Re: A few shots on the streets of Hermosillo
xpatUSA wrote:
xfajardo wrote:
xpatUSA wrote:
richard stone wrote:
The older DP series cameras used (I think) a sensor not too different from the one in the SD10. Excellent color and not much edge-roll-off, just sharp three color per-pixel definition.
Yes, they had the DP13 sensor - same as the SD14/15 cameras but with different micro-lenses and a built-in UV/IR blocking filter.
In theory the sdQ on lo-res should behave somewhat similarly, but, in terms of reality I'm not so sure about that.
Nobody knows for sure (meaning no Sigma references) how they do that.
You would think that they use pixel-binning 2x2 on the top layer and pre-Quattro raw conversion but that has yet to be proven to me.
Oh my, I didn't quite understood anything
Xavier una vez más:
It all depends on what is meant by "not too different" ...
For example, the DP1s and SD10 sensors are the same size (20.7 x 13.8mm) and both have three layers.
But they have a different number of pixels, different fill factors, different micro-lenses, different firmware, different UV/IR blocking filters, different raw-to-color conversion multipliers and . . different sensor part numbers and data sheets.
Are they "not too different" or are they just "different"?
P.S. For "pixel-binning", please see: http://www.foveon.com/article.php?a=71
Ted
I know you're right on the technical aspects.
I just remember, years ago, looking at the same scenes shot with the SD10 and then the SD15, comparing the detail in each image and the result was, as I saw it at the time...not much difference. If any really. I know the pixels on the SD15 are "better," compared to the SD10, but there are not that many more of them. At the time I had been reading Norman Koren's site on a regular basis, and his wish, as expressed on that site was for a Foveon sensor with many more pixels. Meaning enough to easily see a difference.
That's one reason why I just stuck with the SD10. My current sense of the SD10 is that it works great in daylight and with good flash, but it produces some odd results in certain lighting situations. I was using the SD10 last year or so, with good results: Vibrant colors, excellent crisp details.
In any event, the SD15 is, in the end, as I see it, only slightly different in terms of results, but probably a lot easier to use, and more versatile.
I know that the DP series using that (SD15 type) sensor produces some great images too.
Richard
