Moisture trapped under LCD on Canon t6
Started Nov 2, 2017 | Discussions
dan_kelly_78 New Member • Posts: 9
So, I got caught in a heavy rainstorm last weekend (about four 1/2 days ago) and my Canon t6 got rain on it. I had a plastic bag on me and I stored my camera in it after it started to rain but water got in the bag anyway and my camera got slightly wet (not soaked or immersed). Lesson learned.
I took out the battery as soon as I realized what had happened, and let the camera dry for four days. Turned it on today with a new battery... it's working again, taking photos okay, but the rear LCD has dark patches and is diagonally "crisscrossed" with darkish lines.
Will this go away on its own if I put it in a 'dry box' with silica packets or is my LDC ruined and do I need to have it replaced?
Rear LCD of Canon t6 with water intrusion.
 dan_kelly_78's gear list:dan_kelly_78's gear list
Canon EOS Rebel T6 Canon EF 75-300mm f/4.0-5.6 III USM Sigma 70-200mm F2.8 EX DG OS HSM Sigma 17-50mm F2.8 EX DC OS HSM Canon EF-S 18-55mm f/3.5-5.6 IS II +1 more
Canon EOS Rebel T6 (EOS 1300D)
davebreal
davebreal Regular Member • Posts: 415
Re: Moisture trapped under LCD on Canon t6
Silicon packets could not hurt give it a shot. However we may be looking at smudges or damage from water residue. Your other options would be to live with the streaks or have Canon repair it.
IMO a T6 repair service may not be worth it. Check out prices on preowned and grey market bodies for replacement. T6 refurbs can go for $280 with kit lens (~$100 value). Minimum Canon USA repair fee is ~$150 I believe.
 davebreal's gear list:davebreal's gear list
Canon EOS 7D Canon EOS 60D Canon EOS M Olympus PEN E-PM2 Canon EOS 6D +21 more
Olga Johnson Forum Pro • Posts: 24,360
It depends. If it is under the first plastic layer of the LCD screen, it’s inexpensive to replace the top cover yourself.
Here is an old thread that explains how you can get the part number and how to order the plastic first layer from Canon.  It’s missing some pictures but you will get the idea.
https://www.dpreview.com/forums/post/10852446
Olga
R2D2 Forum Pro • Posts: 26,551
You can use silica-gel (if you have enough), or do the "Rice" trick...
Take batt and SD card out.  Seal your camera in a large ziplock bag filled with rice and set it in the sun (indoors) for a few days.
Also, most sporting goods stores sell (large) desiccant packs for keeping gun safes dry.  You may also find containers of powdered silica-gel at craft stores for drying flowers.
Best of luck,
R2
OP dan_kelly_78 New Member • Posts: 9
Thanks for all the suggestions, everyone. After keeping the T6 camera body in a airtight plastic box with silica packets for a few days the water trapped in the LCD seems to be gone and the display looks good as new again.
