What do you think about the bokeh that 85L 1/4 will produce?
Started Nov 11, 2017 | Polls
Bluerio Regular Member • Posts: 418
Re: What do you think about the bokeh that 85L 1/4 will produce?
Off topic...what's going on in some of the pictures with a lot of weird artifacts particularly in the out of focus areas?
 Bluerio's gear list:Bluerio's gear list
Sony a7R III Sony a7 III Sigma 35mm F1.4 DG HSM Art Sony FE 55mm F1.8 Sony FE 70-200 F4 +8 more
Shaun Gibbs
Shaun Gibbs Contributing Member • Posts: 560
Bluerio wrote:
Shaun Gibbs wrote:
Only had my lens a day and have taken some samples to test IS and IQ for first impressions.
Not exciting photos, but I did go through all the F stops and shutter speeds in these sequences, and to test purple fringing etc.
RAWs imported straight into Lightroom and exported to Jpg full resolution. No Editing at all.
Autofocus is not quite as fast as the 70-200mm f/2.8L II, but almost, and is very useable.
I'll probably do some more structured photos soon on the weekend and add to the gallery when I have time.
EF-85mm-f14L-IS-USM-Samples
Thank you Shaun, really useful post and good amount of samples in different situations.
From a first close look the lens seems very sharp across the entire frame but CA are massive, and in few cases even not rectifiable in post. Blur is smooth, bokeh exhibits cat's eye towards the extreme and seems a bit characterless.
You're welcome. I did try and remove the CA manually in Lightroom for the tree shots and it worked a treat. I then undid the removal to post on the gallery.
No profile for the lens in Lightroom yet.
www.shaungibbs.com.au
 Shaun Gibbs's gear list:Shaun Gibbs's gear list
Canon EOS R Canon EOS R5 Canon EF 24-70mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon 70-300 F4-5.6 IS II +5 more
