Downloading Picture Styles from camera - is it possible?
Started Dec 15, 2017 | Questions
role_of_72 Junior Member • Posts: 32
Hi,
I am planning to sell my trusty 450D which has some quite good custom Picture Styles on it. As I could not find the .pf2 files on my PC I'd like to ask you if it is possible to download these styles from the camera?
I could not find any information on it online, so might just be impossible (for the standard user at least) but I thought it'd worth asking.
Thank you!
 role_of_72's gear list:role_of_72's gear list
Canon EOS Rebel T4i Canon EOS M5 Canon EF 50mm F1.8 II Sigma 10-20mm F4-5.6 EX DC HSM Samyang 8mm F2.8 UMC Fisheye +4 more
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2)
AnthonyL Veteran Member • Posts: 3,686
Canon's Picture Style editor
Your camera came with (and if you haven't got it you can download it) the Picture Style editor.  Not tried it but I assume it is a two way thing ie you can copy from camera as well as to camera.
http://cpn.canon-europe.com/content/product/canon_software/colour_your_way.do
 AnthonyL's gear list:AnthonyL's gear list
Canon EOS 700D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 55-250mm f/4-5.6 IS Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM +5 more
Lemming51
Lemming51 Forum Pro • Posts: 15,278
Re: Downloading Picture Styles from camera - is it possible?
role_of_72 wrote:
Hi,
Thank you!
check if they're hiding in a \pf2\ folder in your DPP directory, e.g.
C:\Program Files\Canon\Digital Photo Professional\pf2
EOS Utility is used to upload custom picture styles from the computer to the camera. I don't think it or PS Editor or DPP has a feature for downloading from the camera.
If these custom picture styles were developed/published by Canon or other third party, they're likely still available online.
e.g. "Autumn Hues", "Emerald", "Twilight", etc. from Canon: http://www.canon.co.jp/imaging/picturestyle/index.html
Flickr sharing forum: https://www.flickr.com/groups/canoncustompicturestyles
https://www.cnet.com/how-to/best-picture-styles-for-slrs/
If they're simply modifications you made with the slider controls to the built-in styles, you can easily reproduce them with the same slider settings. If you built them from scratch in PS Editor, then maybe you kept some notes on their creation?
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
Ray UK Contributing Member • Posts: 977
From what I've read I don't think you can do it. Within the picture style editor there is an option to lock any files that you've created and this makes them inaccessible so I would guess that Canon have done the same with their in-camera styles.
In any case picture styles seem to more than just the basic controls of sharpness, hue etc so I would suggest they may be specific to the model of camera that they were designed for.
OP role_of_72 Junior Member • Posts: 32
Thank you for the replies! I made these Picture Styles long ago and I have switched SSD since then - but probably have that drive somewhere, so I can check the path in the Picture Stlye Editor folders - if this is still the same Windows install I had back then...
These weren't made with just the slider adjustments as we couldn't replicate them on an other 450D with just these settings.
Thanks again!
Further to my earlier reply I've had a play with the Picture Style editor.  I don't have my 450D any more so there are variations, the 700D editor having more control.
Anyway it seems as if it all based on the assumption you are post-processing RAW, so I suspect that any in-camera settings are non-saveable or transferable.
However, if you were to take photo in RAW using each of the picture styles then from what I can see those settings are seen in the Picture Style editor and and be saved to your computer.  This isn't going to be of much use if you're not shooting/processing  RAW though as I don't see any option to upload to my 700D.
I'm fairly sure if I had set them up on the 450D I wouldn't be using the same settings on the 700D though as it processes differently even with ostensibly the same defaults.
This is something I could definitely check. Thank you, Anthony!
