Help X-E3 or X100F - using eye glasses
Started Jan 1, 2018 | Discussions
Trintex Regular Member • Posts: 301
Considering X-E3 with 27mm lens or X100F
I am trying to make an informed decision in selecting one of these cameras as a second body. I have read as much as I could find, watched tons of video.
1. Intended use for travel/hiking
2. No further lens for use with the X-E3. Currently have E2 which will be upgraded to
X-T2 or then current model in about a year or so
3. X100F a. leaf shutter, probably not an plus or minus for me.
b. small internal flash a plus
c. ND filter - very interesting
4 As a full time glasses wearer, concerned about, but not well informed about the impact, if any, of the shorter eye point of the X100f. The X-E3 being better (longer), but still shorter than my X-E2.
Also, diopter range of the X100F is less than the X-E3 and my X-E2
Eye Point Diopter Range
X-E2 23mm -4 to +2
X-E3 17.5mm -4 to +2
X100F 15mm -2 to +1
On the X-E2, I had no problem with viewing either with or without glasses using the diopter control, excepting for frequent light leaking around the eye cup. I have read somewhere that the X100F is a somewhat better.
Would be very appreciative for comments helpful with my understanding of these specification differences.
Thanks,
Roger
 Trintex's gear list:Trintex's gear list
Fujifilm X-S10 Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 35mm F2 R WR Fujifilm 50mm F2 R WR +3 more
Fujifilm X100F Fujifilm X-E3
j0llysnowman
j0llysnowman Regular Member • Posts: 147
Re: Help X-E3 or X100F - using eye glasses
I have an X-E2 and X100F - no problem using either while wearing my glasses. I'm EVF almost all the time.
 j0llysnowman's gear list:j0llysnowman's gear list
Fujifilm X100F Fujifilm X-E2 Fujifilm X-Pro2 Leica Elmarit-M 28mm f/2.8 ASPH XF 90mm +4 more
HornOUBet
HornOUBet Senior Member • Posts: 2,228
Slightly off topic, but I wear glasses and I never wear them when using my camera....am I in a minority??
Dwight
take a peek at the world I see at
http://www.flickr.com/photos/96816407@N07/
https://photos.google.com/albums
There are 2 types of photographers....
...those that see the forest.........and those who see the trees....
 HornOUBet's gear list:HornOUBet's gear list
Panasonic Lumix DMC-ZS50 Canon G3 X Olympus OM-D E-M10 II Panasonic G95 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +12 more
Vic Chapman Forum Pro • Posts: 10,694
Silent leaf shutter is discrete and without the foibles of Electronic shutter. Use with flash to 1/1000 for probably the best of all Fuji fill flash results and it can be used in conjunction with the built-in ND filter to make things easier too.
Vic
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan. Writer, comedian, poet, Goon. 1918 - 2002
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
archrich Senior Member • Posts: 1,485
Roger,
I can’t comment about the X-E3, but as an eyeglass wearer I don’t have any problem shooting my X-100F with my glasses. I use both the EVF and the OVF with a slight diopter adjustment.
The X-100F is excellent BTW.
Archie
 archrich's gear list:archrich's gear list
Fujifilm X100F Sony RX10 IV Sony RX100 VI Olympus E-1 Nikon D500 +2 more
dv312
dv312 Veteran Member • Posts: 9,214
Either camera should be able to do this, the X100F being smaller and more discreet
The beauty of XE3; can use with any lens; the bane of the X100F sometimes
I've been using the X100F since May but may sell in favor of XE3 since I need a second backup body to XT2 and the XE3 fits the bill as both backup and street camera + prime
I could have gotten a XT1 and keep the X100F but I don't want to carry 3 bodies on a trip
All good but one needs to use them ; I have not touched these
X-E2 23mm -4 to +2
X100F 15mm -2 to +1
Should be a non issue with either; I wear glasses too (-5.0 correction) and have no problems
XE3 AF is faster than X100F
X100F has better build
X100F has OVF for those who swear by them; I only use it 1% of the time, prefer EVF WISIWIG
The X100F is desirable , albeit not as versatile as the XE3
Best wishes,
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
jhorse Veteran Member • Posts: 5,913
Hi, I happened across this review when looking at the E3, might be of interest:
https://www.youtube.com/watch?v=CY2WX-HhxKk
Hope that helps.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
OP Trintex Regular Member • Posts: 301
Your response got me thinking.  Although I use glasses for everything, I almost always remove glasses for camera use.  I think I asked the question in the wrong way.  As I said, I am a glasses wearer.  Should I have asked if the camera diopter and eye point on X-E3 were a significant improvement on the X100F?  Is any of this relevant for camera use?  Why are the specs on these two camera for diopter range and eye point so different?  Do I need to be concerned.  Most have responded that they have no issues.  Probably I shouldn't be concerned.  But yet...
Thanks,
Roger
klayking Regular Member • Posts: 492
Vic
Totally agree. It is magic waiting for discover for lot of users. I thought it is useless before and dived in last week with my x100. Now I understand why there is a build in Nd filter for this camera and how to combine leaf shutter, Nd filter and flash to create something truly amazing.
Once understood, you will not consider x100 same as other e,t,pro series. It is just not the same thing.
 klayking's gear list:klayking's gear list
Fujifilm X100F Fujifilm X-T2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +2 more
photodan1
photodan1 Contributing Member • Posts: 974
I'm the same, hardly ever shoot with glasses. My right eye is not too bad for distance so I haven't used a camera where the built in diopter wasn't enough. Now looking on the LCD in back, that can be a struggle.
www.dankaneimages.com
 photodan1's gear list:photodan1's gear list
Nikon Z6 II Nikon Z 24-70mm F4 Nikon Z 50mm F1.8
Thanks for your comments.  I'm perplexed why the diopter range on these two camera are so different.  Maybe is just doesn't matter.  Wish I understood.
Thanks, Roger
hdahl100 New Member • Posts: 3
Old thread, new (to me) problem.
I been been using the Fujis for a long time now:
x100 & S & T, X-E1 & 2, X-T10 and the X-T2.
My shooting eye (right) is in terrible shape, but I've always succeeded to adjust the diopter setting on the various models so I can shoot without glasses.
Yesterday my brand new, lovely X100F arrived, and I can no longer see clearly through the VF.
The diopter setting is too narrow. I sold the X100T 2 years ago, didn't have a problem with that. I still don't have a problem with X-T2 or X-T10.
Has something in the X100F model changed or am I just getting really old?
/Henrik
I am not qualified to explain the optics
X-E2 23mm -4 to +2
X100F 15mm -2 to +1
But for me the X100F diopter was a perceived issue.  I did not keep the camera.  The X-E3 is working out quite well.  Also, although the rubber eye piece looks the same as my previously owned X-E2, I have not experienced the light leaks.
Sorry about your X100F, it's lovely.
Roger
DarnGoodPhotos Forum Pro • Posts: 11,881
I think it depends on your glasses. I wear them but have no problem with the eye point on my X-Pro2.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
X-E2 23mm -4 to +2
X100F 15mm -2 to +1
Roger
It must be really frustrating to have a viewfinder with such a limited diopter range. What on earth were Fuji thinking?
Vic
TEAS Contributing Member • Posts: 954
I have these cameras and to me the eyeglass issue is a non issue with any of them.
 TEAS's gear list:TEAS's gear list
Fujifilm X100F Fujifilm X-T20 Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 60mm F2.4 R Macro +17 more
Yeah - just wear your glasses
Denver100 Regular Member • Posts: 246
I own an E3 now and previously a 100F. I am a glasses wearer (trifocals or polarized sunglasses). The 100F viewfinder is slightly better in terms of usability. The difference is not huge and I find the E3 adequate and the 100F adequate plus (by a little bit) Because of less magnification and smaller size and eye-point with both the E3 and 100F you need to be careful to scan the periphery/far corners. But you learn to do this instinctively pretty quickly. This is especially true when compared with the truly outstanding and easy to use viewfinder on the T2 where no such scanning is required. I loved the 100F but traded it in for an E3 because of the added flexibility of interchangeable lenses and the fact that the 27mm pancake is only a tad bit wider than the 100F but still pocketable in a jacket with an E3. If I want total pocketability/stealth I use my RX100 (image quality can't match the Fuji's).
I found the optical viewfinder on the 100F invaluable in very low light situations though and the leaf shutter is very nice. I chose flexibility in lenses for a small amount of extra bulk and a tiny bit worse, but still adequate viewfinder.
 Denver100's gear list:Denver100's gear list
Fujifilm XF 16mm F2.8 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +7 more
Kit Laughlin Regular Member • Posts: 257
I need about a -2.5 diopter for true in-focus viewing via the EVF/OVF. I'm a bit surprised by the narrow range of adjustment, but wonder if there is an after-market solution?
I was a commercial shooter for 30+ years in a former life, and I never used glasses when shooting before, but may have to in the future if the diopter cannot be augmented.
I will search on this myself, and if I find anything, I will post here.
Kit Laughlin
www.stretchtherapy.net, www.KitLaughlin.com/bodypress/
 Kit Laughlin's gear list:Kit Laughlin's gear list
Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro
