Shure Vp83f Lenshopper Sd card error, broken?
Started Nov 23, 2017 | Discussions
Robodelfy Regular Member • Posts: 312
I have a shure VP83f lenshopper, which was working fine. Now, within 10 seconds of turning it on it says 'SD card error' and makes me restart, and it happens ovr and over again. It doesn't have an SD card in it! I've tried with SD cards and without, tried resetting, every option i can think of.
I reloaded the firmware, but theres only one, so I cant try a different one.
I emailed Shure and they said to send it in for repair on warranty, but its out of warranty.
Sometimes it doesnt get the error and I can use it until i turn it off again, but its rare. And then it works perfectly.
It seems crazy that it might be unusable because of this, when everything else works fine and I dont even want to use it with an SD card.
Anybody got any advice?
PookaStudio New Member • Posts: 1
Re: Shure Vp83f Lenshopper Sd card error, broken?
Shure VP83f Lenshopper only supports a max 32 GB card. I had trouble with my unit because the card was too big. Try a 32 and format it and see if the problem has been solved.
