Panasonic GH4 Issue - Screen is frozen when I press the Playback Button
Started Dec 1, 2017 | Discussions
sparaire New Member • Posts: 1
Hello
In a few days ago I was shooting an automatic Timelapse with my GH4. After the shooting was done, I've met a lot of issues with it .
1 : Each time I press the playback button, the screen freezes and all the camera's body is not working. When I want to turn it off, I have to remove the battery. It does the same thing when I only go to the playback menu or when I press the wifi button.
2 : The screen doesn't work well sometimes when I turn the camera on, Many strange dots appears on it. (It happens just when I turn the camera on).
3 : When I want to rotate the screen, the picture is staying at the same position
4 : the touchscreen is not working
I was thinking it's a firmware issue, (my version is 2.5), I've downloaded the 2.7 version but I can't install it because when I press the playback button, everything freeze.
Can you please help me ?
Thank you
Panasonic Lumix DMC-GH4
Ranlee Senior Member • Posts: 2,258
Re: Panasonic GH4 Issue - Screen is frozen when I press the Playback Button
sparaire wrote:
Hello
Thank you
I'll bump this to the top again and maybe you'll a helpful response.  As for me, I don't have a Gh4 so nothing specific but if I were you I would try a system reset which should put the camera back to default settings as when new.  You will lose any and all settings you have changed so you might want to write them down so you can get back to where you are now more easily, assuming the reset helps you get past the problems you are having and perhaps allows you to update the firmware.  Good luck.
Randy
 Ranlee's gear list:Ranlee's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix DC-S5II Canon EF 200mm f/2.8L II USM +10 more
opiecat Senior Member • Posts: 2,410
have you tried removing the memory card and or lens and turn the camera on?
use another memory card?
'when 900 years you reach, look as good you will not' -- master yoda
http://opienc.wordpress.com
Wasabi Bob Contributing Member • Posts: 680
Try another SD card, especially if you are using  LEXAR cards. They have had problems with their 1st two revisions. I don't think this is a common problem with the camera. If you were shooting time lapse, were you running on external power? Generic power supplies may not provide enough power and can cause this problem. Happened to me once - verified it was the power supply.
BenjiBlobs
BenjiBlobs New Member • Posts: 5
This is a long shot given the age of your post, but did you ever find out what the issue was? I have a friend who has a GH4 which is exhibiting the same issue. Any pointers on how to fix it would be amazing.
Many thanks,
Benjamin Marc Huggett
Livin' the HuggLife
 BenjiBlobs's gear list:BenjiBlobs's gear list
Canon EOS 5D Mark III Sony a7S II Canon EF 40mm f/2.8 STM Canon EOS 60D Canon EF 50mm F1.4 USM +5 more
