my fix of the K-30 aperture problem without disassembly
Started Nov 6, 2017 | Discussions
tonydav New Member • Posts: 6
Re: My bricked K30 works again thanks to new AA alkaline batteries!
I went to use my K30 a few years ago at my kid's grandmother's 100th birthday. I don't do much photography these days but still have a really nice 50mm 1.4 lens which is great for this sort of thing.
And nothing...
Lucky I'd followed my old mentors advice and taken a spare camera (the K200D that I first learnt SLR photography on) so a total disaster was averted (spose I could have used my phone for photos lol).
Then I tried the K30 again about a year ago (same issue - no surprise) and then researched the issue.
Tried this fix after buying the AA battery adapter. Well it works. Sort of.  If I keep the aperture closed down or even half open it will work. But unfortunately with my 50-200mm 2.8 or the 50mm 1.4 it's pretty useless
Contacted Pentax in Australia. $190 to fix the camera. Or buy a "mint-used" K-5 for around twice that (so I can still use my lens). Thoughts?
 tonydav's gear list:tonydav's gear list
Pentax K-3
The Squirrel Mafia
The Squirrel Mafia Senior Member • Posts: 1,017
$380 for a near mint K-5 doesn't sound bad, but I'd suggest a K-5IIs instead if you can find one.
 The Squirrel Mafia's gear list:The Squirrel Mafia's gear list
Pentax K-3 II Pentax smc DA 21mm F3.2 AL Limited Pentax 11-18mm F2.8 Pentax DA* 16-50mm F2.8 ED PLM AW Pentax K-50 +10 more
PentUp
PentUp Veteran Member • Posts: 4,188
Tony,
Leederville Cameras in Perth seem to be selling new K5ii and K5iis bodies. Maybe snap one up?
https://www.leedervillecameras.com.au/cameras/dslr-cameras/pentax-dslr/
(although I have been wondering if those are placeholders on the website for... K-5iii / K-5iiis ?!? ... "wouldn't that be nice..." )
 PentUp's gear list:PentUp's gear list
Panasonic Lumix DMC-FZ300 Canon G7 X II Pentax K-x Pentax K-5 II Pentax K-50 +12 more
TPLOR New Member • Posts: 1
Re: my fix of the K-30 aperture problem without disassembly
Many thanks. Seems to have worked for me!
grcolts Veteran Member • Posts: 3,911
My K50 just started showing this aperture problem too.  I tried the quick fix and so far it seems to be working. For how long it will work I don't know.  This is my 2nd K50 to develop this issue.  I doubt I will try to fix it as I don't think its worth the cost. I may get a used K3 or K3ii or may just abandoned Pentax. I thought about getting an K70 but from what I have read it too suffers the same fate. Sad.
Russ Miller
Russ Miller New Member • Posts: 13
Unfortunately, there is a lot of incorrect information on the ABF issue.
First, the last thing that should be done with an ABF issue is rapid firing of the shutter.  The magnetic strength of the bad solenoids is too strong. Rapid firing of the shutter has been known to damage the mechanical mechanism.
Second, Pentax has updated the defective solenoids and they can (and should) be used to repair the camera.
Third, The K70 never suffered from this issue in any real numbers.  Pentax fixed the issue early in the K70 release and all new K70 cameras after 2016 have the newer solenoid.  This is a non-issue at this point.
There is no reason to be skittish about the K70 cameras anymore.
 Russ Miller's gear list:Russ Miller's gear list
Olympus E-M5 II Panasonic Lumix DC-GX9
Thank you for your input. Right now I will probably just use the K50 with a lens that works with that problem.  I may still look a the K70 and hope that Pentax actually did upgrade the solenoid on the K70.  I don't really want another camera with the solenoid defect so I will proceed with caution.
Futax Senior Member • Posts: 1,353
I think the most common understanding is that the new solenoid used in the K-70 is "improved", but not to the standard of the original, as used in the pre-K30 entry-level models.
Faulty K-70 solenoids are fairly rare, but have been reported.  Best to use the camera regularly, as that may well keep the failure at bay...
- Keith.
 Futax's gear list:Futax's gear list
Sigma DP1 Fujifilm FinePix F70EXR Sigma DP2 Merrill Canon PowerShot SX50 HS Panasonic Lumix DMC-XS1 +5 more
Russ Miller
I disagree. One of the PF members did electrical testing on the latest solenoid, and it was fully in spec with the original. Not an issue to be concerned about anymore.
"Electrical testing"?  Will this be able to predict reliability (of what is, after all, a very elusive electro-mechanical issue)?  Doesn't the original green solenoid also meet electrical specification?
- Keith.
