Does the A7RIII shoot 14 Bit at 10FPS?
Started Nov 1, 2017 | Discussions
9VIII Senior Member • Posts: 1,046
http://www.imaging-resource.com/PRODS/sony-a7r-iii/sony-a7r-iiiA.HTM#comparison
About 2/3 of the way down this article from Imaging Resource, under the section "The Sony A7R III Image Sensor" you'll find this quote:
"The camera does drop to 12-bit RAWs when shooting in continuous burst mode using the compressed RAW format"
where DPReview seems to make a statement directly opposed to that in bold at the start of a recent article, though DPReview does not give any numbers:
"The Sony a7R III retains its dynamic range even in bursts."
https://www.dpreview.com/news/4302149407/sony-a7r-iii-dynamic-range-improved-nearly-matches-chart-topping-nikon-d850
So which is it?
 9VIII's gear list:9VIII's gear list
Canon EOS 1100D Fujifilm X-E2S Fujifilm X-E3 Canon EF 400mm f/5.6L USM Sigma 150mm F2.8 EX DG Macro HSM +6 more
Sony a7R III
Richard Butler
Richard Butler dpreview Admin • Posts: 2,787
Re: Does the A7RIII shoot 14 Bit at 10FPS?
So which is it?
It's both. In compressed mode it drops to 12-bit, in uncompressed mode (which you'd need to be in, if you were worried about DR) it stays in 14-bit.
Richard - dpreview.com
