G9, a7 II, 6D, or D750
Started Dec 31, 2017 | Discussions
Aydereal New Member • Posts: 5
Have a budget of arnd 2000USD. Wanted to "upsize" from Oly EPL6 to full frame for dynamic range & better performance in the dark. Am a hobbyist so I want a camera I can grow into. BUT I shoot some video too.
Main contenders are G9 and a7 II.
SOS
Canon EOS 6D Nikon D750 Olympus PEN E-PL6 Panasonic Lumix DC-G9 Sony a7 Sony a7 II
Birdingbilly Regular Member • Posts: 189
Re: G9, a7 II, 6D, or D750
If you can cope with the size and more importantly the weight of FF lenses then go that way if on the other hand you want to travel light then stick with m43. The pros and cons in terms of IQ, noise, DOF are all I am sure well known to you.
 Birdingbilly's gear list:Birdingbilly's gear list
norman shearer Senior Member • Posts: 1,418
SOS
Those 2 cameras are very different beasts. G9 is sports/action and video and A7II is for more leisurely genres. I suspect the G9 will provide the 'wow factor' for performance but the A7II will win comfortably in image quality.
I'm guessing you won't be splashing out a lot of money on glass so the size/weight differences may not be a consideration. However using FF with no big/fast and expensive lenses is kind of a waste - may as well get a Sony RX1R? That way you get a taste of the best but are not left drooling over lenses you can ill afford!
I'm still watching A7II 2nd hand prices myself because I'd like to trade-up my Canon 5D so I can better utilise a lot of legacy lenses that rarely come out of the cupboard.
 norman shearer's gear list:norman shearer's gear list
Nikon Coolpix A Sony RX1R Samsung EX2F Canon EOS 5D Sony a7R II +10 more
jb89100 Forum Member • Posts: 69
HI
The choice can be made on the most used focals length
MFT's crop factor is favorable for long focal length.
FF's crop factor is favorable for short focal length.
Rogerf1948 Regular Member • Posts: 169
My question would be "what do you use your pictures for?"
Whilst I would agree that larger formats do give better image quality, I doubt that the quality difference would be very noticeable unless you are making huge prints or taking pictures for billboards!
I know the technical experts will probably disagree, but just my opinion.
I have tried switching to another brand (Sony), but have just sold the last of that gear.  Luckily, I kept my m43 gear and I am very happy using it.
Good luck, whatever you choose.
 Rogerf1948's gear list:Rogerf1948's gear list
Olympus E-M1 Olympus M.Zuiko 300mm F4 IS Pro Olympus 7-14mm F2.8 Pro Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro
bofo777 Senior Member • Posts: 2,267
SOS
If you want better DR and shoot in the dark I guess Sony would be your best choice since video doesn't seem to be your forte....but to tell you the truth my EM1M II which would be very similar to the G9 are above excellent cameras...i mostly do portrait photography and a lot of video lately (in dim lighting conditions) and never yearn for FF ......
 bofo777's gear list:bofo777's gear list
Olympus E-1 Olympus E-M1 Olympus E-M1 II Olympus E-M1 III Fujifilm GFX 100S +17 more
Martin Ocando
MOD Martin Ocando Veteran Member • Posts: 6,722
I often get confused with these questions
SOS
I usually get confused with this kind of questions. Aha, you have $2K for a new body, but you are talking about a Panasonic, a Sony a Canon or a Nikon, and they don't share the same lens mount. So have you even considered that $2K for the body will be the least of your concerns? If you already have a heavy investment in m43 lenses, and you dump everything and start over in another format, the camera body will be a small part of the whole cost. Lenses is where the big money will be.
Unless you only use a camera with the kit lens.
Martin
"One of the biggest mistakes a photographer can make is to look at the real world and cling to the vain hope that next time his film will somehow bear a closer resemblance to it" - Galen Rowell
 Martin Ocando's gear list:Martin Ocando's gear list
Panasonic Lumix DC-G9 Olympus 12-40mm F2.8 Pro Panasonic Lumix G X Vario 35-100mm F2.8 OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH 7artisans 7.5mm F2.8 Fisheye +13 more
ahaslett
ahaslett Forum Pro • Posts: 12,654
What is your budget for lenses?
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
pannumon Veteran Member • Posts: 4,130
Re: I often get confused with these questions
SOS
This is an important point. An other other point is that a camera like G9 does not have that much better image quality in the first place (except in pixel-shift mode; it's not FF). Perhaps something like G80/85 or E-M10 mk III (or E-M5 mk III when it's available) could offer better video and handling, while saving part of the budget for lenses, accessories and software.
Another option is to go for full frame, but $2000 is probably not enough to get a decent kit. Of course, APS-C is in between.
Overall, it's a positive problem, because E-PL6 is already very capable camera.
Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GM1 Panasonic G85 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GF1 +21 more
Rjansenbr2
Rjansenbr2 Regular Member • Posts: 420
The A7II was a disappointment for me. The ibis is not even near as good as in m43s. And Sony lenses tend do be very expensive (maybe with the exception of the 28mm and 85mm). Also the camera interface is not the best.
6D and D750 are excellent, but I am a mirrorless fan.
The G9 is a camera  I am also looking at. But you should also look at the G85 or the Gx85, which are great and not as expensive.
You can also put fuji cameras in your mix. They seem to be great.
For me, m43 is still Kay main choice considering interface, lens size and ibis.
 Rjansenbr2's gear list:Rjansenbr2's gear list
Olympus E-M5 II Panasonic Lumix DMC-GX85 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 +2 more
howardfuhrman Veteran Member • Posts: 4,153
If you do not have a heavy investment in quality m4/3 lenses and do not mind the weight of FF body and lenses, go for the A7II, 6D or D750.  While the FF cameras you mentioned may be older technology, they are full frame cameras and I expect images generated from those camera will be higher IQ than from the G9.
If  however, weight and cost is an issue, I have have been satisfied with my Panasonic M43 cameras as my main camera. I do have a Sony RX1, a FF camera which generates excellent quality images.  While my images may not be ready to be published in National Geographic, I have plenty of excellent photos.
I find that there are a minimum of four main elements to get great IQ: (1) photographer's skill; (2) quality of the lens and (3) the size of the sensor (4) ability of photographer edit images in PP.  I am sure others can add other important elements that I omitted.
I find that poor quality lenses with full frame generally will not yield excellent image IQ.
Good luck with your decisiom.
Kirkdi Regular Member • Posts: 496
SOS
Have you read the DP review for the Sony? Given your requirement for low light performance they did not think the performance was good in that area.
"Not so good for fans of low light photography"
Also you mentioned you wanted to switch to FF so why is the G9 one of your top contenders?
Before deciding on a body/system I recommend you first consider the lens system, both for cost and size.  To accomplish your stated goals you will want fast lenses and better optical quality than the standard kit lens.
If you only have a limited budget can you get the body you want and also a few lenses to cover your needs, or is cost going to be one of the factors in your selection of a sensor type?
If I had $2,000 and wanted to upgrade to a new body and some decent fast lenses certainly m4/3 is going to be a solid option if you can live with the smaller sensor (you did not mention why you felt you needed a larger sensor, big prints?).
Another consideration is image stabilization.  WIth m4/3 you can shoot handheld in situations that would require a tripod for FF or increasing the ISO, which then affects the quality you hoped to gain with FF.
The argument for m4/3 is you already have the 20mm f/1.7, add the 45/42.5mm option and you have two solid lenses for low light situations.  You could consider a lower cost option for the body to start and use your extra funds to purchase another quality lenses, maybe one of the f/2.8 zooms.
A G85 is a well rounded camera for the cost that produces about the best you can get from the 16MP sensor and shoots 4K video as well.  If you prefer Olympus then the EM10 Mk 3 or EM5 is worth looking at.
But then lenses choice is also important in consideration of a m4/3 body as some features in the newer cameras only work with the manufactures lenses.  I have mostly all Panasonic lenses so I would stay with a Panasonic camera at this point if I was going to upgrade.
Good luck with your decision and enjoy whichever camera you select
 Kirkdi's gear list:Kirkdi's gear list
Panasonic LX100 II Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G 42.5mm F1.7 +13 more
Martin Ocando
You've done this before
You have done this before, but apparently never got around to it:
New G7 or 2nd hand EM5 mkii
Martin
trotteritco Regular Member • Posts: 131
SOS
I was in the Oly club for 8 years, and this year, I bought myself new D750.. E-M1 is still going with me, but as a backup, and I rarely use it. When you get used to the IQ of larger sensor, and much much better DR, m43 stays in the bag.
Yeah, it will be a bit bulkier, but not that much, I'm using my E-M1 with the battery grip, and with the 12-40 Pro, it's a little bit lighter than my D750 and 24-120 f4 which is great combo, cant say anything bad about that lens, it's great, versatile, sharp, has good IS, good for portraits and for landscape.
But, the only thing I'm missing with d750 is that awesome IBIS that Olympus has. But Sony has one, if you go FF with IBIS, you will not regret.
 trotteritco's gear list:trotteritco's gear list
Olympus E-M1 Nikon Z7 Tokina AT-X 16-28mm f/2.8 Pro FX Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon Z 24-70mm F4 +3 more
OP Aydereal New Member • Posts: 5
Re: You've done this before
Haha yeah. My budget changed
daleeight Veteran Member • Posts: 3,199
Easy
You're in the Micro 4/3 forum. Get the G9.
Dale
 daleeight's gear list:daleeight's gear list
Olympus E-M1 III Nikon Z7 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko Digital ED 60mm F2.8 Macro +6 more
