How to avoid condensation inside housing in hot humid weather?
Started Nov 21, 2017 | Discussions
Julian500 Contributing Member • Posts: 781
I own an EWA Marine bag/housing for my 5D and have used it only a small handful of times. A couple years ago I fried a camera inside of it due to a huge amount of condensation build up while I was kayaking in very hot humid sunny conditions. I was trying to keep it out of direct sunlight by placing a wet T shirt over it but in the end I found almost a half inch of water sitting on the bottom of the bag inside. Now I have an assignment in Florida coming up which will require some underwater shots and was looking at buying one of those Meikon housings for Canon 5Diii to make my setup look less clunky.
Since I'll find myself once again in humid environment and currently live in NYC where it definitely won't be anything but cold before then, I can't test things out beforehand. I've read about placing the camera in the housing and sealing in as dry of air as possible (such as air conditioned room). Also using silica packets.
If I stick to these two am I totally fine? Should I still avoid letting the camera/housing sit in the sun once it's sealed?
Thanks for any tips!
Julian
www.julianwalter.com
Canon EOS 5D Mark III
nafik Contributing Member • Posts: 922
Re: How to avoid condensation inside housing in hot humid weather?
Julian
using silica packets and avoid letting the camera/housing sit in the sun. actually on a good scuba diving boat you will always find a bucket full of water where all cameras reside until the dive.
for those boats that do not have a bucket, i wrap housing in wet towel and keep it in the shade.
M.
Nice camera...now show me the pictures.
 nafik's gear list:nafik's gear list
Canon PowerShot S100 Canon PowerShot G7 X Nikon D7200 Nikon AF Nikkor 50mm f/1.4D Sigma 10-20mm F4-5.6 EX DC HSM +2 more
Yar1971 Regular Member • Posts: 409
Well, I'm not expert, but I've used EWA Marine bag for a compact camera while kayaking. I remember that for proper use these bags must be pumped with some air via small valve (of pneumatic matress resemblance). By the way, that single element was the main weakness of the bag - easy to open accidentally.  Some extra protection needed.
What is important here: I've discovered qucikly that blowing air by yourself into the bag gives a lot of condensation if you don't use dessicator inside. So I've bought rubber ball for blowing dust and used it as a small pump. It worked, but in your case I would probably use both it AND dessicator. Note, the ball must be relatively big one or have an inlet one-direction valve in the rear end to work effectively. Your soft-casing is bigger than mine was...
-J.
Allen Murray Regular Member • Posts: 184
I'm no expert, but my experience in the order of importance;
1. Having the camera and housing in an air-conditioned room before hand, and sealing it in the room.
2. A small silica gel packet in the housing.
 Allen Murray's gear list:Allen Murray's gear list
Canon PowerShot D10 Olympus TG-820 iHS Canon PowerShot G7 X Canon EOS 400D Canon EOS Rebel SL1 +6 more
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
And that just increases the likelihood of condensation.
That helps.
The root cause here is a cool camera in warm water.   The coolness of the camera body causes humidity already in the housing to condense.
What has helped me:
1. Do NOT allow the camera to go into the housing cooled by A/C.   Better to have everything at the water temp when you go into the water.   Thus you want to leave the camera in a non-air-conditioned environment, preferably with a gel packet.
2. Put antifog chemical on the glass involved.
What has hurt is diving in cooler depths, then coming up to the warm shallows.   Only a gel packet is likely to be completely successful.
Phoenix Arizona Craig
www.cjcphoto.net
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
kelpdiver Veteran Member • Posts: 5,564
A/C also acts as a dehumidifier.  I long used to close up my gopros and my slr rigs in the A/C room, and never expose to the 100% humidity outside.  It worked fine, though became a hassle.  On the liveaboard boats, not practical, and I found no bad came of doing it all on the camera table.   It had the humidity, but not the temp shift you warn of.
Anilao, earlier this year, was land based.   Every morning and every lunch, everyone did their thing in the 20 person station camera room, then took it out to the boats.  Not a concern.   But you don't want to open it outside, just after leaving the cooled room.
PHXAZCRAIG
That makes sense - seal it in A/C, then get it up to temperature before diving.
By the way, I almost booked a week in Anilao this December.   Felt nervous about both water temps and being in the Phillipines, but ultimately had to hold off for health reasons.   Would love to know more about it.   I'm trying to get in another 56 dives between now and July, probably in the Caribbean (for affordability).
www.cjcphoto.net
Anilao is a pretty cheap place to crank out 30-36 dives on a 10 day booking.  (4 per day)  I think the resort part was ~2500 and the airfare around 1400RT, but that was EVA's premium economy.   Straight up coach would have been under 1000.
My wife still logs, so I could find the temp range in May, but most of the time it was marginally necessary to wear the wetsuits for warmth.  Some spots definitely cooler with some unexpected thermoclines.  But bigger reason you need to wetsuit up is you're often planted on the sand next to the target, and there's definitely jelly stuff in the streaming current.  Ankles and wrists get it.
I thought bay waters meant trivial diving, but it's really tidal flows.   About 1 dive each day could have strong to mildly ridiculous current, and not in a predictable way.  That translated into moderately advanced diving conditions.   Not the best place for a new macro diver.  And there can be a fatigue factor with 9 days of it.   Downside to land based is the time you spend on the little boats going out and back twice a day.   But the subject density is ridiculous.
Anilao is pretty isolated from the nonsense with the new regime.  2-3 hour ride from the airport.  The resorts are all built along a steep slope - just ten years ago you had to take a boat to get to the resorts.  Generally an all inclusive approach - too hard to get to anything else.
I was with Blue Water, who uses Crystal Blue.  They have an excellent resident pro.  The dive boats take 3-4 divers plus the guide, though there can obviously be multiple boats from the various resorts at a given site.  But rarely a crowd.
Cayman Aggressor would be my next choice for high dive density.   ~3k for a week charter with 27 dive slots.  Never gets old floating along Bloody Bay Wall.
PHXAZCRAIG
In September I spent my usual week in Roatan, and then added a second week.  I got 37 dives in, skipping two on one day.   My ears just wouldn't take any more.  4 per day would not be good, for me, I think, though I've done it before in Fiji.
I need to get me one of those 'lembeh sticks' - metal rods.   Know where I can order one?  Probably 1 foot in length.
www.cjcphoto.net
Yes, the A/C dehumidifies first, then cools. I don't want the camera and inside of the case cold necessarily, I want the air inside the case to have a very low moisture content.
davephdv Contributing Member • Posts: 850
Ha!
ive felt with this issue for 20 years and heard many different solutions. None of which seem to work reliably with plastic housings.
the best answer is never take your housing into the air conditioning. Leave your camera outside and assemble outside. Thus seems to work best. Nothing seems to work all the time.
the best solution is to make sure your housing is metal and glass.
Master of the Universe Forum Member • Posts: 56
Did you happen to know thoise two depend on each other. It's very, very basic physics.
OP Julian500 Contributing Member • Posts: 781
Are you saying hot and dry air is impossible?
Barmaglot_07 Contributing Member • Posts: 633
In areas where one would be using an underwater camera housing, hot and dry air, while not impossible, is highly unlikely.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
this thread seems at risk of dick waving, but
close housing in A/C'd room.   Take housing to back to dive boat.
In pretty short order, you have a housing with hot dry air.
Not what I meant and you know it but....
Frankly I have no idea what the point of your or Master's posts were.   They don't help the OP's query very much.
I don't know how much more prevalent this problem is with plastic.   I have taken both the AC only and outdoor only routes.   The only time I've been bit is when I try to take the camera out of my cabin to get top side pics.
Andy Willett photography
Andy Willett photography New Member • Posts: 9
Condensation in underwater cameras housings.
There are many posts on this subject with only bits of information that don't always seems to add up or is just a bit bitty. So I hope this helps.. This generally applies If the housing "does not" have "dry" air inside, and has a higher humidity level, i.e particularly a issue in the tropics.
POLY carbonate housings often have more front port glass fogging issues than aluminium housings, the poly case doesn't condense much moisture onto its inner surfaces as it a poor conductor of heat, the inner surface inside the housing therefore remains warmer and any moisture that is present inside, doesn't readily condense on the housing walls, resulting in more vapour staying air borne longer which finds it way to the glass port. The glass port generally being the coldest surface, the moisture condenses, similar to your windows at home.
A METAL housing inner surface temperature is normally cooler as the case conducts heat way into the cold water, and the inner surface temperature is therefore much closer to the cooler water temperature, (i.e water cooled) then acts like a "moisture sponge" so to speak, moisture condenses on the housing sides, this may not be visible, resulting in less moisture being "air borne", (air is now a bit dryer) resulting in less moisture vapour reaching the glass port window, therefore less fogging issues. This process has a similar effect as putting silica gel packs inside the housing to help soak up vapour.
In either housing type, a hot camera, heating up the inside of the housing can in some circumstances re-evaporate some moisture, that is (if any) off the case inner sides to some degree.
So if a glass port is clear with the camera off, Turning on the camera in some circumstances can cause fogging to occur.
As you dive deeper the water temperature often cools and you can find fogging occurs more at depth and can also clear nearer the surface.
The answer to all these issues is to have dry air inside your housing at all times.
Ways to achieve this is to always assemble camera in a air conditioned room. Carefully blow dive cylinder dry air into housing as you close it, or put open prepared camera housing in large plastic bag and fill with dive cylinder dry air, and close it whilst in the dry atmosphere. Least reliable is using silica gel packs inside the housing.
If you would like to know about the physics, google "dew point" and "relative humidity".
To help you with this, remember these following points..
Water condenses on a glass port when the RH reaches 100% at that point.
An air conditioned room may have a RH of about 40%.When vapour condenses on a glass surface, it has reached its dew point temperature.
Dew point of dry dive air is in the minus figures. i.e Extremely dry.
As an example: An aircon room at 25 degrees, with RH=40% has a dew point of 10 degrees. Seal up the camera and trap this air inside, and condensation will not occur on the port until the water temp reaches 10 degrees. This is always going to stop fogging in the above example.
Andy Willett
PHXAZCRAIG
I've been on several dives off a liveaboard in Fiji where my camera fogged up toward the end of the dives.   Canon point-n-shoot in acrylic housing.
I figured out it was due to the camera itself warming up through the dive coupled with coming into shallow, warmer water.   Never happened at the beginning.
With my Nauticam DSLR rig, in my usual caribbean location, I set up the camera in my room (A/C), and pump down the vacuum as soon as everything is ready to go.  (Batteries changed, lens/ports changed if needed, images offloaded.)   If that is overnight, fine.  If it is at lunch break, all I can do is swap stuff out for the afternoon dives, pump it down and go eat.   At least I get a bit of time to watch the leak detector detecting.
To control humidity, I normally only need to worry about the external glass bits, and that goes away once I hit the water.   For above water shooting, I will put my camera gear out of the A/C 30-60 minutes before needing it to acclimate.   But I've not had an issue doing this procedure.
I've also changed out ports and batteries aboard ship between dives, but in those cases the camera is generally at outdoor temp, or cooler.
www.cjcphoto.net
"I miss the days when I was nostalgic."
this was a 3 year old thread revived.
With the ILCs, I don't think it comes up-  too much air to heat.   And since nearly all of us have moved to vacuum systems, less air and moisture anyway.
