E-m1 mk2 with panny 7-14mm f4
Started Nov 10, 2017 | Questions
arbageddon New Member • Posts: 5
Good day,
When using oly E-P5 with the panasonic 7-14mm f4, i found that combination produce some purple color blobs in photos whenever there're strong light source within the framing. I have read that this doesn't exist with panasonic cameras. May i ask if this have been solved with the E-m1 mk2 ?
Thank you.
Arba
Olympus E-M1 Olympus PEN E-P5
Gregm61 Forum Pro • Posts: 15,899
Re: E-m1 mk2 with panny 7-14mm f4
“Solved”?
I seriously doubt that’s anything Olympus is working to solve. They would tell you to use lenses they designed to be used with that body.
"There's shadows in life, baby.." Jack Horner- Boogie Nights
Andy M
Andy M Regular Member • Posts: 458
I haven’t used it on earlier Olympus cameras, but it is present on my EM1 MK2 with that lens.
Andy
 Andy M's gear list:Andy M's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX8 Sony a7R IV Sony a7R V
WhiteBeard
WhiteBeard Senior Member • Posts: 2,944
arbageddon wrote:
Good day,
Thank you.
Arba
It is solved by moving a few degrees away from the the flare point.
 WhiteBeard's gear list:WhiteBeard's gear list
Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix DMC-GX8 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Vario 45-200mm F4-5.6 OIS +4 more
Pete_W
Pete_W Senior Member • Posts: 2,841
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
Pete_W wrote:
Check this out:
https://www.dpreview.com/forums/thread/4179880#forum-post-59818036
This is the solution. Hardest part is sourcing the materials and a P00 screwdriver that you might have to file the tip off to make it fit nicely. Cutting the gel is also tricky unless you make a template out of a folded over piece of paper.
I did it as I had the lens and like it and the Oly 7-14 was not available yet.
I would do it again if saving a few hundred dollars was paramount or the compact size was important.
EM1.2 produces the same purple blobs without the gel mod but it is not every time and often a slightly different angle chosen before you shoot minimises or eliminates it.
"You are a long time dead" -
Credit to whoever said that first and to my wife for saying it to me.
Make the best you can of every day
Photo Pete Veteran Member • Posts: 5,430
WhiteBeard wrote:
arbageddon wrote:
Good day,
Thank you.
Arba
You mean by changing your preferred composition to an inferior one?
I tried the Panasonic 7-14 on a mk1 and it was dreadful for flare, ghosting and purple blobs. Bodging a solution with a filter may reduce the purple blobs, but much of the flare and ghosting will still be present.
The Oly 7-14 is better for flare etc, but has extreme field curvature which can heavily degrade corner sharpness if you’re not careful.
Haven’t tried the panasonic 8-18mm, but knowing what I now know about the shortcomings of the Panasonic and Olympus 7-14 lenses I would certainly consider the 8-18 if I were buying a super wide zoom again.
Have Fun
Photo Pete
glassoholic
Photo Pete wrote:
WhiteBeard wrote:
arbageddon wrote:
Good day,
Thank you.
Arba
I agree... but as far as "normal" flare goes I think they will all flare a lot of the sun is in the frame. One might be more than another and do it differently in different situations. I suspect the Oly might be most prone to it due to size of front element. "Normal" flare sunspots do not bother me too much. Flare from a sunny window when shooting an interior is another story. Especially if there is a purple blob secondary image of the bright window.
OP arbageddon New Member • Posts: 5
Thanks for all the replies guys, i'm considering upgrading to either panny G9 or Oly e-m1.2. Considering the panny 7-14mm is my favourite lens, it's a tough choice as the e-m1.2 price is now getting to the point where i can afford it.
