T6I vs SL2
Started Dec 15, 2017 | Discussions
ZedDoctor
ZedDoctor Contributing Member • Posts: 894
T6I vs SL2
Current Fuji user looking to add a different brand. Will be getting some glass from a friend
Mostly portrait and car photography. Occasional trains here and there.
Local store has T6I with 18-135 kit for $50 more than SL2 with 18-55.
Thoughts? Recommendations?
"And so my fellow Americans, ask not what your country can do for you, ask what you can do for your country." - JFK
 ZedDoctor's gear list:ZedDoctor's gear list
Fujifilm X100V
CPFan
CPFan Regular Member • Posts: 202
Re: T6I vs SL2
As a former train picture-taker, I vote for the 18-135 lens.  However, I do not know what other glass you are getting.
In the film era I used an 80-200mm lens nearly all the time for train photos.  The 18-135 is approx equivalent to 28-216mm.  Admittedly, today my two main bodies usually have an 18-250mm and 55-250mm lenses mounted.  So I'm a telephoto type guy.
Steve
 CPFan's gear list:CPFan's gear list
Canon PowerShot SD600 Canon PowerShot S5 IS Canon PowerShot SX210 IS Sony Cyber-shot DSC-QX10 Canon PowerShot SX620 HS +8 more
MikeJ9116 Veteran Member • Posts: 6,958
Re: T6I vs SL2
First, make sure the 18-135 is the STM version.  Since you don't seem to have a need for telephoto range regarding what you shoot, I would look into the SL2 with kit lens and add the EF 50mm STM for portraits.  It will give you much better control over depth of field and is just a great lens all around.  The new EF-S 18-55mm STM lens is excellent being very sharp and delivers very good IQ.  This way you get the added benefits of Canon's latest APS-C sensor and Digic processor.  You might find the better low ISO DR useful and high ISO noise performance over the T6i.
Selene Senior Member • Posts: 1,308
Re: T6I vs SL2
This is my own personal opinion, but I think the IQ on the Sl2 is much better than t6i using the same lenses.  I do like the 18-135 STM lens, but it is sharper with the Sl2. I do realize I might have gotten a bad copy of the T6i.
ZedDoctor
OP ZedDoctor Contributing Member • Posts: 894
Re: T6I vs SL2
Can anyone make a suggestion or two on lenses to get for this.
My friend gave me his 10-18 IS STM, 24 2.8 STM, and 50 1.8 STM.
Do you think that the 24-105 f4 L would be too much for it?
Fujifilm X100V
Re: T6I vs SL2
You have a very good friend as those are all excellent lenses.
IMO, the 24mm end isn't wide enough for an APS-C camera. I have the EF 24-105mmL that I use on a 6D and also have the SL2 with the EF-S 18-55mm STM f/4.0-5.6 kit lens. I think the kit lens is very close in IQ to the 24-105mm lens. It is sharper, IMO, than the 24-105L and is a better fit with the SL2. It keeps the combination small and lightweight. I suggest getting the SL2 with the kit lens and see how it works out. I have the 10-18mm, 18-55mm and the 55-250mm STM (for an equivalent range of 16-400mm) and find this to be a wonderful compliment of zooms. Plus, all these lenses are small and lightweight. Many compare the 55-250mm STM to the EF 70-200 f/4 IS for IQ.
Re: T6I vs SL2
Those are terrific lenses to have with it. The 24-105L works well with it, especially if you think you might go to full frame some day.  I actually like the 18-135 on it better because of the additional reach at both ends and the fact that it is so much lighter.  It's a lens that will work nicely with the10-18. I also like the 70-300 USM lens. It is also pretty inexpensive right now.  But the 24-105 does do work well with it. (It was actually using the 24-105 on both the sl2 and the T6i that made me think the Sl2 had much better IQ. Whatever you get, you should enjoy the camera.
onlooker Veteran Member • Posts: 4,002
Consider the weight of the lenses
Consider the weight of the lenses if you carry the camera around. 18-135 with SL2 will be nose heavy. It ceases to be fun after a while. 24-105L is a nice lens, but it's even heavier. I would not consider it. I used to walk around with 6D and that lens, and I found that combination to be nose heavy, let alone with SL2.
Check if that 18-55 is STM. They have good reputation and are light.
Lepewhi Senior Member • Posts: 2,105
Re: T6I vs SL2
The SL2 comes in white; )))
Seriously, I think if you want to do a lot of sport photography, you might want to go for the T6i, more focus points.  If you do more travel photography, go for the SL2, smaller lighter.  I think the sensors are similar, if not the same.  So, images should be the same.  Just depends on what your interests are.
Slippery when wet.
 Lepewhi's gear list:Lepewhi's gear list
Panasonic Lumix DC-GX9 Panasonic Lumix DC-G100
Re: T6I vs SL2
The sensors aren't the same or the image processor.  They each have 24mp but the SL2 has Canon's current on-chip ADC design which provides better dynamic range and lower noise at higher ISO.  Plus, the processor in the SL2 is Digic 7, Canon's latest.  Also, the SL2 has much better live view performance and comes with PDAF for butter smooth AF performance in video and faster live view auto focus.
R2D2 Forum Pro • Posts: 26,551
Re: T6I vs SL2
I would lean toward the SL2.  Primarily for the excellent Dual Pixel Autofocus which will give you outstanding Live View AF, as well as rock solid Video AF (if that's your thing).
Phase Detect (viewfinder) AF will be very close between the two, even though the difference looks big on paper.  Very similar controls.  SL2 is physically smaller.
The two cameras really are pretty close except for the guts (love the SL2's guts  ).
If you really prefer the T6i's form factor and features, then I'd pony up for the T7i (it has good guts too).
Nice start.  Nice friend!  All you need now is a "kit" lens.
Like the others have mentioned, 24mm at the wide end really is too long on a crop sensor (esp for what you want to shoot).  It's capabilities are much better suited to full frame (I've shot it on crop).
You could get by with the 18-55 STM, but I would really opt for the 18-135 STM.  A lot fewer lens changes.  Plenty of sharpness for cars, trains, and candids/street.  Adequate sharpness for formal portraits (but you're much better off with the primes for those).
18-135 STM sample portrait on a 70D (worse guts yet)...
18-135 STM @ f/5.6.  ISO 800.  Click on "original size"
Good luck in your quest!
R2
Re: T6I vs SL2
Thanks, I stand(or sit) corrected.
I do plan on getting the 200D/SL2.  I'm going to wait for a while for the price to drop.
Slippery when wet.
Re: T6I vs SL2
It is easy to equate Canon's first generation 24mp APS-C senor with its second generation. At a glance they look nearly identical.
I think the body only price for the SL2 might go down to $450USD and the kit to $500-$525USD eventually but it will take a while.  I don't think we will see fire sales on it as it has little competition at the moment from Nikon.
Re: T6I vs SL2
Yes, I'm going to the States in the Spring.  Hopefully by then, it'll be cheaper.  Plus I want it in white.  I haven't seen it here(Belgium) in white.  And with the €-$ exchange, sweet.
Slippery when wet.
Re: T6I vs SL2
If you are going to be close to a Henry's camera store in Canada then you might get an even better deal.
Jeff Peterman
Jeff Peterman Forum Pro • Posts: 13,585
Weight of the lens.
I've traveled a lot with the 18-135 on an SL1 and never found it to be "nose heavy." The key is to support it with your left hand under the lens, and don't try to hold it with both hands on the body - but that is generally true with anything other than a short lens.
Jeff Peterman, Moderator 7D and Phone/Tablet forums.
Not a staff member, or paid employee, of DPReview.
Any insults, implied anger, bad grammar and bad spelling, are entirely unintentionalal. Sorry.
www.pbase.com/jeffp25
www.jeffp25.smugmug.com
 Jeff Peterman's gear list:Jeff Peterman's gear list
Panasonic Lumix DMC-FZ40 Canon PowerShot S110 Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 17-55mm f/2.8 IS USM +19 more
Re: Weight of the lens.
How long did you walk around like that? I hike, and walking all the time with one hand supporting the camera is not feasible.
Jeff Peterman
I always use a sling bag. When I'm not using the camera, it is in the bag, where it is easy to pull out and use any time - I keep a wrist strap on the body, instead of a neck strap. I have spent all day wandering cities that way (keeping it in the bag, except when in use makes it less obvious too).
I see. That must be the difference. I normally keep the camera outside all the time.
Re: T6I vs SL2
No, will be in Oregon.
Slippery when wet.
