The best kit lens? Canon 55-250mm IS STM review
Started Dec 4, 2017 | User reviews
NacMacFeegle
NacMacFeegle Contributing Member • Posts: 604
I initially planned to sell off the kit lenses that came with my 80D when I upgraded from the 60D, but to my surprise I found myself using the included 55-250mm lens more than just about any other lens in my kit! My only real complaint about it would be the dark, variable aperture.
In addition to the video review, I've published a full written review on my blog:
http://illuminationsfromtheattic.blogspot.com/2017/10/canon-55-250mm-is-stm-f4-56-review.html
Canon EF-S 55-250mm f/4-5.6 IS STM
Telephoto zoom lens • Canon EF-S • 8546B002
Announced: Aug 22, 2013
NacMacFeegle's score
4.5
Average community score
4.4
Abu Mahendra Veteran Member • Posts: 5,312
Re: The best kit lens? Canon 55-250mm IS STM review
I was the first one here to preach the gospel of this lens 45 months ago on this seminal thread:
https://www.dpreview.com/forums/thread/3641158#forum-post-53318866
>> I'm already lovin' my Canon 35IS lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
IoannisZ
IoannisZ Contributing Member • Posts: 500
Hi! I have an eos m3 with a 18-55mm which I like very much. Most of my photos are in the 55 position and I search for a tele for street photography (from a safe distance). Do you recommend this lense?
Thank you.
More pixels, less ideas
NacMacFeegle
OP NacMacFeegle Contributing Member • Posts: 604
Thank you.
If you are happy with the 18-55 you will like the 55-250. I own both and I find that the image quality of the 55-250 is much better than the 18-55. I still regularly use the 55-250 due to it's long reach and small size - it's my go-to telephoto for backpacking. I don't do street photography, but this should work for that - autofocus is very fast and accurate (at least with my Eos 80D).
quiquae Senior Member • Posts: 2,265
EF-S 55-250 STM will work fine, but is a bit big relative to your M3. EF-M 55-200 is much smaller, possibly making it a better choice, as it sounds like you don’t need the 200-250mm range and not drawing attention to the camera seems to matter for you.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
rmexpress22 Senior Member • Posts: 2,304
I thought for what it was, the original version of this lens was okay. I still have it but it started looking a bit hazy at some point. Not sure if I bumped it, but something wasn't quite right. The STM version is better from what I read, which is good.
The Canon kit lenses are mostly decent. All the newer STM kit lenses are not bad. I think the main issue is the variable aperture, but if you can deal with that, you have a capable lens.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
My copy of the non-STM 55-250 IS II was pretty respectable when shooting things only a few meters away, but became rather soft when focusing at objects more than 20-30m away, which was a problem because such focal lengths are most useful at shooting distant objects. The STM turned out to be much more consistent at different distances.
Incidentally, I was rather disappointed with the autofocusing and IQ of the STM when attached to an EOS R, which was interesting because I had great experience with the same lens when paired with APS-C bodies (M2, M5, 7D mark II, T4i).
maarensv
maarensv Senior Member • Posts: 1,106
Personal preference differ sometimes. I have the EF-s 18-55 STM and EF-s 55-250 STM. Both bought for fun out of curiosity.  Both are surprisingly good, but I hardly use the lenses as I have other option to choose from. The 18-55 is usually in the closet and the 55-250 normally lives with my dad. I do sometimes use the 55-250 STM on an M5 though. A low weight "100-400mm" hiking alternative (to FF 100-400mm). Really like the combo. I find the somewhat larger size a plus compared to the EF-m 55-200 as it makes the combo better to handhold and more stabile.
 maarensv's gear list:maarensv's gear list
Canon 6D Mark II Canon EOS R Olympus E-M5 III Canon EOS R7 Canon EF 100mm F2.8L Macro IS USM +22 more
IoannisZ
Thank you.
What is the other option if I could ask?
Dareshooter Veteran Member • Posts: 5,842
IoannisZ wrote:
Thank you.
I had the ef m 18-55 and efm 55-200  for my M50 nothing wrong with either of them but  traded them for them ef m 18-150 and other than the loss of 50mm on the top end I haven't suffered any disadvantage. I used to use an adapted ef s 55-250 STM which was great too but as I was in the process of downsizing I decided to ditch adapted lenses altogether .
tkbslc Forum Pro • Posts: 17,523
Thank you.
For M3, you;d want the EF-M mount version, the EF-M 55-200mm f/4.5-6.3 IS STM
