Focus Point Disappeared!
Started Dec 10, 2017 | Questions
randrand Regular Member • Posts: 315
Hi everyone!   New Fuji X-e3 owner here.   I fired up the camera, and it was functioning fine.   Then I turned it on later and no focus point was visible in the EVF or the rear LCD.   Have since restarted the camera several times, and still no focus point is visible.   What did I do?   How do I get it back?    It's virtually useless as of now.    Yes, if I push the joystick in, the focus screen and focus point appears.   But only if I do this.   When I first started using it, I would turn on the camera and the focus "box" would appear and I would move it around on the screen with the joystick.   Help please!   Thank you in advance for your advice!
Rand
 randrand's gear list:randrand's gear list
Fujifilm X100S
Ed B
Ed B Forum Pro • Posts: 12,575
Re: Focus Point Disappeared!
I don't have an X-E3 but it sounds like you may have accidentally pressed the display button (if the X-E3 has one) that changes what's seen in the viewfinder and on the LCD.
I may be 100% wrong but look for a button that says, Disp and press it a couple of times.
OP randrand Regular Member • Posts: 315
Hi!  Thanks for your reply!   Tried it.   Didn't work.   I used to have an X100S and had the same thing happen to me.   Unfortunately I don't remember what I did to get the focus point to appear again.  Hmmmm.
rand
Fujifilm X100S
Acrill
Acrill Veteran Member • Posts: 3,166
Check your autofocus mode. It may be set to wide/tracking.
 Acrill's gear list:Acrill's gear list
Fujifilm X-T20 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS
Thanks.   That's a thoughtful suggestion.   Unfortunately it's on Single Point AF.
rand
Fujifilm X100S
robert1955 Veteran Member • Posts: 7,299
Have a look in the menu, AF/MF setting, Focus point display, ON
Exit10 Senior Member • Posts: 2,264
6
How about Set-up>Screen Set-up>Dis Custom Setting>Focus Frame
 Exit10's gear list:Exit10's gear list
Canon EOS Rebel T6i Fujifilm X-T3 Canon EF 200mm f/2.8L II USM Canon EF 24-105mm f/4L IS USM Fujifilm XF 18-55mm F2.8-4 R LM OIS +4 more
Ha!  That was it!   Thank you!   Thank you!   Thank you!   That'll teach me to fiddle around with menu setting without knowing what each of them does!   I am so happy and relieved!
Thank you!
rand
Fujifilm X100S
Phil1 Senior Member • Posts: 2,307
It's happened to me several times. Very frustrating! Try checking the focus mode switch on the front of the camera. It may have moved from single to continuous focus. Worked for me!
Let us know what happens?
Good luck
Phil
Thank you!
You're welcome. As the camera is still new to me as well, it was good for me to look it up [though i sort of knew where to look]
Cameron22222 New Member • Posts: 1
This worked for me! Thanks!
FoveoLux New Member • Posts: 3
Thanks! It worked for X-T30 II, too.
Btheboat New Member • Posts: 5
Five years later and this just helped me, too!
 Btheboat's gear list:Btheboat's gear list
Nikon D750 Fujifilm X-T30
