75-300 ii, Is this what I should expect?
Started Dec 25, 2017 | Photos
Joe Snow Regular Member • Posts: 143
Hi All,
I was looking for a budget zoom lens that is longer than 150mm and has a good quality (at least the same as 14-150 ii)
and since all reviews I read are saying that 75-300 ii is on bar with 100-300 ii and there is no major difference in IQ, I chose to go with the budget and size advantage.
The IQ I'm getting from this lens is not what I was expecting (Maybe my expectation was high)
So I just want to confirm that this is what I should expect from this lens when you look 1:1.
here are examples of what I consider "bad" shots
Other mages are not bad and I consider them "good"
appreciate your input.
Comment & critique:
gsergei Contributing Member • Posts: 869
Re: 75-300 ii, Is this what I should expect?
This lens is very good from 75 to 200, fair between 200-250, and soft from 254 onward.
Think of it as a 75 to 254 and anything longer is just a bonus.
Sergei,
Calgary.
 gsergei's gear list:gsergei's gear list
Olympus E-1 Olympus E-3 Olympus E-330 Olympus PEN E-P2 Olympus E-M1 +12 more
scottyinfrisco Contributing Member • Posts: 923
This lens and the Panasonic 100-300 seem to vary greatly copy to copy.  The copy of this lens I had was much better than what you are showing here.
 scottyinfrisco's gear list:scottyinfrisco's gear list
Canon EOS M6 Sony a7 III Sony a6600 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM +8 more
addlightness Veteran Member • Posts: 3,641
I'm also struggling to get clean, non-blurry shot. And thanks to tips from this forum, I've learned to shoot at higher shutter speed while keeping ISO below 1600.
Still not happy with my pics. Learning through more practice.
It's still quite awful, so you're not alone
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
OP Joe Snow Regular Member • Posts: 143
would you please post an example OOC?
Thanks for sharing your experience. according to your post that this is what I should expect!
Would you please share the technique so I can try it?
daddyo Forum Pro • Posts: 12,670
18
It's actually pretty simple -- if these are hand held shots, then yes, this is what you can expect.
If not, why not put the camera on a decent tripod, use a cable release or remote release, shoot a static subject, and see if the results are sharp. If the shots are sharp, you lens is good and your technique is faulty, if your shots are soft, you've got a problem.
I have this lens, and get very good, sharp images with it -- I do use a tripod very often.
God Bless,
Greg
www.imagismphotos.com
www.mccroskery.zenfolio.com
www.pbase.com/daddyo
 daddyo's gear list:daddyo's gear list
Olympus 12-40mm F2.8 Pro
Cagey75
Cagey75 Senior Member • Posts: 1,347
6
Not being funny, but looks like your hand holding technique sucks a bit.  Are you reminding yourself that this lens is pretty much a 600mm in terms of full frame? Try hand holding a 600mm on a Nikon D800 and 'casually' shooting .... it's a new ball game, you have to knuckle down, steady up, use a tripod when you can otherwise really pay attention to the fact you are shooting so long.
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Fujifilm XC 35mm F2 Venus Laowa 65mm F2.8 Macro +1 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
Mine would occasionally produce a brilliant shot at 300mm. So the problem is having enough light to have a lowish ISO and at least 1/1600 handheld. IBIS is not terribly effective at 300mm. Also use the electronic shutter.
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me. Make the best you can of every day!
All hand held SOOC
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
You have not stated anything about your camera or settings or technique. All of which can and will affect your results greatly.
With practice and fine tuning camera settings, the sharpness of images I got from my 75-300 mk2 improved dramatically. It is now even quite sharp at the 300 end!
Give us more info to allow us to advise.
PS. Turning on the electronic shutter is an important first step.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
opiecat Senior Member • Posts: 2,410
i have learned to use higher shutter speeds with this lens and it can give great results. Lower shutter speeds can also get good results, but poor hand-holding technique can cause blurriness.
'when 900 years you reach, look as good you will not' -- master yoda
http://opienc.wordpress.com
J Warren Forum Member • Posts: 79
Actually I'm quite happy with mine...My suggestions would be to practice your hand holding technique, get as close as you can, be patient and wait for just the right shot. I've never used a tripod with this lens.
will focus
will focus Senior Member • Posts: 2,640
Higher shutter speeds certainly help, especially when shooting from a moving, bouncing boat, as was the case here. Still, when viewed original size, a crewmember is clearly visible through the windows of the bridge. The distant (10+ miles away) windmills are suffering from atmospheric distortion.
The lens does take some effort to get right and is , after all, like handholding a 600mm at the long end. I've had mine since May and I'm still trying to remind myself that I need to keep the crosshairs on target and squeeze the shutter release like I would a rifle shot If I want detail when zoomed in. I think the stabilization cuts both ways sometimes in that, sure, it helps stabilize the image, but it also tends to hide how sloppy I am holding the camera. Disable it and crack off a few hand held shots. You'll see how bad you'd be if you were shooting an old Nikkormat film camera with a 600mm lens hanging off the front. It's eye opening and an easy barometer from which to compare.
 will focus's gear list:will focus's gear list
Sony a7R II Olympus OM-D E-M10 II Sony a7R IV Sony 70-200mm F2.8 G SSM II Sigma 24-70 F2.8 DG DN +1 more
Martin.au
Martin.au Forum Pro • Posts: 14,339
This is what I expect.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
will focus
Can you post those so they could be viewed original size for comparison?
csiluk Senior Member • Posts: 1,508
Well, the ship looks nice and sharp to me. Nice example.
I checked out your "bird on the fountain" photos in your gallery and I just had to laugh. It looks like it was having a blast
Olyinaz Veteran Member • Posts: 8,283
That is a pretty cool shot of the Wally McCarthy.  Love it.
Oly
 Olyinaz's gear list:Olyinaz's gear list
Olympus E-M1 II Canon EOS 77D Canon EF 100mm F2.8L Macro IS USM Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital ED 8mm 1:3.5 Fisheye +12 more
will focus
Oly
That was taken in October. It was outbound heading northeast in the Saginaw River Shipping Channel into Saginaw Bay and Lake Huron. It's an impressive ship at 1000 feet long.
