Lenses you keep because they are too good to give away....
Started Dec 19, 2017 | Discussions
Jeff4500
Jeff4500 Senior Member • Posts: 1,921
I've got two that I hardly use any more, in fact they live in my LowPro toploader with the Gx8/PL100-400 birding combination, just because when I'm out in the field birding if I see a good landscape type shot I have a 22/28/60 f2.5/.8 setup I could use.
My two are the Panasonic 14 & GWC1 and the Sigma 30mm f2.8 1st version. I've lots of stock images accepted from these two lenses yet I doubt I'd get $75 for the sigma and before they quite making it the 14mm were going anywhere from $125 to $150. I've seen  the GWC1 sit for quite a while at $100 on MU-43.
What lens do you have that are inexpensive yet really good performers or fit a specific space in your lens lineup that you don't use.
Jeff
 Jeff4500's gear list:Jeff4500's gear list
Panasonic 12-35mm F2.8 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix DC-GH6 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +9 more
Panasonic Lumix G 14mm F2.5 II ASPH
JohnLock Senior Member • Posts: 1,524
Olympus 12-40
5
Not inexpensive, but I bought the 12-100 when it came out and now it's my primary lens, but the 12-40 is too good to give up and I use it for night shooting at mostly iso 3200.
Cheers.  JL
 JohnLock's gear list:JohnLock's gear list
Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS
addlightness Veteran Member • Posts: 3,641
Re: Lenses you keep because they are too good to give away....
14/2.5 + Fujifilm 0.76x WC
Sigma 60/2.8
9mmBCL
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
ahaslett
ahaslett Forum Pro • Posts: 12,662
I only use the Zuiko 50/2 occasionally and the 12-40 has replaced the Zuiko 12-60SWD as my standard lens.  When I need them, they are there.
I also have an old Sigma 30/1.4 APSC lens in FT mount which is there in case I need it.  It once did an important job that would not have been possible any other way.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
samtheman2014
samtheman2014 Veteran Member • Posts: 4,571
Though not the best or fastest lens in the system I love the Panasonic 20mm I currently have version 2 only because it came as part of deal with my GX8 , it is optically identical to the mk1.
Between it and the mk1 { my first m43 lens back in 2009} it is by a fair margin  the most used lens I own of any format. Over the years it has been on the GF1,GH2,GH3,GH4, GX7,GX8 and will continue to be used on future m43 cameras { probably the G9 }
Jim Stirling
 samtheman2014's gear list:samtheman2014's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GH4 Sony a7R II Panasonic Lumix DMC-GX8 Nikon AF-S Nikkor 14-24mm f/2.8G ED +10 more
Prairie Pal Senior Member • Posts: 2,912
Jim Stirling
Also my choice.  My version 1always comes along no matter what else is in my bag. The Pan 20 is the reason I entered the micro 4/3 format.  The size, focal length and  IQ all make me happy.
Ivan
 Prairie Pal's gear list:Prairie Pal's gear list
Nikon D600 Nikon D7200 Olympus OM-D E-M10 II Olympus E-M1 III Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II +6 more
samtheman2014
Jim Stirling
Ivan
I agree Ivan I was shooting with a D3X when I saw the GF1 and 20mm and thought that is for me
Jim Stirling
Albert Valentino Veteran Member • Posts: 9,770
-Tamron 90mm f/2.8 (72B) adaptall macro lens . This 1:1 macro lens, with aperture ring, has no camera mount so it can be adapted with a inexpensive AdaptAll adapter for any system. I purchased this in 2013 when I shoot Fuji. Wonderful, large, buttery smooth manual focus ring. Same optical formula as their AF version thatwas discontinued in 2013. I use the Olympus 60mm macro more due to size and AF options
-Nikon 28mm f/3.5. This lens was the gold standard for IR photogrpahy and had no hot spots. I do not shoot these days but who knows what the future will bring so along with the above, will never sell
As for modern lenses I use and plan on keeping....
-Olympus 12-40 f/2.8 Pro. My go to lens with extended warranty until late 2021
-Olympus 60mm f/2.8 macro. Small, light, sharp, with smooth bokeh and limit switches.
All other lenses I own are subject to upgrade but no plans to do so at present
Tamron 72B 90mm f/2.8 adaptall lens on EM1. IBIS makes this combo sing!
Tamron 72B 90mm f/2.8 adaptall lens on Fuji XE1
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
3dwag
3dwag Veteran Member • Posts: 4,674
Re: Olympus 12-40
Cheers. JL
Basically, same here — just could not get enough $ selling it to justify giving up some still viable uses for it, making it an “affordable luxury” backup zoom in a more compact package with one stop more light and in-camera focus stacking (12-100 does not have).
 3dwag's gear list:3dwag's gear list
Fujifilm FinePix Real 3D W3 Panasonic Lumix DMC-ZS50 Panasonic Lumix DMC-GM5 OM-1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +19 more
maggiemole Senior Member • Posts: 1,988
Panasonic 14-45mm. I keep it with my IR converted G1 because it's the only zoom I found which didn't produce hotspots, and it's a really good lens as well.
M
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
(unknown member) Veteran Member • Posts: 4,046
Re: Olympus 12-40
Makes the 12-40 an interesting buy at ~ $500 lightly used. Great lens for the money.
I rarely use the 50/2, and the OM 135 f/28 and 200 f/4 but can't give them up for when they are the perfect lens for the image. They made some of the best images I have.
3dwag
In addition to my “old” 12-40mm f/2.8 which I already mentioned above, 2 more lenses which are relatively “cheap” (considering what I could sell them for used now) and I will hardly use but keep include:
1.  Olympus 40-150mm f/4-5.6 R.  I haven’t used this since I got my 14-150mm f/4-5.6 Mark II, which is weathersealed, goes wider, and is not far off IQ-wise from the best of the 40-150 in its range.
2.  Olympus 14-150mm f/4-5.6 Mark II.  Now that I have the Olympus 12-100mm f/4, I have not used this lens once.  However, I expected that there will be times when that’s all I need and it is smaller and lighter, though not quite as wide.  The 100-150mm range does not exist on the 12-100mm, but on the other hand form what I’ve seen so far I can crop (or use the in-camera 2x DTC function) with at least similar of not better IQ.
UNDECIDED:  my Olympus 12-50mm.  I have mainly held on to it for the macro mode with my little Nikon slide duplicator accessory, and also its electric zoom Is handy for some video work.  However, I got the Olympus 30mm macro lens during the Black Friday sale and expect it to perform even better for copying slides, so the 12-50mm becomes even less relevant.  Still, it has the power zoom and it’s weather sealed...
3dwag
The 4/3 50mm f/2 Macro is the one lens I sometimes regret having sold, mainly because it is a true “reference lens” for the system (and I am a true geek).  I use my 60mm f/2.8 Macro far more and with greater satisfaction than I ever did my 50mm.
Henry Stamm Veteran Member • Posts: 3,553
Oly 4/3 14-35mm f2 and Oly 35-100mm f2
These are still in my bag and used frequently.  There simply are no micro 4/3 equivalent zooms to replace them (the f2.8 zooms don't attract me at all).  That said, I do have the PL 12-60.  It's a toss-up for me as to whether I use it more than I do my 14-35 f2.  I seem to go from one to another quite frequently.
 Henry Stamm's gear list:Henry Stamm's gear list
Olympus E-M1 II Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +8 more
ahaslett
That's an interesting way of looking at it.  My rarely used lenses tend to be used with greater satisfaction because they fit the task.  My 12-40 gives greater satisfaction overall because it gets used most but not always when it would be the absolute best lens for the job.  Mind you it's pretty good.
The 12-32 and 35-100 kit lenses get used quite a bit too and are never the best lens apart from being there and being unobtrusive.
Andrew
I can see why you did that. I don't shoot enough macro to own the 60 f/2,8, so I bought the 50 f/2 for about $50 a few years ago. For that cost I can own it for a few shots a year. I don't mind the slow focus. I love the rendering and I already owned the adaptor for use with the 50-200 f2.8-3.5.
I love the 12-32 on my PL-7. I think about buying a 12-40 with prices so appealing now, but I don't need the IQ or aperture enough to carry it.
Wow, that Tamron looks good!
YWG Senior Member • Posts: 1,364
Olympus 75mm F1.8 that I got in a batch buy of used m43 gear. Tried to negotiate the release of it from that sale but the owner said take it all or nothing. Turns out it has been very sharp and after some warming up, a longish portrait lens and good for picking people off at events in lower light like speaking at a podium. Had some okay results tracking some indoor sports too.
20mm F1.7 that I got with my GF-1 as a combo. Didn't like the GF-1 and eventually sold it off. Really like the compact lens and sharpness. Unfortunately, it seems to have gone missing on a business trip. The slow AF was annoying however so I haven't jumped at a replacement.
 YWG's gear list:YWG's gear list
Olympus Stylus 1s Canon PowerShot G5 X Olympus E-M1 Olympus E-M1 II
