Hdmi cable for 5Div?
Started Jan 6, 2018 | Discussions
flatpicknut
flatpicknut Contributing Member • Posts: 693
I bought a cable at Micro Center a few years ago and used it once with an older camera (can't remember if it was a 5Diii or 6d) but it isn't working well with my 5Div. It won't work at all on one monitor and is intermittent on another monitor. Do I need to pay $50 for the Canon cable? There seem to be many cables with good reviews that are $10 or less.
Doug Brock
 flatpicknut's gear list:flatpicknut's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Samyang 14mm F2.8 ED AS IF UMC Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +8 more
landscaper1
landscaper1 Veteran Member • Posts: 4,533
Re: Hdmi cable for 5Div?
I've bought the least expensive HDMI cables Amazon offered, and they've worked just fine for tethering.  Of course, that isn't a monitor connection.  Have you considered that the problem isn't in the cable itself?
Landscaper
 landscaper1's gear list:landscaper1's gear list
Sony Cyber-shot DSC-RX10 Canon EOS 5DS R Canon EF 16-35mm F4L IS USM Canon EOS R Canon EF 50mm F1.8 II +10 more
flatpicknut
OP flatpicknut Contributing Member • Posts: 693
I've considered that but I have seen lots of Amazon comments from folks who seem to have had similar issues when using certain cables. Also, the one monitor that works connects and disconnects when I move the cable around, so it does seem to be a cable issue. I'm torn between just buying the $50 cable or trying another cable at Micro Center. On one hand I see multiple customers talk about how a cable fit better or worked better, but on the other hand I'm not finding any internet guidance from the video folks saying that you definitely need the expensive Canon cable.
Doug Brock
yodermk Senior Member • Posts: 1,386
I use an HDMI cable to connect it to a projector.  Done it with the 5D4, the 5D3, and 60D.  No issues.  It's just a basic HDMI cable with a mini (or is it micro, I forget) dongle on the end.
If it's a *Single* Lens Reflex, why do I need so many lenses?
 yodermk's gear list:yodermk's gear list
Canon EOS 80D Canon EOS 5D Mark IV Canon EF 400mm f/5.6L USM Canon EF 100mm f/2.8 Macro USM Canon MP-E 65mm f/2.5 1-5x Macro +12 more
