Strategies for your backup body
Started Jan 8, 2018 | Discussions
jsaras Contributing Member • Posts: 610
My main body is a Panasonic GX85 and I have an Olympus E-PL6 as a backup.  I have some lenses that I don't use that often (14mm pancake and the 12-32mm). I'm considering getting the 20mm f1.7 to make it a stand-alone setup of sorts, and my wife may get a little use out of that, but she's not particularly photographically inclined.
Based on all the other lenses I have,, and lenses that I could get (currently contemplating getting the Samyang 7.5mm 3.5), does anyone have some suggestions as to how to keep the E-PL6 in my rotation?  I want to find a practical use for it.
Things have never been more like today than they are right now.
 jsaras's gear list:jsaras's gear list
Sony RX100 III Olympus PEN E-PL6 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +10 more
Olympus PEN E-PL6 Panasonic Lumix DMC-GX8 Panasonic Lumix DMC-GX85
richj20 Forum Pro • Posts: 10,181
Re: Strategies for your backup body
jsaras wrote:
My main body is a Panasonic GX85 and I have an Olympus E-PL6 as a backup. ...
Instead of thinking of it as a backup body, why not as a second body that you use for certain situations?
I do that with my GX8 and GX7, where the GX7, smaller and with a tilt screen, is ideal with the 20mm f/1.7 for  certain social situations where the system is less obtrusive.
- Richard
JaKing
JaKing Veteran Member • Posts: 6,300
+1 Richard.
That's how I use my E-M1 MkI and MkII.
Different cameras/lenses for different uses.
br, john, from you know where
My gear list and sordid past are here: https://www.dpreview.com/members/1558378718/overview
Gallery: https://www.canopuscomputing.com.au/zen2/page/gallery/
 JaKing's gear list:JaKing's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus 12-100mm F4.0 Olympus E-1 +29 more
mentos77 Contributing Member • Posts: 988
iPhone SE with camera grip on it and Filmic Pro app for very acceptable 4K video. Anyone recommend a good iOS app to get more controls and dynamic range from photos?
OP jsaras Contributing Member • Posts: 610
ProCamera (by cocologics) shooting in TIFF mode works for me in a pinch where there is good lighting and the native 28mm view is appropriate.  It also supports RAW in iPhone 7 and higher.
3dwag
3dwag Veteran Member • Posts: 4,674
Kinda random question and practically off topic, isn’t it?
In the spirit of trying to be helpful, I use an app call Halide on my iPhone X.  It saves RAW files so a bit more dynamic range to post-process from, but I’m not sure if that will work on an iPhone SE, you can check in the App Store.
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
3dwag wrote:
-Dennis W.
Austin, Texas
Absolutely right. Thanks for the recommendation from you and jsaras. I will look in the correct forum if need more.
Back on topic- I use a Ricoh GR when I need pocketable back up with good quality e.g a family wedding the other day.
Cagey75
Cagey75 Senior Member • Posts: 1,347
Yeah ... Android
Seriously though, adding a grip? to an already large phone? May as well have a GX85
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Fujifilm XC 35mm F2 Venus Laowa 65mm F2.8 Macro +1 more
eques Veteran Member • Posts: 4,115
  1.  Use one with a tele lens, the other with a WA. I use the Ricoh GR as WA and the GX7 with 40-150 (or macro or, rarely, the Samyang 7,5 FE).
  2. Use one with the 1,7/20, the other with a slower zoom. - But then there is a danger, you only want to use the versatile 20mm combo (fast, normal FOV, close focus, excellent IQ) and forget to carry the other one.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Cagey75 wrote:
Yeah ... Android
It is a tiny phone compared to most, I don't feel it in my pocket:
amipal
amipal Senior Member • Posts: 1,275
Peter
This is what I've done in the past with my GH3 and GM5. At Goodwood Revival in 2016, I did the following for the airshow part:
  • GM5 with Lumix 14-140mm to captured formations and take-off/landing (close enough to the runway).
  • GH3 with Lumix 100-300m for single aircraft flying.
Both worked very well, and because I had the GM5 on shutter-priority in order to blur props, it only ever used the mechanical shutter.
The only thing I will say is that the GM5's battery went quicker than the GH3's!
Paul
 amipal's gear list:amipal's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +7 more
rsmithgi Senior Member • Posts: 2,939
The issue that you have is that the cameras are too similar. If you prefer the GX85, why would you take the E-PL6 instead? Changing a lens is just not that difficult. If you buy the 20mm and like it, why not just use it on the GX85?
In your situation, you can keep the E-PL6 as a true backup (i.e. use it only when the GX85 fails) or as a second body when you want to shoot with two cameras. In that case you could have a telephoto zoom on one and the wide zoom or prime on the other.
In my case, I have two different camera styles (E-M1 and E-P5) that are generally used with different lenses for different purposes.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
I use GF7 as second body to G80. The GF7 tends to have wide lens Samyang 7.5 FE or Panasonic 7-14mm, with 12-60 or 14-140 on the G80. The GF7 sits in a belt mounted Lowepro case (all lenses up to the 14-140mm will fit). I also have GM1 but the GF7 tends to be used because its tilt screen is very helpful for low wideangle shots - often on the floor with Pixie mini tripod.
GF7 is also used as lightweight travel body (with7-14 /Samyang FE), usually in combo with a Compact/Bridge camera.
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
larsbc Forum Pro • Posts: 18,282
As others have mentioned, the two cameras are similar in form so it's tough to think of any reason to use it other than because it has a different lens mounted on it.  Since it has no EVF, I'd probably keep a short lens on it.  Maybe use it as your wide angle body.
As for *my* backup body, I usually have two different bodies which get upgraded at alternate times.  I have a  DSLR-style (G85) and a rangefinder-style (GX7).  The 7 is used for street due to its tilting EVF and single-axis flip-up rear screen.  It is also used as either the secondary lens (eg: 35-100 on my G85 and 12-35 or 15/1.7 on the GX7) or I hand it off to my son or daughter who want to shoot some frames while I use the other camera.
