Cheap Flash for a D100
Started Dec 16, 2017 | Discussions
10Dman Regular Member • Posts: 318
I'm looking for a cheap flash for my wife'd D100. I've seen a few on Amazon for under $50. Any recommendations?  Here are 2 options?  Please provide links of better options.
$33.99
Neewer TT560 Flash Speedlite for Canon Nikon Panasonic Olympus Pentax and Other DSLR Cameras,Digital Cameras with Standard Hot Shoe
https://www.amazon.com/Neewer-Speedlite-Panasonic-Cameras%EF%BC%8CDigital-Standard/dp/B004LEAYXY/ref=sr_1_6?s=photo&ie=UTF8&qid=1513399546&sr=1-6&keywords=nikon+Flash
... or maybe this one?
$65.98
YONGNUO YN560 IV Wireless Flash Speedlite Master + Slave Flash + Built-in Trigger System for Canon Nikon Pentax Olympus Fujifilm Panasonic Digital Cameras
https://www.amazon.com/IV-Wireless-Speedlite-Fujifilm-Panasonic/dp/B00PGTOX26/ref=sr_1_2?ie=UTF8&qid=1513399578&sr=8-2&keywords=nikon+flash+yongnuo
Nikon D100
OP 10Dman Regular Member • Posts: 318
Re: Cheap Flash for a D100
bump..... any ideas?
Horoscope Fish
Horoscope Fish Senior Member • Posts: 1,180
$33.99
$65.98
Both of those flashes will work with your D100 but they don't support TTL, so you'll be adjusting the flash output manually with either one. If that's what you want then that's fine, just pointing it out. I use several Yongnuo flashes and I like them a lot.
If you want something that's TTL capable, consider a Yongnuo 565EX instead.
 Horoscope Fish's gear list:Horoscope Fish's gear list
Nikon D850 Sigma 50mm F1.4 DG HSM | A Nikon AF-S 70-200mm F2.8E FL ED VR Sigma 135mm F1.8 Art Tamron SP 24-70mm F2.8 G2
kli
kli Veteran Member • Posts: 4,591
+1 No TTL, no HSS/FP.  Limited usage.  Better if you plan to use the flash off-camera for portrait studio-lighting setups, strobist style.  But for on-camera bouncing and run'n'gun event/social shooting, not a great choice.  (See this answer I wrote on stackexchange about what flash features mean in practical shooting terms).
If this is a first/only flash, I highly advocate getting a TTL full-sized speedlight with 360º swivel. You can always turn TTL off on a TTL flash, but a manual-only flash cannot have TTL added.
Flash can be far more transformative to your photography than a lens. Budgeting accordingly is not stupid.
And even if you still decide to go off-camera manual-only, there is a much better choice that costs the same ($65): the Godox TT600. It's better because a) it's got a radio trigger built in and b) it can do HSS over that radio trigger: neither of the others can. And c) it's in the Godox system.
Actually, I'd say consider a $110 Godox TT685-N.  The YN-565EX can't do HSS (you need a YN-568 for that), and has no built-in radio triggering.  The TT685-N has both, and can do quite a bit more.
Because Godox has created an integrated lighting system, while Yongnuo hasn't.
Even a year ago, Yongnuo flashes were a default low-cost hobbyist recommendation for flashes, but this year, Godox rolled out TTL/HSS support for mirrorless as well as Canon/Nikon (so if you add mirrorless or swap to it, you don't have to rebuy your off-camera lights, just your on-camera transmitter).  And the Godox gear can autoswitch between all five systems (Canon/Nikon/Sony/MFT/Fuji) over radio. Yongnuo TTL/HSS gear only comes in Canon and Nikon flavors and can't be used cross-brand in any way.
With Godox all the speedlights have built-in radio transceivers and can be master or slave in the system. The manual-only flashes can do HSS over radio. And both the manual-only and TTL lights can be controlled from the same transmitter. If that transmitter does TTL, you'll have TTL with the lights that can do it.
Compare that with the Yongnuo system where the only way to get the 560/60x manual gear and the 622  or -RT TTL-capable gear to work together is to put the TTL gear into "603" manual mode, where it will act like it's 560/60x gear. And all that TTL/HSS functionality you paid extra ford isn't usable.  And if you use a YN-622 on camera, and YN-685 slaves, you have no way of putting a speedlight on-camera other than to sandwich a YN-622 transceiver between the flash and the camera hotshoe.  The Godox TT685, otoh, can be an RF master by itself. No stacking required.
And if you decide you need bigger lights than speedlights, Godox offers bare bulb flashes and studio strobes (both corded and cordless).  Yongnuo mostly just offers speedlights.
And finally, Adorama has rebranded the Godox X system gear as Flashpoint R2 gear. Which means if you purchase from them, they'll supply the Godox customer support. And it's easier to deal with a retailer in NYC than it is the manufacturer in China. Yongnuo? You don't get the choice: you're dealing with a company in Shenzhen.
There were reasons to get Yongnuo. But today, I'd say there are more reasons to go Godox.
 kli's gear list:kli's gear list
Fujifilm X100T Canon EOS 5D Mark II Canon EOS 50D Panasonic Lumix DMC-GX7 Canon EF 135mm F2L USM +12 more
Mike H Contributing Member • Posts: 976
Nikon SB 80-DX I had one for my D100 nice unit wasnt expensive,
KEH has used ones from $99 to 120.
 Mike H's gear list:Mike H's gear list
Nikon D500 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 55-300mm f/4.5-5.6G ED VR Sigma 10-20mm F3.5 EX DC HSM Nikon AF-Nikkor 80-200mm f/2.8D ED +2 more
lightandaprayer Veteran Member • Posts: 5,388
Nikon SB 26, Metz "potato masher" or shoe-mount with auto aperture and a built-in sensor. There are other brands as well. . . (Check sync voltage online for questionable strobes. . .) Cheap on eBay and more accurate than TTL in some circumstances. I use old Nikon and Metz strobes with my D200.
Use the flash ISO setting to get the output within 1/3 stop. Works great for fill-flash.
Chuck Yadmark
Chuck Yadmark Veteran Member • Posts: 5,127
D-TTL of the D100, D1/h/x was a dead end flash metering system, not as good as iTTL by a lot.
having said that there's a ton of SB50dx, SB80dx, SB28dx D-TTL flashes used for very little as mind as you realize it's not going to be very good on iTTL cameras.
Ann Arbor, MI USA
www.sportsshooter.com/cyadmark
 Chuck Yadmark's gear list:Chuck Yadmark's gear list
Nikon D4S Nikon D500 Nikon Z6 Nikon Z50 Sony E 10-18mm F4 OSS +24 more
n057 Veteran Member • Posts: 8,769
I have a bunch of SB-15, and those can be had very cheap on Ebay. They are not iTTL, but you can use them by setting the camera to full manual as in a studio. You can also use the built-in calculator to determine the aperture and distance. But also, since the SB-15 has a photocell, you can set the camera to A mode and within the indicated range, the photocell and thyristor will do their magic.
JC
Some cameras, some lenses, some computers
 n057's gear list:n057's gear list
Nikon Coolpix 995 Nikon D200 Nikon D500 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S DX Nikkor 35mm F1.8G +7 more
