Canon 17-40mm L vs 16-35mm L for Real Estate Photography
Started Jan 2, 2018 | Discussions
ed rader Veteran Member • Posts: 9,068
best answer right here....nt
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
lumigraphics Veteran Member • Posts: 3,325
Re: Canon 17-40mm L vs 16-35mm L for Real Estate Photography
The way to move up would be buying tilt-shift lenses. Those are fabulous for real estate.
David M. Converse
Lumigraphics
http://www.lumigraphics.com
dmbibeault Regular Member • Posts: 249
Just curious, how long does it take to shoot a house with the 17TS or any other TS Sense?
Most agents and owners want you in and out as fast as you are able.
at $125.00/hr shooting 10 rooms and outside would take some time, yes?
I agree the 17TS  would get you Architectural Digest look, but Agents I work with are not interested in me hanging around for hours....  Just sayin!
 dmbibeault's gear list:dmbibeault's gear list
Canon EOS-1D X Canon EOS 5DS Canon EOS R6 +1 more
gipper51 Veteran Member • Posts: 5,904
TS lenses don't really take any longer than an ultra wide angle zoom to setup and use.  You can leave it shifted between shots.  Shift adjustments take a few seconds.  You still have to compose and level the camera before you shoot.  In my opinion, they don't slow you down.
With a 17 TS, you could shot every interior shot with it and just crop later. RE work doesn't need the high resolution, so even cropping from 30 to 10MP you'll still be fine.
 gipper51's gear list:gipper51's gear list
Canon EOS 5DS Panasonic Lumix DMC-GX85 Canon EOS R6 Mark II Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM +20 more
J A C S
J A C S Forum Pro • Posts: 20,544
HeyItsJoel wrote:
MjMart85 wrote:
Happy New Year everybody! First of all, I currently own a 17-40 mm and find that it is pretty good, and the price point was awesome when I bought it. I am shooting more and more real estate and a few people have told me to move up to the 16-35mm.. Am I really gaining that much more with that lens? I shoot with a Canon 5d Mark III. Any info you can provide would be greatly appreciated!
-Matt
Noticeable difference between 16mm vs 17mm. Especially indoors.
That extra mm can easily be abused.
Greg OH Regular Member • Posts: 456
They're manual focus.
 Greg OH's gear list:Greg OH's gear list
Panasonic Lumix DC-S5 Samyang 14mm F2.8 ED AS IF UMC Samyang 24mm F1.4 Samyang 35mm F1.4 Panasonic S 24-105mm F4 Macro OIS +4 more
Which most are doing anyway for for RE work.  Most shots you can leave the camera at a hyperfocal distance and f8.  Everything will be in focus.
If you're walking around snapping hand-held pics, they yeah, a TS-E lens will be slower.  But for a typical shooter on a tripod, who is taking time to carefully compose, level the camera, etc., the extra step of adding shift takes about 3 seconds.
Not saying TS-E lenses are as simple as an AF zoom, but there seems to be some myth that they take a long time to setup and use.  I can add desired shift and focus a shot in about 10 seconds.
Steve Balcombe Forum Pro • Posts: 15,582
I think an important point to make here is that you're not using tilt, which can be fiddly to get right, you're just using shift which is easy. I've no experience doing real estate photography with a T/S lens but I can see how it wouldn't be difficult.
Thomas Guenther Senior Member • Posts: 1,511
And having it mounted on a small monopod/tripod, everything can be adjusted once. Having found the perfect perspective through tilting from a definite height of view, it i just an orthogonal 360° turning of the camera system. >>>>> Better results than doing shots with any other non-correction lens, because you "only" have take care of the composition and releasing the shutter.
And the old TSE 17mm from Canon is nowadays a real bargain at the range of the 16-35:
And yes: Your shots will be better in any way over your competitors!
some lenses - some bodies
