90mm Test Shots
Started Oct 28, 2017 | Discussions
rwbaron Forum Pro • Posts: 14,345
Re: 90mm Test Shots
Yes that's it. It's also visible in areas of the upper left quadrant.
It's quite clear on my MacBook Retina display even without magnification or manipulation.
rlx wrote:
Is that what you are seeing. I can't see it myself but the pattern becomes apparent after some image filtering and it shows up in the FFT.
I would be surprised if the pattern was created by the lens.
Rawtherapee processing.
Part of the picture without the shirt and its FFT (ImageJ). The shirt itself has a pattern so I had to remove the shirt from the picture.
 rwbaron's gear list:rwbaron's gear list
Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +8 more
myahya09
OP myahya09 Regular Member • Posts: 123
Re: 90mm Test Shots
Ooh that one..
That's someone's striped shirt
 myahya09's gear list:myahya09's gear list
Fujifilm X100F Fujifilm X-Pro1 Fujifilm X-Pro3 Nikon Z6 II Nikon Z fc +7 more
mahdirafiey
mahdirafiey Forum Member • Posts: 93
Re: 90mm Test Shots
I think it is because of the background itself and not the lens. I have this lens and never experienced this. see sample below.
 mahdirafiey's gear list:mahdirafiey's gear list
Fujifilm X-T3 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 35mm F2 R WR
myahya09
Re: 90mm Test Shots
Didn't expect you to be replying back here 🤣
rlx
rlx Senior Member • Posts: 1,375
I don't see the pattern on the picture posted by the OP, but ...
There is a pattern in the crop provided by rwbarron as I showed in my last post.
@rwbarron. How did you create that crop from the OP picture? It seems to me it was resized.
I tried again to amplify any pattern using RT but this time directly from the OP provided picture (not rwbarron's post) and there is no pattern I can see. Maybe others can see a pattern though. The FFT still shows a grid but that is likely a leftover from the demosaicking algo.
(Edit) It looks like the person in the back wears something around the neck and that may be creating the pattern rwbarron sees (as the OP commented).
Re: 90mm Test Shots
Yes and my thinking is it's the way this site handles the files. There have been discussions about this in the Canon forums several years ago where people noticed artifacts in the photos they uploaded to this site that were not in their original.
cali92rs Contributing Member • Posts: 673
Re: 90mm Test Shots
I love this lens.  The output is just really pleasant and it is just so sharp even wide open.
I just wish I used it more.  I find that for what I shoot, the 56mm gets a lot more usage because the 90mm is just too long, even though I prefer the look of the 90mm.
