What is wrong with my camera?
Started Dec 19, 2017 | Questions
isabellamariieee New Member • Posts: 1
Canon EOS Rebel T3
I have a camera that has been in the back of a closet for awhile now, but I recently grabbed it and noticed two dark, worm shaped spots. It does not appear on the view finder before I take a picture, but then it suddenly appears once I preview my shot on the LCD screen and once I upload them to my laptop. I've switched out lenses to rule out that it's definitely not the lens, but something internal of the camera body.
Forgive me, I'm a camera newbie, so I do not know what part of the camera is damaged. I am also curious on whether this is an issue that can be fixed, or if it's too much of an issue that is not worth the cost.
I've attached images to help explain the marks.
Help please!
#1
#2
#3
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50)
(unknown member) Forum Pro • Posts: 12,611
Re: What is wrong with my camera?
looks like you have 2 small hairs on your sensor.
Max Iso
Max Iso Veteran Member • Posts: 8,652
5
Looks like you need to clean your sensor.
 Max Iso's gear list:Max Iso's gear list
Nikon D300 Olympus E-M1 II Canon EOS M50 Canon EF 100mm f/2.0 USM Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
tkbslc Forum Pro • Posts: 17,523
6
That would be my diagnosis as well.   I would recommend using a rocket blower and the manual lens cleaning setting on your camera to clean them out.  A few hard puffs with the blower, and they should be gone.
Nickels Regular Member • Posts: 458
isabellamariieee wrote:
Canon EOS Rebel T3
Help please!
#1
#2
#3
Yup,what they said. Be more careful swapping lenses. I never leave the body "open" for more then a second. Plan the swap in advance,lay out lens caps etc first.
Clive50
Clive50 Contributing Member • Posts: 693
Not just the 2 hairs you also have dust specks in there to.
Take the cap off have have the lens opening facing down then use a puffer to blow air in there a few times. Don't blow with your mouth as thats damp air. I have some brush hair in my 600D which drops on the sensor every so often.
If all that fails take it for a clean at a camera shop.
 Clive50's gear list:Clive50's gear list
Canon EOS 600D Canon EOS 80D Canon EF 50mm F1.8 II Tamron AF 18-200mm F/3.5-6.3 XR Di II LD Aspherical (IF) Macro Tamron SP 150-600mm F5-6.3 Di VC USD +5 more
MikeJ9116 Veteran Member • Posts: 6,958
As others have said, you have a dirty sensor. Since you are a "camera newbie" take it to a camera shop for cleaning.  Also, as others have said, make sure to keep a body mount cap or lens on it at all time and minimize the time the lens mount is open to the elements.
Herb Senior Member • Posts: 1,085
Test to see all the stuff on your sensor
Take your camera with a lens attached and set the aperture to f16 or greater.  Aim the camera into the sky getting just a blue or white sky, stay away from the clouds as they just sometimes mask the dirt and grime.
After you take the photo, look at the photo and the black spots or the "worms" are stuff on your sensor.
Take the blower to get the easy stuff off and then run the test again.  You should notice a difference.  The stuff that wont come off needs more than just blowing to get them off.
If you are not comfortable cleaning the sensor yourself (look on YouTube as there are several tutorials) either take it to local camera shop to see if they can help or final option is Canon, but you should check costs first.
This isnt a disaster as everyone that has digital cameras with removable lenses experiences this....
Herb Turner
 Herb's gear list:Herb's gear list
Canon EOS 5DS R Canon EOS-1D X Mark II Canon EF 24mm f/1.4L II USM Canon EF 50mm F1.4 USM Canon EF 85mm F1.2L II USM +8 more
sludge21017
sludge21017 Veteran Member • Posts: 3,813
#3
The 1 worm blends in quite well there. I wouldn't have noticed.
RedFox88 Forum Pro • Posts: 30,738
dust on your image sensor. Get a rocket blower (handheld squeeze device ) and do it on your sensor while in sensor clean mode. That should do it. No need to pay a store $40 to do the same thing!
deanimator Contributing Member • Posts: 719
I went through the same thing a couple of months ago with my used T4i.
I do mostly macrophotography at 1:1 or greater.  As I started to increase the magnification while experimenting with equipment, I started noticing streaks in my focus stacks.
I thought it was movement, but people on another forum explained to me that it was dirt on the sensor.
Unfortunately, the Cleveland, Oho area isn't the best for serious photography gear and accessories, so I had to make do with inferior cleaning products until the good stuff arrived from Amazon.
I highly advise you to get the best stuff you can afford, since trying to clean my sensor with the cheap (and only) stuff available at my local camera stores was an exercise in frustration.  I was literally just moving the contaminants around.  I went through almost a complete pack of cheap swabs without eliminating the spots.
When my good fluid, swabs and blower arrived, I had the sensor clean with the use of only two good swabs.
Following directions on forums and in YouTube, you can clean your own sensor.  Just make sure you buy the good stuff.  Otherwise, you'll accomplish little besides getting frustrated.
A tip:
As noted, you can take a picture of the sky or a piece of blank paper to see the spots on the sensor.  However a lot of instructions leave out a step.  If you just look at that image, it's hard to see the dirt.  If however you run the image through something like Elements and invert the colors, the dirt leaps out in the picture.  I think the command in Elements is F12, but don't remember for sure.
R2D2 Forum Pro • Posts: 26,551
deanimator wrote:
A tip:
+1 Set a small aperture like f/22 (and don't overexpose).
Then do an "Auto Contrast."  (or increase contrast greatly yourself).
If you haven't cleaned your sensor in a while, plan to get ill.
From another macro shooter,
R2
R2D2 wrote:
deanimator wrote:
A tip:
R2
I bought my T4i used from Adorama.
While it was just about mechanically perfect, as I discovered later, the sensor was FILTHY.  I probably never would have noticed if I didn't do focus stacking at greater than 1:1.
