Why two identical GH4 produce different footage?
Started Nov 29, 2017 | Discussions
AshVR New Member • Posts: 2
I have two identical GH4 set ups (Firmware, Lens, Vlog-L and other profiles, memory card, setting) for shooting stereoscopic VR. But one camera footage has a red cast and slightly more saturated. I have switched the lenses, memory cards and also rerecorded externally and I have still got the same result. Can't figure out why? appreciate any help.
Panasonic Lumix DMC-GH4
Danielvr Veteran Member • Posts: 6,860
Re: Why two identical GH4 produce different footage?
Do they both use the same white balance setting? Just guessing.. (and kicking your unanswered msg back to the frontpage).
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
Skyler King
Skyler King Regular Member • Posts: 162
I think the guy above me likely nailed it. White balance would be the most likely issue, I think. However, it's also always possible that there has been some sort of unintentional damage done to the sensor or metering system.
 Skyler King's gear list:Skyler King's gear list
Samsung EX2F Canon EOS 5D Nikon D200 Olympus PEN E-P1 Olympus PEN E-P3 +10 more
Sean Nelson
Sean Nelson Forum Pro • Posts: 16,118
AshVR wrote:
...one camera footage has a red cast and slightly more saturated.  ... Can't figure out why?
Probably for the same reason that you can get different colour casts even if you shoot the same scene twice with the same camera - "automatic" white balance.   If you want to eliminate the differences between the cameras, then you need to defeat all of the automatic options by choosing manual white balance, manual ISO, etc. etc.
Even there you may find small differences, so be prepared to tweak your footage in post.  Fortunately, the eye's stereoscopic separation is far more sensitive to edges than to colours.
OP AshVR New Member • Posts: 2
White Balance is on 5600K manual and every settings on manual and identical. They were both purchased new.
RickPick
RickPick Senior Member • Posts: 1,332
Have you checked the WB adjustment graphs which are present on all WB settings (including Auto and Kelvin)? Press WB, select your set then touch down arrow.
If one of these has been knocked from the default central position it could explain the issue. If not, you might be able to adjust the two cameras so the WB matches up.
Similarly, check the settings on your selected Photo Styles (profiles) if you haven't already.
 RickPick's gear list:RickPick's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
Androole Senior Member • Posts: 1,455
If they're brand new and you've made sure that all the settings, including white balance, are identical, I would go back to the store (or any store) and try a 3rd GH4 to see what result you get from footage with the exact same settings.
If your red cast is the only odd camera out, then I would return it.
 Androole's gear list:Androole's gear list
Olympus Stylus Tough TG-850 iHS Panasonic Lumix DMC-GX7 YI M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +2 more
