Smallest m43 Z Camera E1
Started Dec 27, 2017 | Discussions
cerich
cerich Contributing Member • Posts: 580
audio
I must be doing something wrong, tried on both my E1's to record using external boom mic plugged into the 3.5 audio in and no audio when using the boom mic. Looked thru the settings and didn't see anything that I need to do there.
What am I missing and doing wrong?
The manual really sucks.. LOL
 cerich's gear list:cerich's gear list
Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus PEN E-PL6 Olympus Air Olympus OM-D E-M10 II +33 more
orey10m Regular Member • Posts: 232
Re: Smallest m43 Z Camera E1 $199 for a Limited Time
Are other people using the iphone version of the mobile app? Does it provide a live view of what the camera is recording over wifi or over bluetooth?
The Android version of the app doesn't seem to do either, unless I'm missing something.
my digital photography:
- yero.vsco.co -
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
Re: audio
I'm guessing, but a lot of cameras can provide power to the microphone via the microphone cable.  It may be the Z/E1 does not provide power, and you would need to use a microphone with a battery.
My G85 for instance does provide power, so I don't need to put a battery in my Azden SMX-10.  I'm at work right now, but if I think of it tonight, I might try a test with the Z/E1.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
cerich
Re: audio
Thanks would appreciate that, no powered mic handy, I did try two unpowered units however and no joy.
OP Markr041 Forum Pro • Posts: 10,078
My Android version provides live view. You are doing something wrong. I uploaded a video showing how to use A/B push-screen focus pulls via the app, which requires I see in real time what the camera is seeing.
https://youtu.be/cAsY3NiKqgA
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
Not sure what was going on. Liveview is working fine now with the Android App
- yero.vsco.co -
Michael Meissner
Re: audio
Unfortunately, the results aren't promising:
  • I first recorded 4K30p, with the microphone without battery.  I could not hear anything on my Linux system, even with the sound volume turned completely up.
  • I recorded 4K30p, with the microphone with a battery installed.  I still could not hear anything.
  • I recorded using the built-in microphone, and it recorded, but the sound level was low.
  • I reduced the movie size to 1080p30, and recorded it with the microphone with a battery.  The sound level was really low (less than the built-in microphone).
  • I kept the movie size at 1080p30 and took out the battery.  I could not hear anything.
So, it sounds like it needs a powered microphone, and it wants a higher sound level than my Azden microphone records at.
cerich
Re: audio
much thanks, it helps to at least start the mystery
cerich
Re: audio
used a powered mic, RODE VideMic Pro and all solved, audio is great.
Michael Meissner
Re: audio
Hmmm, I wonder why the AZDEN microphone (which I did try with a battery inside) didn't work as well.
Using the Z-E1 for a second video camera was one of my two main reasons I bought the camera.  If I can't get a cheap microphone to work with it, it would reduce my use of the Z-E1.
Maybe the sound level issue is a Linux thing.  When I have some more time, maybe I can export the video to youtube to see if it is better there.
cerich
Re: audio
yeah the mic I got was the same price as I paid for the camera itself....
Ragnar Jensen
Ragnar Jensen Regular Member • Posts: 433
Re: audio
I get pretty much the same results in Windows...
I have tested with a couple of different microphones:
  • A pair of dynamic mics, of the kind that is often used in radio studios. Being dynamics, they don't need to be powered. They have notoriously low level output, though, that needs a lot of amplification. No surprises there, the sound was barely audible.
  • A cheap, battery-powered stereo mic , with somewhat hotter output. Sound levels were on par with the built in mics, i.e. a bit lower than I'm used to. Sound quality was very good.
  • A pair of studio condenser mics, with external phantom power supply and pre-amps. With these, I could drive the camera's input to saturation. With levels adjusted to something suitable, the camera's sound quality was very, very good.
I also connected the camera to an audio interface and fed it an assortment of test signals at various levels. All in all, the camera seems to want fairly hot input. If I compare it with other recording devices without manual gain adjustment, with the same input levels, the output from the Z cam is lower, it doesn't apply as much gain. On the other hand, if you feed it a good signal, the sound quality is better than I expected, with a surprisingly low noise floor. I find the built-in mics quite good too, for what they are.
While trying out the mics, I took a look at the mic jack with an oscilloscope. It doesn't supply any DC power, so mics that need plug-in power won't work.
Ragnar
 Ragnar Jensen's gear list:Ragnar Jensen's gear list
Olympus Stylus Verve Olympus TG-5 Olympus E-1 Olympus E-3 Olympus E-510 +15 more
Michael Meissner
I think the Z camera is too limited for me
I'm coming to the conclusion that the Z camera is too limited for me, and I'm about to send it back to  B&H (I bought mine on December 29th, so I have to act quickly).
Anybody else return theirs?
For me, I had two uses in mind:
  • I was going to use it as a b-camera for recording video.  However, my external microphone (AZDEN SMX-10) is so faint on the E1, that it is not usable.  While there are microphones that work (such as the $250 Rode microphone), it isn't worth it to me to buy a microphone that expensive to be used for a backup video camera.
  • I incorporate my cameras into various steampunk projects, and I was wanting a smaller body.  However the lack of stablization, the limited menu options, the slow focusing, and not having a touch screen on the camera itself limits what I can do with the camera.
I tore the box in opening it, so I will probably be docked the 15% restocking fee.  But, if somebody still wanted one, I could sell it to you instead.  I'm not sure whether the squaretrade warranty I bought would transfer, but if it does, I can transfer the warranty as well.
MOD Tom Caldwell Forum Pro • Posts: 46,349
Re: I think the Z camera is too limited for me
I will hang on to mine as I consider it a novelty and a pretty good first try at a compact M4/3 camera.  It tends to demonstrate that newcomers can make good things but established corporations with deeper R&D and marketing pockets still have the edge.
I never was really overcome by a presing need for it but my cusiosity was certainly piqued and remains so.  I think that I have mastered everything that I need to know about it and presently it is wearing a converted LM mount lens for manal focus.  I never had any intention of pursing it as a video camera as I have no interest in video and if I did have then the GH5(S) is staring me in the face as i would have to do it properly.
Michael, the GM1 is effectively the same physical size - just differently shaped - it is quite a sophisticated little bit of kit and perhaps you should investigate that one further.
Meanwhile I have intended to put up some sort of report on my experinces with the Z-Cam E1 but my earlier ordered G9 arrived and it is a whole more complex and larger piece of gear to wrestle with and has taken my centre attention for the time being.
But I remain optimistic about the place for the Z-Cam E1 even if it falls short in certain areas, however it is a  good try and I hope that the company that made it prospers as the industry needs more entrepreneurs ho are willing to think outside of the box.
... and of course users who will buy their product to support it.
I also now know that you don’t soft press and wait for focus otherwise 10 images might be caught. Just press through and the camera will focus itself (more or less) and only one image will result.
However if you wish multiple captures you don’t have to change anything just press and hold. Every cloud has a silver lining and latching still image capture into the video capture routine could be handy sometimes.
Tom Caldwell
Re: Stabilization
I used my Z Cam extensively for the first time last weekend and it got some amazing footage. I have some thoughts on stabilization, and what I need to figure out to have it best work for me.
There is a 'video stabilization' option built in to the camera, correct? Does it work with non-stabilized, manual lenses?
FWIW, my handheld footage from my recent trip is very shaky, but I was using the camera in pretty much the most extreme test of stabilization (besides strapping it to a mountain bike or something). I used it almost like one-would use an action cam while on vacation.
I held the camera on a small tripod I was attempting to have act as a selfie-stick/steadi cam (obviously without high expectations of either objective being accomplished). This produced extremely shaky footage, but I would have suspected so with really any camera body that doesn't have something like the 5 axis IBIS of the GX85, G85 etc. Even with a stabilized lens, on a non-sensor stabilized body, I think this extreme of a test would produce very shaky footage.
Nonetheless, that is my main application. So now I'm considering gimbals. I'd consider something like the Zhiyun Crane, but don't really want to drop that kindof money. And that seems to be the bottom of the market..
My question though is do gimbals help to minimize/eradicate what I will call 'extremely minor/high frequency shakes"? Like that induced by your hands, even when trying to hold a camera body still?
(Also, Is there a better forum to ask for detailed perspectives/buying advice on gimbals?)
- yero.vsco.co -
Re: Stabilization
Yes, that in my mind is the most important use of a gimbal - the ability to remove shake and micro jitters from static shots. You can really handhold and be free of tripods, move from point to point easily *or* move while shooting. Here is a video with the Z mounted on the Crane M - pay particular attention to the static shots - tripod steady.
https://youtu.be/WBRrK-6P3UE
Re: Stabilization
That footage looks good. Looks like somewhere near me in the southeast US, with the little bit of snow we had recently!
I am also considering getting something like this, but not sure if it will be smooth enough for what I'm looking for. It's also kind of big.
I really like the idea of just hand holding the top portion of the yi Gimbal , but I don't think the mount they have no that would accommodate the Z Cam.
- yero.vsco.co -
Re: Assignable Buttons
Do you or anyone else know if I can program any button other than the power button to act as the power button? Would be great if I could turn on the camera using the shutter button or something.
- yero.vsco.co -
Nevermind, I found the solution to my problem. STANDBY MODE! I will leave the camera on in this waterproof case that I created for it, and it will go into standby mode. Then when I need to turn it on to take some video, i just 'wake it up" ..I think via the app. Trying to figure out more details of how this works, but it should help me for my purposes.
Basically I need the camera to be able to be turned on without using the power button because the case I have the camera in makes the power button very hard to reach/depress.
I need to figure out if it only goes into standby if it's connected to my phone via the app.
If anyone knows, let me know. Otherwise it's trial aand error
- yero.vsco.co -
TOMAS CRYBABY New Member • Posts: 2
Re: Z-Cam E1 - arrived today
Dear Tom, may I ask you where did you get the Z Cam E1 batteries, pls?
Thanks a lot, Tomas.
