Trip to India: adding a prime to my EZ 14-42mm kit lens
Started Dec 4, 2017 | Discussions
mfroms New Member • Posts: 15
So after getting some great help from you guys earlier with choosing a camera I've now received my e-m10 mark ii with the 14-42 kit lens.
In two weeks I'm going on a trip to India for three weeks. And I would love to add another prime for this. This is how I see myself travel and using my camera:
  • General sightseeing (like Delhi/Taj Mahal) during daytime: Using the 14-42.
  • Some photos at dusk/dawn (hence the prime rather than the 14-42)
  • Days more focused on taking nice pics of the people and the life in India; guess street is closest to describe this
  • Indoor photos of me and my travel company
So if you could only add one prime, which would it be?
What I'm considering:
Olympus 45/1,8 - Great for people, but would it be a bit too tele for street/general photos of life in india? Also, is size an issue here?
Panasonic 20/1,7 II - Have to move a bit closer when taking portraits, on the other hand: there are LOTS of people in India so the wider 20 might be more useful so it's possible to add context as well? Also, a bit expensive (and almost out of my budget)
Panasonic 25/1,8 - Cheap! However a bit bigger, maybe too big to carry around all day?
One important thing, and the reason for buying the e-m10, is the size and having a camera that is small enough to carry with me rather (already own a big Nikon DSLR).
So what do you guys say? All input is greatly appreciated!
Best regards
//M
 mfroms's gear list:mfroms's gear list
Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ Olympus M.Zuiko Digital 25mm F1.8
Olympus M.Zuiko Digital 25mm F1.8 Olympus M.Zuiko Digital 45mm F1.8 Olympus OM-D E-M10 Panasonic 20mm F1.7 II
maggiemole Senior Member • Posts: 1,988
Re: Trip to India: adding a prime to my EZ 14-42mm kit lens
I'd start from a different point, by getting rid of (or leaving behind) the kit zoom.
The 14-140mm II makes a great daytime walk-around lens and gives you the telephoto distance you want for portraits. You're not counting on too many night-time portraits, are you? It's rather big for street so .....
A low light prime complements the zoom for your indoor, dusk and dawn shots and it will handle very nicely for street in any light. Personally I use the 20mm but I hear the 15mm f1.7 is warmly spoken of for street and will probably cope better with the space restrictions of rooms than the 20mm. If it still isn't wide enough, there are other possibilities: 12mm f2 made either by Olympus or Samyang - the latter being a manual lens which you might not like. Or a combination I am preaching more and more (depending how fast you want) the 14mm f2.5 with the wide-angle converter, taking it down to at least 11mm.
Enjoy a marvellous country!
M
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
Okapi001 Veteran Member • Posts: 5,145
My suggestion for one prime would be Leica 25mm f/1.4. Or, if you don't mind manual focus, Mitakon 25mm f/0.95.
Other than that, get also Olympus 9mm f/8, cheap and very useful on a travel like yours.
Next in line for purchase would be Olympus 40-150mm kit lens, also quite inexpensive and small for what it is.
With these three lenses (+14-42mm) you are all set for travel;-)
 Okapi001's gear list:Okapi001's gear list
Olympus OM-D E-M10 II Olympus PEN-F Olympus E-M1 II Olympus OM-D E-M1X OM-1 +18 more
larsbc Forum Pro • Posts: 18,282
Use the 14-42's long end for portrait photos. For indoor/lowlight stuff, the Panasonic 20/1.7, Panasonic 15/1.7 or Olympus 17/1.8.
OP mfroms New Member • Posts: 15
So you would prefer the Pana 20/1.7 rather than the 25/1.7? Read something about slow autofocus on the 20/1.7, do you think this will be an issue?
ahaslett
ahaslett Forum Pro • Posts: 12,662
SAF on the 20/1.7 is a bit slower than other MFT lenses but it's hardly noticeable for most types of shooting.  More serious is AF noise which makes video a problem.  On some Olympus bodies it produces high ISO banding, not sure about yours.
Other than that a used 20/1.7 mk I would fit your spec nicely.  It's what I use mine for (no banding on EM1.1).
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Vetteran
Vetteran Senior Member • Posts: 1,664
Been there. Bring some sort of backup camera. Preferably something that can share lenses and batteries  although not required.
Any lens will work. Most mileage from a 17mm or so focal length. Even another kit lens such as the 40-150 works.
Two bodies with any additional lens is more important than a prime or any lens on a single body.
Warm regards and very respectfully,
VETTRAN
My travel blog:www.midlifetravels.com
 Vetteran's gear list:Vetteran's gear list
Leica Digilux 2 Leica X1 Leica X Vario Nikon D750 Leica Digilux Zoom +8 more
zxaar Veteran Member • Posts: 4,541
If possible do tajmahal very early in the day. In fact be there 20 minutes before it opens.
As soon as it opens go directly to the back side of the taj spend your time there that moment is magical down there. As the sun comes up walk to the front and you will also see crowd increasing.
Going to taj in day means you will see lots of crowd.
Best regards
//M
::> I make spelling mistakes. May Dog forgive me for this.
For stills, it's never been an issue for me.  For video, I'd still use it since I don't usually use AF when recording...but if you did, then the AF noise is also going to be an issue with that lens.  In which case, go for the 17/1.8 or 15/1.7.
I also have a 25/1.4 but for a single travel prime for indoors, I'd take my 15/1.7 (or 17/1.8 if I had one).  I use my 25/1.4 for outdoor street photography, mosty.
Thanks for the feedback. I just checked this forum and unfortunately my E-M10mkII is one of the models where banding can happen at higher isos. As I'm planning to use it mostly for low-light and indoors I think I have to try to find another lens instead.  So right now I'm leaning towards Pana 25/1.7 or Oly 17/1.8 instead.
//M
Great tips! I'll make sure I'll get there early.. Thank you for sharing the photos, looks magical!
//M
phaet2112 Regular Member • Posts: 129
The 25 field of view can be a bit narrow when trying to do outdoor photography sometimes.  I usually find myself arching backwards or taking several steps back and trying to fit more in the shot- the 20, 17, or 15mm may provide a much better field of view.
 phaet2112's gear list:phaet2112's gear list
Panasonic G85 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 25mm F1.7 ASPH Panasonic 12-60mm F3.5-5.6 OIS +1 more
rsmithgi Senior Member • Posts: 2,939
//M
You should also consider the Oly 25mm/1.8. Gets better reviews than the Pana 25/1.7. Comes down to the focal length you prefer for the prime. 25mm is better for tighter shots of 1 - 3 people. 17mm gives more room for larger groups or including more of the background in the photo. You will be farther away from the subjects and avoid the perspective distortion that is (IMO) common with the 17mm.
I have both lenses and like them both. Really depends on the type of shooting you want to do.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
jeffharris
jeffharris Forum Pro • Posts: 11,411
Oly 17mm f1.8
Ideally, Panasonic 15mm f1.7
A slightly wider field of view is more flexible, especially for narrow streets and interiors.
20mm and 25mm just don’t cut it. I’ve traveled with both and found them frustrating. 17.5mm for me is perfect. Wide, but not too wide.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
mentos77 Contributing Member • Posts: 988
100% the 45mm f1.8 - it is cheap, the best of the 3 lenses you mentioned (quicker to focus than the 20 and better optically than the P25).
India is full of amazing sights, so your zoom will serve you well in the day for sightseeing and street. But the "real India" is the amazing street scenes. The poverty is pretty harsh, so that's why I say the 45 over the 25; you can keep your distance and capture plenty of colorful street sights, cows in the middle of the road, characters, plus you have the option to get in close and take awesome portraits with smooth bokeh, which those with you should appreciate.
Sure, you have to take a step or two back with the 45 sometimes e.g. when having a group meal. But it is worth it. You can get perfectly good head shots of your travel partners whilst eating. The 45 makes it so easy to get warm shots (slight yellow tint) of people with good background blur.
The 20 would be boring and not enough difference to your zoom i.e. not much background blur. The 25 is faster to focus, lightweight but bigger than the 45 and again pretty "vanilla" when it comes to getting shots which will really make you go wow compared to your zoom. If you take a shot in the day with the 45 you will know it was taken that lens when you come to view your trip pics. With the other two you will only know if it is a close up shot.
If I was to go back to India I would certainly leave behind my tiny 14mm street camera and re-buy the 45mm 1.8 to use with my pancake zoom. Or take the Sigma 60mm. People's faces are what I want to capture and day to day activity- a guy rolling a massive cart down the street, a woman cleaning her clothes in the Ganges at dawn, colourful head scarfs of women with pierced faces that have "seen a lot".
ahaslett wrote:
SAF on the 20/1.7 is a bit slower than other MFT lenses ......
I think this is down to personal opinion. For me it is not a bit slower, it is enormously slower, my keeper rate was very poor for anything moving. India is a non stop chock-a-block assault on the senses of new things to photo, you will want to take photos in rickshaws and taxis whilst moving. If you look at the actual figures, sure it is only within a second, but the pretty much instant focus (approx. 0.20 seconds) you get with the 25 or 45 can feel a long way away from almost a second on the 20mm. Even if it manages to focus in half a second it is 2 and a half times slower that the others. I pulled the figures out of thin air to illustrate the point, but they are probably a decent enough guesstimate.  Again, this is just my opinion, I do not wish to debate the 20mm with anyone. The OP asked, so I am giving him/her an alternative opinion,
jeffharris
Re: Trip to India: sell the EZ 14-42mm kit lens…
I've owned both versions of the 20mm. Even on Panasonic cameras… GH2, GX1, GX7 & GX8… it often hunts for focus even in full daylight. Sometimes not. Although, it's nailed focus in low light when I thought it wouldn't. It's really a crap shoot on what it decides to focus on in whatever situation.
Another option for the OP would be to sell the kit zoom, forget the prime and just get a 12-40mm f2.8. The proverbial "bag full of primes".
In low light, crank the ISO a bit. It may not be ideal, but then which prime to buy isn't an issue AND once the OP has a chance to review their travel images, they can see which focal lengths THEY actually prefer, not a bunch of random suggestions from strangers……12mm, 14mm, 15mm, 17mm, 17.5mm, 20mm, 25mm, 42.5mm, 45mm, fisheye… UGH.
Later the OP can make an educated purchase based on their own experience and developing shooting style and way of seeing.
As far as the cost of the 12-40mm goes. How much is the OP spending on the trip? It's a "trip of a lifetime" (HATE that expression) so, what's it worth to capture images from an experience like that? There have been quite a few trips I've taken with not that great photo gear and wished I'd ponied up and bought something better!
It's probably a few $100 more. Is it worth it? I'd say!
yellodog Senior Member • Posts: 2,304
It's also worth a lot to avoid having to change lenses in a dusty ( potentially polluted) environment. However there is the small matter of carrying around a $1000 worth of equipment while you're rubbing elbows with people perhaps earning $2-3 a day...
gotoole Contributing Member • Posts: 524
In two weeks I'm going on a trip to India for three weeks. And I would love to add another prime for this. ....
//M
I have both Olympus 45/1.8 and PANASONIC 20/1.7 . When traveling I almost always take the 20mm/ 1.7 lens  in preference to 45mm ( on either e-m10 mark 1 or Epl6 which is even smaller). As you say, 45mm is often too long
