Dedicated Macro lens "better" for flower shots?
Started Dec 26, 2017 | Discussions
Brian P Smith Contributing Member • Posts: 644
Recently made a thread in the Sony FF forum asking about the 90mm macro vs adapting a Canon 100mm Macro which had some good responses. But it got me thinking, do I really need a dedicated macro lens for my intended shooting purposes? "Macro" for me is not tripod, macro flash, close in on bugs etc; it's more along the lines of flower/leaf photography using "close focus" and in fact in the past I'd just just my olympus 12-40mm pro with a closer focus distance, which served me well.  Below is an example shot of what I'd normal do, and I think a dedicated Macro lens would help, but not be required...
 Brian P Smith's gear list:Brian P Smith's gear list
Fujifilm X-E1 Fujifilm X-T3 Nikon AF-S Nikkor 70-200mm F4G ED VR Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +4 more
D Cox Forum Pro • Posts: 26,384
Re: Dedicated Macro lens "better" for flower shots?
If you aren't going to shoot little flowers, you don't need a macro lens. Even if you occasionally shoot little flowers, you may find that a close-up lens is all you need.
Sigma fp
BBbuilder467 Veteran Member • Posts: 4,404
What size are the flowers ?
You might need a macro lens for the FF to match the same framing that you get with a native lens for m4/3. A flower could be the size of a US dime or a coffee mug and my flowers/buds could be tiny, but nobody would realize that. A lot of my flowers are no bigger than a US penny, so I need the macro.
OP Brian P Smith Contributing Member • Posts: 644
Re: What size are the flowers ?
I've always had trouble with "equivalency" talk but shouldn't the framing of about 80-90mm be similar on FF as with the above shot at 40mm on m4/3?
You don't need to bother with equivalent. Just divide the sensor size by the magnification of the specific lens. It has nothing to do with the focal length. Non-macro lenses are different.
Some m4/3 zoom lenses have as much as 0.3x magnification  at minimum focus. That's 57mm across the frame. This flower could be 43mm in diameter.
Gary from Seattle Veteran Member • Posts: 4,718
For most flowers you don't need macro, just close focus. The 12-40 has .3x magnification and that is usually adequate. A macro lens like the 60mm macro comes into play when documenting very small flowers perhaps 3 or so mm in diameter. The other uses of macro is to be able to distinguish botanical details like the shape, size and distribution of hairs on the flower stem or leaves; and also, when making an artistic image where only part of the flower is in focus.
Nama demissa Owen's Valley
Colombia larsenii Mt. Rainier
Lewisopsis tweedyi Wenatchee Mountains
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G X Vario 35-100mm F2.8 OIS +3 more
