Telephoto for landscapes - 40-150mm f2.8 or something else?
Started Dec 18, 2017 | Discussions
(unknown member) Veteran Member • Posts: 4,046
Re: Telephoto for landscapes - 40-150mm f2.8 or something else?
Andy, in an update to previous comments....
I carefully tested the 40-150 PRO with the 1.4X TC against the 75-300 this morning by setting the FL of the 75-300 to 200mm.
I let the camera choose shutter speed, and aperture with the ISO fixed at 200 and no filter on either camera.
As expected, the 40-150 shot 1/500 and f/7.1 while the 75-300 shot 1/250 at f/8. I have to say the sky was a bit brighter when I took the photo with the 75-300 30 minutes to an hour later. One stop maybe? That would drop the shutter on the 75-300 image to maybe 1/160 and the aperture to f/7.1 - just a guess Andy. I can't measure the amount of light. I shot homes 3.5 miles across a lake with mountains another 60-70 miles behind the homes, a good example of a long FL compressed landscape with the homes more in focus than mountains.  Need focus stacking to focus both and don't have it. I viewed the homes at 100% crop to test the lenses.
I knew what the approximate difference in aperture and shutter speed would be. I expected the PRO lens to be sharper.
More light might have helped the 75-300, however inspecting the images at 100% zoom, I found so little difference in sharpness I don't think anybody could see it without 100% cropping. That surprised me. I can't honestly say the PRO lens is sharper at its extreme FL with the 1.4X TC compared with the middle of the 75-300 range. I've observed slightly sharper images with the PRO lens when the TC is not used. It isn't enough to make me want to leave it off. The images are detailed enough for me with the TC and with the 75-300.
I do notice the PRO lens seems to control glare better, but it did have less of it to contend with. In equal light or with a CPL I may not see a difference, but keep in mind the difference in the amount of light showed up as f/7.1 to f/8 with the 75-300 choosing f/8 and the shutter difference of 1/250 to 1/500. I'm not sure if this difference in light tilts sharpness to the 75-300. I expected the PRO lens to be significantly sharper. It isn't.
What I am sure of, is compared to the cost and results, the 75-300 hits above its weight class at MSRP $550. I think its an underrated lens. I paid $350 on the OLY refurbish page for this lens I consider to be as-new. I think these are demo lenses, not sold to the public and returned for refurbishing. Keep in mind the 75-300 is not weather sealed. I wouldn't take it out in rain or snow. It is much smaller and half the weight.
I didn't test the 14-150 which I also have, but I used this lens a lot in the summer, and I am surprised at the quality of the images I have from it, even though its a 10X plus lens. Some images are close enough in quality to the 75-300 that I can't say the bigger lens is much better, if better.
From this decidedly unscientific, but real world test, I conclude, at least for myself, that as long as I can keep the ISO down, I am happy with the images from any of these three lenses, so the only time I need the PRO lens is when ISO rises above 400, maybe to 640 using the 14-300 or 75-300.
I do a lot of motorsports photography. In that world, I pan a lot at shutter speeds between 1/80 and 1/160, so keeping the ISO as base is no problem. The problem can be preventing the lens from stopping down past f/11 in bright sun where I might encounter diffraction.
When a car is pointing at me off a corner or down the straight, I like 1/250 - 1/800 depending on distance and speed of the car, and angle to the camera. In gloomy weather, fog, shade I like to shoot in, this is where I need the PRO lens to keep the ISO at 200. I do not shoot in these conditions that much, but it results in compelling images with no hot spots on the cars, and limited shadows to bring the image to a dynamic range the sensor can manage, so even for a few shots a day, owning the PRO lens is worth it for me.
I know the specs and consult the lab test data, but for me, a decision is only valid if its made using results in conditions I shoot in. I suggest you take this into consideration before buying more lenses. If you look at the photos you've taken, it will show you how often you need PRO glass to keep the ISO down to 200, 400, whatever you think is acceptable.
I would be willing to bet, as long as you can shoot the same ISO with all three lenses, the delta in IQ, all other things being equal, you will not see enough difference between them to justify spending $1,850 for the PRO lens and the TC. Maybe at 100% crop. Maybe not. It then becomes a decision of the additional cost for those shots where the ISO rises to 800+ if it does make a difference that matters to you. Only you can know this by reviewing the images you saved.
When you hike, you will appreciate a 10-13oz lens in your pack, rather than a bigger 1.67lbs lens and a 6oz TC to hump around with.
I know I'm running the risk here of emotional responses, maybe outrage for suggesting the lab tests and the quality and cost of the PRO lens suggests I am wrong about this, or the "consumer grade" lenses really are better than the test data and price suggests.
Either may be true. I can only tell you my experience with these lenses. Your experience may lead you and anybody else to a different conclusion which for me, is inside the light window of the 14-150 and 75-300, when you can keep the ISO at 200-400, maybe a little more, for monitors and prints, you will probably do just as well with the consumer grade lenses as the PRO lens, and you can buy both of them for less than $1,000 if you shop. The 40-150 PRO is an MSRP$1,500 lens vs. $1,150 for both of the other lenses and they cover a bigger range - 14-300mm vs. 40-210 with a $350 TC = $1,850 MSRP.
I bought the PRO lens because I need it for the FL in low light. You may not need it. You may do just as well without it. My test is not scientific, but for me its valid because its actual photography in light I shoot in, and a composition I shoot as a real world test. This is my suggestion to you. Look at the data on the images you have, to decide if you need f/2.8-4 glass and how often.
For what its worth, here are the test images. Took them in RAW, converted with OLY viewer 3, sharpened a little. I played around with color a little so ignore that. I suggest you just look at sharpness and control of glare in crops. Glare is controllable with a CPL filter. For me, the image taken with the 75-300 without cropping, is for all my intents and purposes just as good as the PRO image. The 75-300 gives you another 180mm of reach if you need it. I could take a better photo of an individual house with the 75-300 because I wouldn't have to crop as much and the sharpness between the two lenses is pretty close at these apertures in this light, though the 75-300 might be as sharp at 300mm as it is at 200mm.
The homes are 3.5 miles away per GOOGLE maps. I probably shouldn't have played around with the color. Too late for that. You can see one image had more light. The sun had risen more and is reflecting off the water in front of the homes. This may account for 100% of the difference in glare and increase the difference in shutter speed and aperture. I think they are pretty similar in conditions and result. I am just as satisfied with the image made with the 75-300 as I am with the PRO lens - for $950 lower MSRP. I hope this is useful. It was for me. Without the glare off the water, the camera setting would have been probably a stop further apart, but the image quality may have been dead even.
prymsnap Regular Member • Posts: 316
Re: Lofots...
Jouko wrote:
The other way to go is the old (and used) D.Zuiko 50-200mm f2.8-3.5 SWD. Get also the older TC14. Works fast on Em1, but not as fast as the 40-150 mm Pro. More reach, weatherproof. Also heavy and large, but not too much compared to 40-150 mm lens.
The SWD-version is the mkII of that lens and has a faster focus system. Solid performer.
PS. If you buy the 50-200, do the focus adjustment before the trip and test the fine tuning... Mine needed some -3 setting, and a bit more with the TC. Easily done, but needs a tripod.
Jouko
'The best camera in the world is the one you have with you when you need it'
https://www.instagram.com/jouko.k.lehto/
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
https://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
https://joukolehto.blogspot.fi/2015/12/what-to-dowith-camera-during-winter.html
May I ask what adjustment method you used for this combination of body/lens/adapter? Thanks in advance.
 prymsnap's gear list:prymsnap's gear list
Olympus OM-D E-M10 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Olympus M.Zuiko Digital ED 75mm F1.8 Rokinon 7.5mm F3.5 UMC Fisheye CS Olympus 12-40mm F2.8 Pro +9 more
ahaslett
ahaslett Forum Pro • Posts: 12,654
Re: Lofots...
Jouko
The EM1 manual describes how to do micro focus adjustment.  You need to register the lens and the lens plus EC14 separately.  I agree it's worth doing.  All my old FT lenses need a small amount of adjustment.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Re: Lofots...
ahaslett wrote:
prymsnap wrote:
Andrew
Thank you!
Photo Pete Veteran Member • Posts: 5,430
Controlled test at 150mm of 14-150, 70-300 and 40-150 pro here:
https://www.dpreview.com/forums/post/57547600
70-300 is pretty good at 150mm. The 40-150 is better and gives excellent results 2 stops wider too.
what isn’t stated in my test is that the 40-150 with 2x teleconverter tends to give me better results for sports and action than using the 70-300 over 200mm. Partly this is due to having an extra stop of light available, partly due to optical quality and partly due to the 40-150 having faster autofocus.
personally I think that, if you can accept the weight and size, the 40-159 pro is worth every penny of its price premium over the 14-150 and 70-300.
Have Fun
Photo Pete
I feel from personal experience in the field, all three are quality lenses. I think it comes down to the amount of light you have to work with. In good light, that is as long as you can keep the ISO the same for all of them, I'm finding the difference between the results is not worth debating, that even side by side they look similar, and not side my side I doubt if anybody could say which lens made the image.
For me it comes down to a matter of conditions. I would not take the 75-300 in the rain or the snow. The 14-150 won't make as good an image at ISO 800 as the 40-150 PRO will at ISO 200 - if you want the best chance of getting the shot under adverse conditions, you have to have the 40-150 PRO. That's why I own it.
In good light, and dry conditions, I'd rather carry the 14-150, crop a little if I have to and/or the 75-300. Both of them combined weigh less than the 40-150 PRO and the TC and cover a bigger range.
The original post discusses hiking and shows images of snow. That makes it a little problematic. On a long mountain hike, 5 miles or more I can feel another pound in the pack and held to my face. In snow, I'd have to be careful with the 75-300 but I prefer to travel light.
I'd carry the 14-150 and a bright prime, probably the 17 f/.28 because its fast enough, pancake, relatively inexpensive and weighs nothing or splurge on the 17 f/1.8.
I like carrying a fisheye. The Rokinon works well for me cropped to rectilinear, or de-fished.
Now that I'm putting more and more gear in the pack, I appreciate dropping one pound by leaving the 40-150 PRO an the TC home. I feel it in the pack.
I take the 40-150 PRO and TC only if I am pretty confidence I need it. The 14-150 is a lot slower but I can usually get a good photo with a slower shutter speed. There is also HDR if you can steady the camera.
For me its a decision between weight and the need for f/2.8 because optically, on an M43 camera all three lenses make good images. I think, the skill of the photographer and the time / location / composition are more important than the choice between these three lenses unless you are shooting in light and conditions that force the ISO up to 800 and more and you need all the detail you can get.
Gary from Seattle Veteran Member • Posts: 7,852
MShot wrote:
If you compose something close you don't need long. If you go someplace like the Palouse where you can forever, I find 150mm - even 300mm very useful. (300-600).
That may be, I've never shot there; but that is not hiking/backcountry skiing where weight is important. When I go out hiking which is probably 70 times a year I make a conscience decision which of my lenses I'll bring along. some hikes are just exercise or I've done them too many times for them to be interesting on a mid-day hike. In those cases I may not carry a camera at all. On many hikes, knowing what is available to photograph, I will sometimes carry just my 12-40 - the same on most backcountry skiing trips if I expect the scenery and lighting to warrant a camera. On others, particularly in the North Cascades, or in the Canadian Rockies or Purcells, or near Mt. Rainier I may choose to add my 35-100 F2.8. This is mostly for glacier detail or detail of spectacular rock formations. On overnights (and a few day hikes) in the mountains where scenes are good I may add the 8mm F1.8 FE - also for rain forests or ocean sea shore scenes. The 8mm F1.8 FE because of it's aperture is very good for astro/landscape. I think the 75-300 is a very good choice for hiking and photographing wildlife. But there are few hikes where I am likely to encounter significant wildlife and so that lens usually stays at home; but gets used when shooting birds in lowland birding areas - again not on most hikes.
I need 420mm to photograph the Olympic Mountains beyond Lake Washington from my house in Kirkland without cropping. I use it on the Puget Sound. Depends on the kind of landscape you are photographing, where it is, how you want to compose it.
While I agree with your last sentence, for me it is clear there are very few hikes and no ski tours where I would carry the somewhat larger 75-300. As to photographing the Olympics from the greater Puget Sound area, that again is not hiking - at least not of consequence.
More landscapes are photographed with a long telephoto than you think.
That is not my experience in the mountain ranges I visit - the Cascades, Olympics, Purcells, Canadian Rockies, Tetons, Wind Rivers, and Sierra Nevada. I am usually in the range of 12-40 mm with quite a few shots in the 15mm to 40mm range and a much smaller set of outliers to 65 to 80mm and with the 8mm, and with a yet much far fewer set of shots beyond 80mm and a few extending to 300mm on the occasions when I carry the 75-300.
I would note that although many shots are not at their best below 15mm, Most days I might shoot at 12mm once or twice, so I would encourage the OP to consider the 12-40 over the 14-140. 8mm or 12mm shots are definitely something I would shoot more commonly in desert scenes with wide open spaces and a huge sky or in seascapes - which I rarely shoot. I ordinarily use the 8mm or 12mm perhaps to 14mm or 15mm for astro/landscape. Except for these uses one does not ordinarily need a fast lens and that is with a tripod. So something like a 17mm F1.8 would, for me, just be an optional lens for tripod use in shooting the MW.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
Pete_W
Pete_W Senior Member • Posts: 2,838
Re: 45-150 Panasonic?
hindesite wrote:
I'm a bit surprised nobody has mentioned the Lumix 45-150; I have it and the m.Zuiko 40-150 4/5.6 and prefer the Lumix.
Neither is expensive, both are small and light, and you don't need 2.8 for landscape.
I have this lens also - it is great! So small, light and great quality. And so inexpensive.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
Yes, I’ve still got my 75-300 in case I need to travel very light with a long telephoto. Quality is really very good for its price, range and size.  To be honest though, my main kit is finding its way in to my bag most of the time now and the 75-300 is getting very little use.
I pretty much always pack my Em1 mkii,  7-14 f2.8, 12-100 f4 and 40-150 f2.8 with 1.4 TC. The weight in a Billingham Hadley Pro is comfortable for an all day shoot (and that is for someone who had back problems which were part of the reason I moved from Nikon a few years ago). In a backpack I hardly notice it.
One of the big changes was removing the tripod foot from the 40-150 and replacing it with the Olympus ‘beauty ring’. It makes the 40-150 seem like a much smaller and lighter lens.
I was really never happy with the 14-150 though. Edge and corner performance was very poor on my copy.
Have Fun
Photo Pete
SunsetBk Contributing Member • Posts: 507
andybryant wrote:
I've been a super wide landscape devotee for years, but I'm just now starting to discover the value of a telephoto to isolate subjects & compress distance, as a tool for landscape photography.
At the moment I'm using the super tiny Panasonic Lumix 35-100 f4-5.6 , which is awesome for hiking, but it isn't as long as I would like; and I'm sure that on my EM-1 MkII, I could benefit from a sharper/longer lens.
I'm very tempted by the Olympus 40-150 f2.8 and the 1.4x teleconverter to stretch it to 210mm, but the price is huge.
I expect that at some point I'll want to do more wildlife, sports and action, but for the moment most of my needs are landscape. So for the moment I don't really need the f2.8.
Is there an alternative in the 40-150 / 45-200 range that I should be considering?
My next trip will be Lofoten & Senja in Feb...
Andy.
+1 for the Olympus 40-150 plastic.  For landscapes at f8 on a micro four thirds sensor I doubt there is a world of difference with the pro version.
 SunsetBk's gear list:SunsetBk's gear list
Sony a7R III Voigtlander 15mm F4.5 Super Wide Heliar Sony FE 55mm F1.8 Tamron 17-28mm F2.8 Di III RXD Sony FE 135mm F1.8 GM +3 more
sonnycsc Regular Member • Posts: 323
The 40-150 Pro, despite being built like a tank, isn’t really as heavy as you might think. I rented it once for a few days to use on my E-M10 II, and with the hood off it didn’t feel as unwieldy as I thought it would. Wish I could’ve shot more with it, I loved how it handled and the internal zooming, nothing to say about its optics which are just awesome.
But until I could afford the Pro, I went with the Panasonic 45-175, mostly because it’s an Internal zoom. But it’s damn well built, and optically it’s surprisingly good. I have lots of fun with it when I shoot landscape. It’s light and compact but I probably wouldn’t recommend it for cold temperature environments.
These are OOC Jpegs.
www.500px.com/rmimagery
 sonnycsc's gear list:sonnycsc's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Olympus M.Zuiko Digital ED 75mm F1.8 Olympus M.Zuiko Digital 17mm F1.8
Andy.
Probably right. But it sure is nice only needing to stop down to get more dof rather than as a necessity to get top notch image quality....  and even nicer not having to think about packing up when it starts raining.
Whether that is enough to offset the extra cost, size and weight of the 40-150 pro is a very individual decision.
Have Fun
Photo Pete
I like the Rokinon 7.5 fisheye and 12mm f/2 when I want to go wide or bright/wide. If I go to the Palouse where you can see forever, I want a lens as long as I can get. The benefits of compression, shooting landscapes with a long lens from a distance are well known.
You can make towering mountains in the distance look much closer to the foreground than they are. It that makes them look much more impressive in the places where you go. You can bring an interesting composition to you that you might not be able to reach on your hike. You don't; have to have a long lens but its good to have one. In a place where I know I don't need one, I'll take a PM 1 or 2 with the 17mm f/2.8 prime on it because its so small and light and the IQ is good. I don't see the need for f/1.8 enough to buy one.
If you look at the photos posted by the OLY visionaries you see they take long lenses with them, even the 300mm f/4 and not just for wildlife. That's too heavy for me so I take the 75-300.
andybryant
OP andybryant Regular Member • Posts: 122
Thanks for the extensive recommendations & discussion.
I considered the lower cost 40-150, which by all accounts has earned the title of plastic fantastic (ref the great Canon 50mm), but felt the need to go a bit longer, plus for something a little more substantial.
I rejected the Pro 45-150 on weight and cost grounds. If I bought this, I would use it in the city, and on 'van' type tours, but I don't think I would often take it into the mountains hiking (especially as I would probably also want to take the teleconverter.)
I ended up selecting the Olympus 75-300 ii, for the mid range weight and longer focal length. It's a bit heavy for multi-day trips, but for an overnight or day hike, quite reasonable, given the potential 600 mm effective focal length.
At the moment it is available in the UK for £349, less £85 Panasonic cashback, which at £264 seemed like a pretty good deal.
I bought it from Jessops with a price match against Castle Cameras.
If the Panasonic 50-200 appears later in the year with a lower weight and size than the Oly Pro, I might sell the 75-300 (probably for not much less than I paid for it).
Andy
 andybryant's gear list:andybryant's gear list
Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus E-M1 II +8 more
I agree about the 14-150 corners, don't take it when that matters. Its useful as a one lens travel solution when I don't expect to see anything important, am not on a photography shoot, but sometimes it surprises me with a good image. No choice for IQ, it doesn't make bad images, just a lot of average ones. It is nice to have something with this range I can shoot in the rain.
I agree in my experience, not enough to matter as long as you can shoot the same ISO. When you have to run up the ISO is does matter.
Very nice images. I can think of places where the extra 25mm over a 40-150 would be useful.
