Can the Olympus TG5 take a dome lens, using a converter?
Started Dec 17, 2017 | Discussions
alexnapierholland
alexnapierholland Junior Member • Posts: 49
Hey, I'm very close to buying an Olympus TG5 and matching fisheye lens, for shallow freedive and surf photography.
I'm also interested in fitting a dome directly to the camera, for over/under shots.
I have no interest in the Olympus housing, as the whole appeal of the TG5 is I can grab it and jump-in. I'll mess about with housings and o-rings for a M43 or DSLR, later.
Can I fit a dome by another manufacturer to the Olympus TG5's 40.5mm mount, using a converter?
For example, here is an 'Intova Wide Angle Lens IAL Air Lens Correction Dome', which requires a 46mm mount.
And here is a 40.5mm to 46mm converter.
Would this work?
And either way, would other domes potentially attach to the 40.5mm mount on the Olympus TG, either with or without a converter?
 alexnapierholland's gear list:alexnapierholland's gear list
Olympus TG-5 Panasonic G85 GoPro Hero (2018) Apple iPhone 6 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
Vie New Member • Posts: 2
Re: Can the Olympus TG5 take a dome lens, using a converter?
Hi Alex,
I was wondering the same. Did you purchase the adapter and dome and tried it out?
alexnapierholland
OP alexnapierholland Junior Member • Posts: 49
Vie wrote:
Hi Alex,
Nope! But Ikelite recently launched the DC1 dome for their TG-5 housing that can - allegedly - do split shots!
I write sales copy for top technology and adventure brands.
Thats a pity. Recently got this set from amazon:
https://www.amazon.com/Seafrogs-Waterproof-Olympus-Underwater-Pictures-Black/dp/B07H32PLJM
It works for split levels as well and it is reasonably priced. However, I would prefer to use the dome without the housing for some quick snorkeling shots. Will see if I can find an 40.5 to 67mm adapter and try it out myself.
LarsPolarBear
LarsPolarBear Contributing Member • Posts: 585
just made some suggestions here:
https://www.dpreview.com/forums/post/62892224
Hope that helps...
Lars
PS:  AOI is the OEM for the original Olympus housing, they started not too long ago to sell directly (through local distributors) to the general public.
