Re: 75-300 ii, Is this what I should expect?
Joe
I am going to go against the flow, and probably upset some folks, and say that I don't think you are doing too badly. There are things which you could do better. The main things being:
Shoot RAW and PP properly. I would not expect to get shots which stand up to critical examination from OOC JPEGs.
Use E shutter. Although the received wisdom is that shutter shock only strikes up to about 1/300, my experience in using EM1 (sorry no EM5) is that it has residual effects at all shutter speeds
It's a balance between getting fast enough shutter, and low enough iso. In some circumstances you just can't get a perfect shot. Today, I had to use iso 3200 to shoot at 1/500 wide open with my test shots. iso 3200 is never going to win any prizes, nor is shutter speed less than 1/500, hand held. I am hoping for better light tomorrow.
Then, there are one or two good shots which have been posted by others, but many are at 200-250mm (some shots quite stopped down as well and some quite unsharp?) It is accepted that 250 -300mm is the problem area for this lens, and those shots you have shown at 300mm are mostly where you think you are having problems, so far as I can see. So shots which are less than 300, or are not posted at full resolution are not going to be helpful for a decent comparison. In fact, if I analyse carefully what I guess to be the focus area of your shots they are not bad (no worse than some others which have been posted) Don't forget you have a very shallow DOF compared with your Fuji (which model, incidentally, I am guessing something with a small sensor) and you cannot expect subject matter on a different plane from the focus area to be in focus.
I am sure with a bit of attention to the points which others have mentioned you are going to be happy with the lens!
Incidentally, I always tell myself that if I can ever get one really sharp photo from a lens, there is nothing wrong with it. If the rest are not sharp it is my technique failing
cheers
tom
Joe Snow wrote:
tomhongkong wrote:
Joe
I have just bought a 75-300ii (GBP 85 cashback in UK at present) and am interested in this discussion. Unfortunately since I bought it, the light has been really poor so I have not got any proper samples. yet.
However, just for clarity
What were your focus settings?
Are these RAW or JPEG?
Have you done any PP on them?
Did you use e-shutter?
Exactly which part of your image are you looking at, which gives you concern about the IQ
Thanks...I hope I can share if the sun comes out!
tom
Hi Tom,
all pictures are SOOC, no PP no RAW. I was using mechanical shutter. The lens gave me some good results (for the price) and I'm happy with, but I had some other photos where the photo is unusable.
the blurry photos are my concern, especially on 1/640th.
I had a fuji before and I was shooting @ 720mm equiv most of the time and didn't have an issue at the same shutter speed. So I thought the lens may suffer from something.
I will try using the electronic shutter and see if that will help.
