85mm 1.4 L IS preview
Started Oct 31, 2017 | Discussions
lumenite Senior Member • Posts: 1,208
8
Here is a preview of the coming lens, though it is written in Korean.
http://www.slrclub.com/bbs/vx2.php?id=canon_fgallery&no=4381920
Summary:
1. Flares are reduced very much. When they appears, they are not cold but warm unlike the latest Canon lenses.
2. Chromatic aberration are also reduced very much, but not to the degree of Canon 35L II.
more portrait samples:
http://www.slrclub.com/bbs/vx2.php?id=canon_fgallery&no=4381938
3. IS noise is low, but not good enough for video.
4. Very fast AF, of course.
 lumenite's gear list:lumenite's gear list
Canon EOS-1D Canon EOS M Canon EOS M5 Canon EF 28mm f/1.8 USM Canon EF 50mm F1.4 USM +7 more
Dmatrix Photo
Dmatrix Photo Regular Member • Posts: 117
Re: 85mm 1.4 L IS preview
Do you know if the images in the article are taken with the new 85 or are they taken with the 1.2?
 Dmatrix Photo's gear list:Dmatrix Photo's gear list
Canon EOS R Canon EOS R5 Canon EOS R6 Canon RF 50mm F1.2L USM Canon RF 15-35mm F2.8L IS USM +4 more
Kameratrollet Senior Member • Posts: 1,106
Check here http://exif.regex.info/exif.cgi
Lens: EF85mm f/1.4L IS USM (shot wide open)
OP lumenite Senior Member • Posts: 1,208
All of them seem to be taken by the new 85 1.4L IS.
You can do a left-click to see their EXIFs.
Most of them are f/1.4. Some of them are f/1.6 and f/2.0.
Dmatrix Photo
Doesnt give me the ability to right click or even select text to translate
Dmatrix Photo
m more concerned about the shots that show the large amount of purple fringing, that looks more like what i expect from the 85 1.2
not right click, but left click on the images. Interestingly, I can use google translate with the text.
and... the writer says that purple fringing is reduced much, compared to that of 85L 1.2, though it is still there. He has used 85 1.2L for quite a long time. I think the examples show the extreme case.
Moreover, he expects that the chromatic aberration can be corrected in software to some degree.
Here you are http://media.slrclub.com/1710/28/s0Fl529dn7gmp3pfqb.jpg
herion
herion Contributing Member • Posts: 756
That amount of CA is not exactly comforting. I have considerably less CA on my Tamron G2 85mm wide open (okay, 1.8 vs. 1.4 - but still, this shot using the new Canon doesn't look good...)
 herion's gear list:herion's gear list
Canon EOS 30D Canon EOS 40D Canon EF-S 10-18mm F4.5–5.6 IS STM Tamron SP 45mm F1.8 Di VC USD Tamron SP 85mm F1.8 Di VC USD +2 more
Tazz93
Tazz93 Veteran Member • Posts: 3,484
CA Monster
5
The level of CA in those samples are completely unacceptable for a lens made in 2017. Hopeful that is not a production model... if it is you can take my name off the list.
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
millan Forum Member • Posts: 98
Re: CA Monster
Here is an example of pretty bad LoCA:
https://www.dpreview.com/forums/post/60320644
beeley Junior Member • Posts: 40
Re: CA Monster
I agree. Take a look at image 26/59 here:
https://www.dpreview.com/sample-galleries/6995506461/canon-ef-85mm-f1-4l-is-usm-sample-gallery
It is of a road surface and there is an apparent horizontal magenta stripe with a green stripe behind it due to the CA. DPP seems to be able to improve it but not eliminate it.
BlueRay2 Forum Pro • Posts: 14,816
hmm...nasty CA (heavy purple fringe) for a lens this exciting and anticipated. hold on to your 85 f1.2 lenses, folks
Tazz93
Re: CA Monster
I may have been a little harsh in the original statement, but I stand behind this is too much CA for a $1600 lens. Canon's samples prove DPP is reasonably good at removing it, but if the $100 50mm 1.8 STM is better than a newer $1600 lens with updated coatings, Canon has an issue. I get that a 1.4 lens is always going to have some aberration, but it just seems like more than what should be expected. Yes the 85mmm Art, and I suspect the Otus will have some, but I'll also venture out to say it's likely going to be significantly less than this one (I'm guessing about 50%). I honestly can't justify a lens at that price, where Canon expects its user to shoot it at narrow apertures or do a lot of lens correcting in post.
Oh well, maybe they'll get it right in their version 2.
Re: CA Monster
Do you have any link for the lenses of other brands, such as Sony 85G, Nikon 85N, and Sigma 85Art?
herion
Re: CA Monster
JerryriggedTECH
JerryriggedTECH Senior Member • Posts: 1,098
Lots of people love the f/1.2 despite the horrible CA. In fact, the reason I got rid of mine was mostly because of the inconsistent and slow focusing. If this f/1.4 version improves significantly on the focus accuracy and speed, then I think it will do well despite there still being some CA. I know I will be considering buying one... I don't consider the difference between f/1.2 and f/1.4 to be a deal breaker.  With that said though... That image showing the very worst CA... I thought that red was the color of the material!  That is ridiculously bad!
 JerryriggedTECH's gear list:JerryriggedTECH's gear list
Canon EOS 5D Mark IV Canon EOS R Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM +5 more
Tazz93
Re: CA Monster
All three mentioned above are on DPR's lens review section. Just select the lens and click the "Sample" tab. Just note, I don't know if all of them are raw in regards to applied corrections.
Pedro Courelas
Pedro Courelas Regular Member • Posts: 195
1.2 AF inconsistency ends with the new AF Dual. Is night and day.
J A C S
J A C S Forum Pro • Posts: 20,544
