Filter use G1x Mark lll
Started Jan 7, 2018 | Discussions
HiTach New Member • Posts: 10
Re: Filter use G1x Mark lll - Lens Cap Alternative
I've been testing my LX100 mostly.
Re: the JCC Z-Cap Z-O14-42 for Olympus 14-42mm EZ lens on G1X III.
Coming back to G1x III and I see there is some vignetting visible on light edged images from the wide end of the zoom range. so not the perfect solution I hoped.
 HiTach's gear list:HiTach's gear list
Sony a6500 Nikon D850 Nikon Z7
mouzhik
mouzhik Regular Member • Posts: 404
Thank you.
So I'm going to stick with the original lens cap: after a couple of days of active use, I find it more or less OK, just a bit stiff to put on/ remove, but its not necessary a bad thing.
 mouzhik's gear list:mouzhik's gear list
Canon G1 X III Ricoh GR III Canon EOS 5D Mark II Canon EOS Rebel SL1 Canon EOS M6 +13 more
scotthunter Regular Member • Posts: 117
TheAlex wrote:
Despite no word from Canon I've noticed some retailers outside the UK (where I am) including a "37mm filter thread" in the Mark iii specifications, including B&H.
It'd be a big mistake for a company to release a camera with no way of attaching filters, surely? I can't see a filter thread on the lens hood (which doesn't seem to be available anywhere in the UK) pictures.
Why not just buy the Canon lens hood? It's a very nice accessory and doesn't make the camera feel any bigger as it is the same diameter as the front control ring.
 scotthunter's gear list:scotthunter's gear list
Canon G1 X III
SoCalTrailRunner New Member • Posts: 15
Re: Caution: Use the Canon LH-DC110 with the G1X III
After almost a week of silence, Canon contacted me personally a third time to inform me of the following: "I would like to inform you that the PowerShot G1 X Mark III allows mounting of external filter by using a filter adapter. Please open attach file." (see image below)
Does anyone know what filter size the DC110 Lens Hood & Filter Adapter is threaded for? And has anyone tried the JJC LH-JDC110 third party alternative? I am desperately seeking a legitimate way to put filters on the G1X M3!
Thanks,
-Barry
mouzhik
DC110 Lens Hood -> 49mm
mouzhik
P.S. You can also screw a filter directly on the objectif: there is a 37mm filter thread.
I've been a little hesitant to try the 37mm direct threading after reading everything here. But the lens hood just adds so much bulk, I may give the direct threading a try.
Thanks,
-Barry
mouzhik
Thanks,
-Barry
So was I... before I bought the camera and had it in my hands: it has a quite normal thread of 37mm (in order to put on the lens hood, I guess) and you can screw on any filter.
I also have the original lens hood, but I hardly use it for the same reason as you: it's bulky and it makes the camera lose its main virtue (compactness).
Sage Senior Member • Posts: 2,596
Thanks,
-Barry
I spoke to Canon's technical support team a couple of days ago and they advised me to not add a filter directly on the lens, but to add one to the lens hood. I'm not exactly sure why they make this recommendation, but I'll follow Canon's advice.
 Sage's gear list:Sage's gear list
Canon PowerShot G1 X Sony a6000 Canon EOS 7D Mark II Canon EOS 5D Mark IV Sony a6500 +24 more
mouzhik
Thanks,
-Barry
Well, I can think only of one reason why they would make such a groundless recommendation: make people buy the optional and rather expensive lens hood...;-)
Their margins on accessories (batteries, lens hoods, etc.) must be three times higher than on cameras and lenses.
Otherwise I like Canon!..;-)
Thanks,
-Barry
Well, I purchased the JJC hood filter adapter, which is identical to the Canon OEM (except 1/3 the price). As far as I'm concerned, they are worthless for using filters, at least a CPL. The filter threads are deep inside the hood. With a relatively low profile CPL filter, I cannot rotate the filter without completely obscuring the frame with my fingers (causing AF to go crazy, not to mention impossible to compose the shot, and also not to mention fingerprints on the filter).
I think I will try direct mounting the filter. And then if I need a hood, I will get a 37mm for the end of the filter.
I can't imagine direct mounting will be a problem, but if it is I have Accident Protection Coverage on the camera
-Barry
mouzhik
"Well, I purchased the JJC hood filter adapter, which is identical to the Canon OEM (except 1/3 the price). As far as I'm concerned, they are worthless for using filters, at least a CPL. The filter threads are deep inside the hood. With a relatively low profile CPL filter, I cannot rotate the filter without completely obscuring the frame with my fingers (causing AF to go crazy, not to mention impossible to compose the shot, and also not to mention fingerprints on the filter).
I think I will try direct mounting the filter. And then if I need a hood, I will get a 37mm for the end of the filter..."
+1
Saying the lens hood of the G1X III is unpractical for using filters would be the understatement on the century..;-)
Actually you don't need to get another hood: the hood has also a 37mm thread, so if there is a (very rare) shooting scenario which requires the hood, I screw the hood directly ON the filter (B+W X-Pro 37mm).
Good point, I will probably just do that. And for what it's worth, I suggested to Lensmate that they make their bayonet adapter for the G1X III. It is awesome for the Sony RX100 series, and would be so much better than the filter adapter or worrying about direct mounting for the G1X.
-Barry
Thanks,
-Barry
I don't think the lens hood adds bulk - it's the same diameter as the lens ring. It's made of the same black aluminium and I think it adds to the high quality feel of the camera. It's a nicely made accessory.
I screw my 49mm ND filter directly to the lens hood and it works fine.
Canon G1 X III
I definitely agree that the hood is low profile as far as hoods go. But it does add almost 1/2" of depth to a camera that is already on the big end of being "pocketable". If pocketability is not a major concern, than the lens hood is a great size. It is also solidly made and threads on/off very smoothly.
UV and ND filters are definitely no problem in the hood. But those don't need to rotate. Using a CPL requires getting your fingers in there constantly, which is a problem. And CPLs are pretty common, especially since the G1X III already has a built-in physical ND filter.
I just wish Canon, Sony, and all the high-end compacts would start including official filter threads. It seems like an easy way to help further differentiate from lower-end P&S and smartphones.
-Barry
Photowalters New Member • Posts: 12
Thanks so much for this info. I called Canon and they seemed to know nothing about the filter size or lens cap. (I bought the Gx1iii used and the seller had no lens cap for the camera.  Very useful...
 Photowalters's gear list:Photowalters's gear list
Panasonic ZS100 Olympus TG-6 Panasonic Lumix DMC-GF1 Olympus PEN E-PL2 Panasonic Lumix DMC-GX85 +2 more
nolten Contributing Member • Posts: 850
I have three 37mm filters for my G1X3, clear protector, polarizer, and close-up diopter.  I also purchased a cheapo 37mm lens cap from B&H that is much less fussy to use than the original.  In nearly three years of extensive use there has been no issues.
I recently purchased a 55mm night sky filter for some of my M lenses.  I'm confident enough in the G's lens that I purchased a 37 to 55 mm step up ring so that I can use the filter on my G1X3 as well.
 nolten's gear list:nolten's gear list
Canon G1 X III Canon EOS 5D Mark IV Canon EOS 90D Canon EOS M6 II
Robinbarke Junior Member • Posts: 31
I use the Hoya 37mm polariser on mine. No problem at all. Lens cap fits over the filter perfectly.
robinbarke
Dusty Road Photos
Dusty Road Photos Junior Member • Posts: 39
Hi,
Did you buy the Sensei or the Kaiser lens cap?
Thank you
"It's Not What You Look At That Matters, It's What You See"
 Dusty Road Photos's gear list:Dusty Road Photos's gear list
Canon G3 X Canon G1 X III Olympus E-M1 II Olympus 12-200mm F3.5-6.3 Nik Silver Efex Pro +8 more
Chris-N Junior Member • Posts: 31
The LH-DC110 lens hood/filter attachment screws onto the 37 mm lens and can accept a 49 mm filter size screwed onto the hood. You can also use a 49 mm thread close up lens/filter The closest focus is at the wide angle end.
I experimented using a 49 to 52 mm filter adapter as I have a lot of 52 mm close up lenses. It works fine, although I had to zoom in a tad to avoid vignetting. It seems that you can only use the thickness of 1 filter at the wide end (24 mm focal length equivalent) to avoid vignetting.
Kind regards
Chris
