Olympus E-P5 acting funny and now I lost my anti shock settings
Started Dec 26, 2017 | Questions
hockey guy Forum Member • Posts: 83
I have a 3 1/2 year old Olympus E-P5. Yesterday it began to act funny. When I turned it on, it would not turn off and the controls did not work.
I called the dealer from where I purchased it and he suggested that I perform a reset.
I did so. It now seems to be working but I no longer have any anti-shock settings.
I thought that it may have reverted to the original firmware.
I tried updating the firmware with Olympus Digital Camera Updater but I received the message that the camera has the most up to date firmware, 1.7.
Any thoughts?
Thanks.
 hockey guy's gear list:hockey guy's gear list
Panasonic Lumix DMC-LX3 Olympus XZ-1 Olympus PEN E-P5 Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +4 more
Olympus PEN E-P5
Chrihsssih Junior Member • Posts: 33
Re: Olympus E-P5 acting funny and now I lost my anti shock settings
Maybe your Camera was set back to factory settings?
You have to turn on Antishock in two different places:
At first, you have change the settings in the menu. As I don‘t have my camera here at the moment, I can‘t tell you the exact position.
Afterwards, you have to switch it on in the control panel.
 Chrihsssih's gear list:Chrihsssih's gear list
Olympus PEN E-P5 Panasonic Lumix DMC-GM1 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye +4 more
OP hockey guy Forum Member • Posts: 83
Thank you.
I found it and was able to get back the ant-shock settings!
I now want to double check that I should have it set at 0 seconds which I had been using all along.
Thanks again.
Garry Schaefer Veteran Member • Posts: 3,349
Yes. 0-second anti-shock is the way to go.
Garry
 Garry Schaefer's gear list:Garry Schaefer's gear list
Panasonic Lumix DMC-G3 Olympus OM-D E-M10 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +8 more
Thank you and happy new year!
