Asking Question about 'Fall Time Snow' challenge
Started Dec 14, 2017 | Questions
jw432 New Member • Posts: 3
I am a newbie and interested in the upcoming upcoming 'Fall Time Snow' challenge that opens on 12/19. Being a generally decent person I would like to comply with the rules set forth, pasted below. I cannot send the challenge owner a private message with my question (dpreview won't let me send a private message) so I am trying my question here, which may be better anyway, everyone can see it.
What specifically does 'no added effects in post processing' mean?  Does that include or exclude cropping or conversion to B&W.  Is there a common standard for what is and is not considered 'post processing'?  For instance is making ANY adjustment on the computer considered 'post processing' and only a white balance adjust is being given an exception here?
Thanks in advance, I appreciate any serious responses.
Processing rules:
  • no added effects in post processing
  • white balancing encouraged.
DL Cade
DL Cade Junior Member • Posts: 48
Re: Asking Question about 'Fall Time Snow' challenge
Hey jw432, you should be approved to send PMs and post without moderation now. Welcome to the DPReview Forums!
Happy posting!
oneofone25
oneofone25 Senior Member • Posts: 1,556
Where is the information on this??
 oneofone25's gear list:oneofone25's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 16mm F2 +1 more
OP jw432 New Member • Posts: 3
Are you asking where to find the challenges? If so, here: https://www.dpreview.com/challenges/
jrtrent Veteran Member • Posts: 6,428
Processing rules:
Were you able to send a PM (as DL Cade mentioned you could now do) and get your question answered? If not, my best guess is that "no added effects in post processing" just means that the host wants the scene you take a picture of to include real, moving snow rather than a post-processing trick designed to add an effect that looks like moving or falling snow. It seems to back up the description, which included, "looking for falling or moving snow in the shot. there has to be actual snow in it."
Yes, the challenge owner wants real failing snow, not fake snow.  Thank you
