(unknown member)
Re: Oly 12mm f2 stepped manual focus?
My 12 f/2 focuses on infinity at 8.5 feet. I measured it using the 14X manual focus assist on an EM-5. Anything further away will be in focus, anything closer will need focusing. Infinity is not exactly where its marked on the focus ring, but it doesn't matter if you find it through the EVF or LCD and leave it there. The focus ring is very smooth, but tight enough so it won't move on you. The aperture ring has a solid click to it when you change it. Same with the 7.5.
The 12 Is big and heavy for M43 if you're used to smaller, lighter M43 lenses, but it feels and looks "right" on the EM-5 with the OLY grip, so it should be good on the Panny G85 as well.
The 8mm fisheye has a mount for a removable hood. It's a 139 degree FOV. It weights 16oz. The 7.5 has a tulip hood built into the barrel, weighs 7oz, is 180 degree FOV, significantly smaller, more like what you would expect in an all metal, compact M43 lens. I have the 7.5. B&H is selling it right now, new for $219. They sell the 8mm for $259.
I like to line up the horizon through the middle of the frame of the 7.5 fisheye, crop to make landscapes look wide instead of fisheye when I don't want a fisheye image. I've de-fished it with Angelfish, a $20 program that works pretty well.
Both are sharp, contrasty, and produce good color. I like them a lot. The OLY evangelist/visionaries used the Rokinon 7.5 fisheye before OLY made a native M43 available.
I never wish for AF in these lenses. Even when I have to adjust focus, manual focus assist and focus peaking nail the focus quickly - not as quickly as AF would. I don't use them in situations where AF would be needed.
Both lenses are less than 1/2 the cost of one OLY 12mm AF lens. For the way I use them, definitely worth it to me. I never bought the OLY 12 or fisheye. Don't feel the need for them.
B&H has 46 customer reviews on the M43 version of the 12, and 96 on the fisheye. A decent number sold with this many reviews. The reviews are good.
For street photography, if a subject is closer than 8.5 feet and going to move or moving, you are going to have to move fast, get used to MF. For anything further - no problem. Some street photos look pretty cool with motion blur, somebody walking, driving, peddling, riding through the composition.
Hope that helps.
