark Veteran Member • Posts: 6,539
Re: S90 vs. G5X
Very nice demonstration of how little difference there is in real life, indeed..!!
Just wondering, which DXO filter did you use to add the bird poop to the lamps??
Thank You,
Chaplain Mark
'Tis better to have a camera and not need one than to need a camera and not have one.
 Chaplain Mark's gear list:Chaplain Mark's gear list
Canon G3 X Canon PowerShot G5 X Sony a7R III Sony a7C Sony FE 135mm F1.8 GM +3 more
saaber1 Senior Member • Posts: 2,164
Re: S90 vs. G5X
Excellent post and excellent example of challenging low light conditions for a non-DSLR to tackle. I've been shooting with some small sensor elphs such as the SD990 (1/1.7" CCD sensor) in raw and it's amazing how even these old cameras compare.
One can use the free CHDK hack to add time-lapse, very long shutter, new auto-iso limits, ability to shoot raw, zebra stripes, etc. to almost any thrift-store-priced powershot.
The ability to shoot RAW seems critical to me when comparing the SD990's JPEG vs. Raw pics. Really expands the dynamic range of these little cameras.
Next I'm going to try adding off camera optical slave flashe(s) to the sd990 shots to see how it looks in more challenging conditions such as your shots. Thanks much for the post!
To add to your point, here is a SOOC shot from a year 2002 3.2 Mp s230 (non-hacked) -strong light favors these small sensor cameras of course:
Juksu Regular Member • Posts: 109
Re: S90 vs. G5X
The biggest difference as to the quality of the images is probably focusing speed, try focusing on fast, erratically moving subject, and you'll see why you should not put the G5X for sale on e-bay and settle for s90..
But I do hear you... As far as image quality on good conditions go, I sometimes stumble on some old photos shot with a S95, and for a second there I wonder if I really do need all those more expensive, big cameras. Then I remember...
 Juksu's gear list:Juksu's gear list
Canon PowerShot S95 Canon EOS 40D Canon EOS 60D Fujifilm X-T10 Samsung Galaxy Note 4
OP Seedeich Veteran Member • Posts: 3,034
Re: S90 vs. G5X
Thanks, Mark.
The DxO filter is obviously called “Bird Poop Effect”. Life’s so simple.
Re: S90 vs. G5X
Thanks, saaber1.
I think, it makes only sense to compare RAW files developed with a modern RAW converter to see what these old sensors really can deliver.
Never thought of using CHDK. I don’t think, I need the extra features for the S90. But I still have two older IXUS cameras. Could be fun to check out, if CHDK works with them.
You want to go strobist?
What about this?
https://www.flickr.com/photos/seedeich/6005968845/
Or even worse.
Re: S90 vs. G5X
Thanks, Juksu.
I have no plans to sell my modern cameras.
The new sensors really have an advantage in low light.
It’s also easier for the G5X to focus in low light.
For fast, erratically moving subjects I use zone focussing anyway (prefocus by half-pressing the shutter button onto the area where the subject is). For this technique the S90 has the advantage of the deeper DoF.
Zone focussing is also great for street photography, where the small S90 has the advantage, that it can disappear in the palm of the hand.
Re: S90 vs. G5X
Lenin Square, St. Petersburg, Russia
I love the tilt screen on G1Xii -- I look down at the camera just above my waist, and people have no idea I am shooting them.
Jon_T
Jon_T Veteran Member • Posts: 6,393
Re: S90 vs. G5X
Curious are you using the DxO PhotoLab 1.1.0 "Essentials" or the "Elite" version with the Prime noise reduction for RAW images?
Reason for asking is at 800 ISO and above my FZ1000 and ZS100 IQ noticeably better than my S95 or G15; ditto with some G3 X sample RAW images I downloaded/ PP prior to getting the FZ1000.
Some 1600 ISO images PP with DxO Optics Pro 11 Elite Suite (EXIF data in images):
FZ1000 RAW 1600 ISO
FZ1000 RAW 1600 ISO
ZS100 RAW 1600 ISO
ZS100 RAW 1600 ISO
Even with RAW 3200 ISO is pushing the 1"-Type sensor:
FZ1000 RAW 3200 ISO; 1/30, 240mm 35mm equiv; handheld
FZ1000 RAW 3200 ISO
At least from my results PP the RAW 1"-Type 20 MP sensor overall provide noticeably better IQ than the smaller 1/1.7" sensors.
Jon
 Jon_T's gear list:Jon_T's gear list
Panasonic Lumix DMC-FZ200 Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot S110 Leica C +16 more
Re: S90 vs. G5X
Vladimir Ilyich probably doesn't mind getting shot and the two ladies might shoot back.
I was thinking more about getting close when shooting street.
chrisno Contributing Member • Posts: 925
Re: S90 vs. G5X
there is little difference because it is well lit
most of the people who bought a P&S like this probably never carry around with an external flash
Chaplain Mark
Re: S90 vs. G5X
Thanks, Mark.
Ah, yes...of course....!!!   🤣🤣🤣
Thank You,
Chaplain Mark
Re: S90 vs. G5X
I’m using DxO PhotoLab Elite. But very rarely Prime Noise Reduction.
The images in the first post were just processed with normal NR.
The older ones from before 2012 where JPEG, converted to b&w. I wasn’t shooting Raw before 2012.
Even this one at ISO 6400 was processed with normal NR. The grain, or call it noise, is perfectly acceptable for me. This is of course not possible with the S90.
Re: S90 vs. G5X
Yes, they are well lit. And up to ISO 800 the S90 does quite well.
Fortunately, most users of enthusiast compact cameras do understand, that they need light of some kind to take pictures. For me it does not matter whether I shoot with a P&S or DSLR - the lighting is the same.
We’re not talking about entry level P&S users, most of which anyway have migrated to smartphones.
davesurrey Senior Member • Posts: 1,846
Re: S90 vs. G5X
An interesting comparison, Thanks for this.
I have a Canon G7X ii which I bought as a compact but "good in low light" carry around camera and haven't been disappointed.
I also have a few compact 1/2.3 inch cameras eg Canon SX260 and Panasonic TZ80 which have other strengths and weaknesses.
I use what I think is best at the time ( or what I have with me) but certainly don't ignore smaller, older technology under the right conditions.
The end result is what matters not what bit of electronics was use to capture the image.
 davesurrey's gear list:davesurrey's gear list
Nikon Coolpix A Panasonic Lumix DMC-ZS60 Panasonic Lumix DC-FZ1000 II Canon EOS D30 Canon EOS M5 +24 more
Re: S90 vs. G5X
Thanks, saaber1.
What about this?
Or even worse.
Haha yes I was thinking 2 sb-800s. I love that flash. Powerful, reliable, smart. I also picked up 2 Norman 800 power packs and 9 lh2400 flash heads with various modifiers for ridiculously cheap.   The issue is too much light with these. Need to use nd gels to reduce.
GeraldW Veteran Member • Posts: 8,872
Re: S90 vs. G5X
A very nice comparison.  Fits in very nicely with what I'm doing with my cameras.  I just started a nostalgia collection of older (2010 or earlier) compact fixed lens cameras with CCD sensors that I owned and used in the past.  I also have four newer cameras with CMOS sensors from 2012 or later.
I also enjoy doing comparisons of the old and newer cameras.  The "new" group includes an FZ1000, G7X II, FZ200, and SX260HS.  The nostalgia group comprises the Pro 1, G7, S5IS, SD950IS, S90, and A710IS and are all models I have owned and used previously and which I liked a lot.  I've had the Pro 1, S90, and A710IS right along; but the other three were bought used.
The whole idea was to have some fun.
Jerry
 GeraldW's gear list:GeraldW's gear list
Canon EOS M5 Canon PowerShot S95 Canon PowerShot G15 Canon G7 X II Sony RX10 IV +1 more
Re: S90 vs. G5X
I got the RX100 as an upgrade from the S90, but found the interface frustrating. Then bought the G7X as soon as it was available. I really like it.
The G5X was added to replace the G11, when it started to malfunction. I needed the hotshoe.
I like to use different cameras for different purposes. And the way they behave differently can be inspiring.
Re: S90 vs. G5X
9 LH2400 flash heads? That sounds like serious business.
You’ll probably blow the sensor out the camera, if you use all of them together.
Re: S90 vs. G5X
I got relatively late into digital and haven’t used that many old digital cameras and given some away.
For me it’s fun to be with fellow photographers with their serious, heavy DSLRs and I shoot with a small lightweight camera.
