Is Panasonic gear's reliability and durability levels comparable to Canon/Nikon gear?
Started Nov 26, 2017 | Discussions
Pete_W
Pete_W Senior Member • Posts: 2,841
Re: Is Panasonic gear's reliability and durability levels comparable to Canon/Nikon gear?
EcoPix wrote:
The technician couldn't clean the GX85's sensor. The dirt had impregnated onto the actual sensor photosites, and they had to quote me nearly AU$500 for a new sensor. Given the camera had also developed a faulty viewfinder module, I had to say no. Another Lumix in the bin.
The take home message I think is to consider dirt behind the sensor glass like fungus on a lens - best to clean it off without delay, lest it write off your camera.
How does this problem happen?
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
Yxa
Yxa Senior Member • Posts: 2,693
Sloppy quality control.
I have the same problem on one of my GX7.
OP CaMeRa QuEsT Regular Member • Posts: 400
Is it dirt or rather fungus?
I just bought a used, early G7 with 20+K on the meter with the kit lens and the 50/1.7, everything had lots of dirt everywhere.  Had to disassemble the lenses' rear elements which were full of dust on their inner surface, also the camera's mount ring which had so much rust on the inside it was de-centering the lenses.  Sensor was also filthy.  I was able to clean everything up nicely by myself, and everything lined up back perfectly square, but darn was the previous owner a pig with his equipment.
During disassembly of the lenses, I noticed that it would be very hard to disassemble deeper than the rearmost element of both lenses, also, since both of them use linear stepper motors, it is also an absolute no no to go down there, as those motors need specialized calibration rigs.  Certainly not repair-friendly; I guess that's the reason why Panasonic service centers will usually replace rather than repair.  The outer lens coating, on the other hand, is very slippery to the tissue paper I usually use for lens cleaning, and it feels very tough, which makes it a real peach to clean, compared to all the other lenses I've owned, and I've pretty much owned all of the Japanese camera brands, plus a Zeiss or two.
 CaMeRa QuEsT's gear list:CaMeRa QuEsT's gear list
Canon EF-M 22mm f/2 STM Canon PowerShot A40 Canon PowerShot A650 IS Canon EOS 1000D Canon EOS M5 +22 more
JosephScha Veteran Member • Posts: 7,249
In my experience: I had a Canon A7 (3.2MP small camera, I think that's the model, look it up) whose sensor died.  The menu came up on the LCD, on a black background.  I took a picture to test it, sure enough the picture was completely black.
I bought a Panasonic FZ7 and used it for years, traded it in and bought a G10 (defeatured G2).  I used that for five years, shot thousands of pictures, and traded it in and bought a G7.  After perhaps 2.5 or 3 years I traded in the G7 and a couple of old lenses, and bought a G9 which I am very happily using now.  None of my Panasonic cameras or lenses have needed service. Not any, ever.
I treat my equipment well, so I won't comment on durability.  But:
I would say no, Panasonic gear's reliability is not comparable to Canon, it is BETTER!
That has been my experience.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
SidSnot
SidSnot Senior Member • Posts: 1,045
https://www.dpreview.com/forums/thread/4320678
GM5 with broken on/off switch (repaired by myself with superglue), 2 x 12-32 kit lenses, both had the outer cover come adrift.
All 3 problems due to crummy black glue that Panasonic use not holding up...
My 3rd version of this lens is ok so far, (4mths old, came with the GX9) interesting that this one has a plastic mount, the previous two both had metal mounts...
 SidSnot's gear list:SidSnot's gear list
Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GM5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +4 more
