Out of focus or wrong settings?
Started Dec 9, 2017 | Discussions
Evil Nemesis
Evil Nemesis Forum Member • Posts: 90
Hi everyone,
Just took this shot using my rebel t3, (1100D) at night with 55x250 stm canon lens at full zoom, image stabilization was on / manual focus was on the focal length was at 250mm / shutter speed was 1/6, ISO = 1600 Aperture = 5.6, metering mode = pattern, no flash and I didn't use any tripod.
1 thing I can guess is I used too much of a noise right? or it's just that those entry level can't produce sharp pictures like seen around the web.
I will highly appreciate any feedback on this. You guys were and are always helpful. Thanks in advance. (The image is scaled down for uploading)
-The Nemesis-
 Evil Nemesis's gear list:Evil Nemesis's gear list
Canon EOS 1100D Canon EF-S 18-55mm f/3.5-5.6 Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50)
CPFan
CPFan Regular Member • Posts: 202
Re: Out of focus or wrong settings?
1/6 sec shutter speed and hand held often results in out of focus pictures unless you are VERY still.
Steve
 CPFan's gear list:CPFan's gear list
Canon PowerShot SD600 Canon PowerShot S5 IS Canon PowerShot SX210 IS Sony Cyber-shot DSC-QX10 Canon PowerShot SX620 HS +8 more
MikeJ9116 Veteran Member • Posts: 6,958
Steve
I agree.  A 1/6 sec shutter speed at 250mm (400mm equivalent) handheld is a difficult shot to make sharp.
Manosko New Member • Posts: 8
Evil Nemesis wrote:
Hi everyone,
While older entry-level cameras do not have the low-light performance of newer or more expensive cameras, that is not the problem here.
You are shooting with a very low shutter speed considering you are hand holding a long zoom tele, so a blurry photo is not surprising. With all that in mind, I am actually almost impressed with that picture, the IS must have been working overtime. I doubt I could take many keepers handheld with the same setup as you in such darkness.
If you want to pursue photography in such conditions, you could get a faster lens (expensive) to keep shutter speed high or get a tripod (much cheaper!) to eliminate any camera shake when shooting with low shutter speeds.
 Manosko's gear list:Manosko's gear list
Canon EOS Rebel T6i Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 24mm F2.8 STM Canon EF 50mm F1.8 STM +5 more
Evil Nemesis
OP Evil Nemesis Forum Member • Posts: 90
Thanks, I do have a tripod but I tried and posted this just to get better at shooting pictures. I knew people here would never fail me. Anyway what fast lens you recommend for night photography?
-The Nemesis-
R2D2 Forum Pro • Posts: 26,551
Evil Nemesis wrote:
Hi everyone,
You are pushing the envelope with your photography. IMHO that's a good thing. See where the limits of the equipment are. See where your limits are. Sometimes the very best photographs are accomplished in this manner.
That said, if you are looking for better image quality, the issue is not really with the equipment here. Sure, you could upgrade to a full frame sensor. Or buy a faster zoom like the 70-200 f/4L IS, or even the 70-200 f/2.8L IS Mk II (or similar 3rd party lens). But given the setup you currently have here, I'd work on technique first.
The easy way to get knock-your-socks-off night shots is to follow the advice of the others and use a tripod. This will increase sharpness in several ways: better stability for reduced camera shake is a given of course, plus it'll allow use of a smaller aperture so you're not shooting wide open (any lens' weakest spot), and also allow you to shoot at a lower ISO (noise reduction robs you of detail). I'd advise picking up a remote release too. The 10-second self timer can be used in a pinch (but never use the 2-second self timer for this).
Bottom line. Shooting with a tripod will allow both the camera and yourself to shoot at your strengths. You'll get maximum IQ out of whatever equipment you have.
With that being said, I personally almost never shoot with a tripod   , (unless I need absolute maximum IQ or a max keeper ratio). There are indeed a couple of tricks we run-and-gun shooters can employ to put the odds back in our favor though.
First off, use your feet instead of the zoom whenever you can. Shorter focal lengths will exhibit less camera shake (plus your max aperture will be faster allowing shorter shutter speeds). You could then even use a shorter (maybe sharper) prime if you have one.
Find something to set the camera on (but don't use a running car!).
Similarly, find something to brace the camera or yourself with. I try to always stop where there's a nearby brace (tree, building, wall, fence, car, etc).
Use good handholding technique. Sometimes an iron grip isn't the best. Watch your breath control and shutter timing (deep breath in, let half out, hold and shoot). Gentle on the shutter. I use the principle of isometrics when handholding any camera (I call it the "Twist Grip" technique). Let both hands put just a little force on the camera against each other. With small point and shoots, it feels almost like you're trying to twist the camera a teensy little bit.
Shoot bursts and then cherry pick the best one. There will always be one frame that's sharper than the others. I call this "Poor Man's Image Stabilization." Note: I've found that shooting bursts also works very well for other types of photography too (such as birding, macros, portraiture, etc).
There are a couple of (low light) modes built into recent cameras (not 100% about yours). One is the "Handheld Night Scene Mode" where the camera increases ISO and shutter speed (for improved handhold-ability), and then shoots a short burst (and combines them into one image). The magic comes when it then applies something of a subtractive noise reduction, resulting in a cleaner picture than you would have otherwise had. The down side is that it's fully automatic, and only works for jpegs.
The other feature is called "Multi-Shot Noise Reduction." The processing is similar, but lets you manually adjust more settings.
I've found these modes to be really effective (and not just for night scenes). Give them a whirl next chance you get. There's no free lunch when you're pushing the envelope this hard, but IMO this is as close as you're liable to get.
Happy shooting!
R2
Evil Nemesis
Thanks for detailed explanation and awesome tips mate.
Here are my tonight's shots with tripod with different settings.
-The Nemesis-
FooHead Contributing Member • Posts: 546
R2D2 wrote:
Evil Nemesis wrote:
Hi everyone,
Happy shooting!
R2
Great tips R2!
I've had my 1100D for 5 years now, yes it has its limitations, but once you understand them you can still get great images with it.
 FooHead's gear list:FooHead's gear list
Canon EOS 1100D Canon EOS 80D Canon EF 35mm F2.0 Canon EF 100mm f/2.8 Macro USM Canon EF-S 18-135mm F3.5-5.6 IS STM +2 more
Sorry, I missed your reply until now!
I like that you are taking multiple shots with different settings.
Experimenting will teach you so much. Good work. 👍
One thing I don't think I mentioned in my post above is that it's a good practice to turn the image stabilization off when you are using a tripod (which you might already be doing).  You might also try shooting multiple exposures and then combining during post processing for different effects.  Often it's nice to have some detail in the dark areas...
Happy shooting!
R2
guinness2
guinness2 Veteran Member • Posts: 4,617
Hi your pics are nice and well exposed, but mind please the horizon level.
 guinness2's gear list:guinness2's gear list
Canon EOS Rebel SL3
