85mm 1.4 L IS preview
Started Oct 31, 2017 | Discussions
(unknown member) Regular Member • Posts: 333
Re: 85mm 1.4 L IS preview
Shaun Gibbs wrote:
I got mine yesterday in Brisbane.
Congrats! Whereabouts in Brisbane did you pick it up from?
Shaun Gibbs
Shaun Gibbs Contributing Member • Posts: 560
Thank you. Camera Pro in Anne Street.
www.shaungibbs.com.au
 Shaun Gibbs's gear list:Shaun Gibbs's gear list
Canon EOS R Canon EOS R5 Canon EF 24-70mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon 70-300 F4-5.6 IS II +5 more
mclaren777
mclaren777 Regular Member • Posts: 257
Re: bokeh test
lumenite wrote:
85 F/1.4L IS is difficult to make the background swirly, while not difficult for the foreground. On the other hand, 85 F/1.2 makes both sides without any difficult.
Enjoy some samples.
http://www.slrclub.com/bbs/vx2.php?id=canon_fgallery&page=117488&no=4382957
Swirly backgrounds are terrible!
Is that really something you want?
Fog Maker Senior Member • Posts: 2,733
Re: bokeh test
Scott Larson wrote:
So far these results aren't much different from the 85mm f1.8.
Oh, finally we agree on something!
I knew something was up when it became
clear that the 85mm 1.2 II would remain in the line up.
The lens will be good of course, but, well...
 Fog Maker's gear list:Fog Maker's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.2L II USM Canon EF 24-70mm f/2.8L USM Canon EF 100mm F2.8L Macro IS USM
J A C S
J A C S Forum Pro • Posts: 20,544
Re: bokeh test
mclaren777 wrote:
Enjoy some samples.
I do not think it is swirly. There are some double lines, unfortunately, when pushed too hard.
Alexsfo Senior Member • Posts: 2,362
Re: bokeh test
J A C S wrote:
mclaren777 wrote:
Enjoy some samples.
Honestly, the rendering is more similar to 85mm 1.8 lens than 85ii, none of the pictures I’ve seen so far would mix well with 85L 1.2 or 135L epic shots.
 Alexsfo's gear list:Alexsfo's gear list
Canon EOS 5D Mark IV Canon EOS M6 II Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM Canon EF 24-70mm F4L IS USM +4 more
Samber
Samber Regular Member • Posts: 102
Re: bokeh test
Isn’t this consistent with the new canon 1.4 lenses.  The 35mm has a less appealing bokeh than the mk l.  The new glass and their drive for edge to edge sharpness seems to have affected bokeh.
 Samber's gear list:Samber's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 135mm F2L USM Canon EF 200mm f/2L IS USM Canon EF 400mm f/4.0 DO IS USM +5 more
J A C S
Re: bokeh test
Definitely not.
brightcolours Forum Pro • Posts: 15,885
no
That is totally not true. The old 35mm is not good bokeh wise, the new one does quite a good job.
That seems to be not true either. This lens, at closer focus, seems to have smoother bokeh than the f1.2. At more distant focus, it seems to break down a bit. But the f1.2 never had flawless bokeh itself.
Tazz93
Tazz93 Veteran Member • Posts: 3,484
Re: no
Yeah, I think what people are commenting on is technique, not lens quality. If you set up your model at a distance that is not good for the background you're going to get poor results.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
OP lumenite Senior Member • Posts: 1,208
Final Review
The final review by the same reviewer of the original post.
http://ran.innori.com/878
In the review the pictures before flare tests seem to have been taken with 85 F/1.2 L long time ago. It is the first part of the review. The second part of the post is filled with recycled materials that show the performance of the new lens. Then, some comparisons between 85 1.2 and 85 1.4 follow and the reviewer makes a long concluding remark with a bunch of test shots.
In summary,
85 F/1.2 is slow, but artistic.
85 F/1.4 is an all-round player.
Because he has been familiar to 85 1/2 for 6 years, he won't change his old lens with the new one. However, if he started from scratch, he would choose the new one because of his moving children.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
