90mm Test Shots
Started Oct 28, 2017 | Discussions
myahya09
myahya09 Regular Member • Posts: 123
90mm Test Shots
21
So, I had purchased the 90mm on clearance a few days back..
I must admit, I was never interested in this lens because I felt that the focal length was strange for what I'd like to use it for..
Although it's considered one of Fujifilm's finest and highest rated lenses (if not the highest), I was shocked to find it placed on clearance among some basic lenses like the 27 and 18 (just my opinion)..
So, I bought it for 40% less than it's original price..
The bokeh looks STUNNING.. The lens is SHARP and FAST!!!
I took it for a test out on the streets to see what I can get out it, and I can easily say that I have now found my favorite lens
Here are some results...
All taken with the X-T2...
 myahya09's gear list:myahya09's gear list
Fujifilm X100F Fujifilm X-Pro1 Fujifilm X-Pro3 Nikon Z6 II Nikon Z fc +7 more
Fujifilm X-T2 XF 90mm
Sjak
Sjak Veteran Member • Posts: 7,318
Re: 90mm Test Shots
Yes, a fast 90mm works very well on APSC
Nice shots, well done!
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
myahya09
OP myahya09 Regular Member • Posts: 123
Re: 90mm Test Shots
Thank you
It's a stunning lens..
It was a bit challenging for me at first, the focal length is quite strange for narrow areas, but you can manage it from a distance
Homo erectus
Homo erectus Senior Member • Posts: 1,047
Re: 90mm Test Shots
The 90 is my favorite lens. The things it does to shadows and highlights on water in out of focus areas are so, so, beautiful.
It's a star attraction on X mount.
Optimus Primes
Optimus Primes Regular Member • Posts: 261
Re: 90mm Test Shots
Wow those are just gorgeous!  I’m going to start saving my pennies!
rwbaron Forum Pro • Posts: 14,345
Re: 90mm Test Shots
Beautiful shots and thanks for sharing.
That said, on my MacBook Pro Retina the oof background in the first image has some unusual structure (repetitive horizontal patterns) that appears unnatural. Are you seeing this in the original or could this be something to do with JPEG compression or just the way the JPEG is rendered on my screen? What quality setting did you use for the JPEG when saving? I'm curious because this lens is on my list probably for my next purchase.
Thanks,
Bob
edit;
I captured a screen shot to hopefully show what I'm seeing.
 rwbaron's gear list:rwbaron's gear list
Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +8 more
stevo23 Forum Pro • Posts: 24,759
Re: 90mm Test Shots
Those are some nice images. And my does this lens sit in it's own class.
 stevo23's gear list:stevo23's gear list
Fujifilm X-Pro2 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 14mm F2.8 R Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F1.4 R +3 more
myahya09
Re: 90mm Test Shots
Thank you
Hmmm..
This is SOOC, could be from the colorful location I shot it in..
Not sure if I made any sense 😅
myahya09
Re: 90mm Test Shots
Thank you
It's a STUNNING lens
myahya09
Re: 90mm Test Shots
Do It!!!!
It's worth every you pay for
Re: 90mm Test Shots
myahya09 wrote:
Do It!!!!
It's one of those lenses that I should just put on my camera and start using more. It can be awkward from a framing perspective, but it's worth it to figure out ways around that.
myahya09
Re: 90mm Test Shots
Exactly!!!
I was with a friend today doing some street photography..
He had a Nikon kit lens, while I had the 90..
It truly challenges you to think of a composition, look around you and just shoot from a distance...
Benjamin Kanarek
Benjamin Kanarek Veteran Member • Posts: 5,118
Re: 90mm Test Shots
Wonderful imagery!!!
 Benjamin Kanarek's gear list:Benjamin Kanarek's gear list
Nikon D800 Nikon D800E Nikon D810 Fujifilm GFX 50S Fujifilm X-T20 +49 more
Yake Senior Member • Posts: 1,531
Re: 90mm Test Shots
Thanks,
Bob
edit;
Looks fine to me.  Nothing unusual.  Backgrounds always have unusual structures, with nearly every lens.  Depends on what is in the background.
 Yake's gear list:Yake's gear list
Sony a7 III Canon EOS RP
Re: 90mm Test Shots
myahya09 wrote:
Thank you
Hmmm..
I'm referring to below  which I also see in other areas of the frame.
Do you see the horizontal pattern in the oof background?
Re: 90mm Test Shots
Thanks,
Bob
edit;
Not like the pattern in the crop section I just posted above which I see in several areas of the background. Please look at the crop section I just posted above and tell me if you see the horizontal pattern in the oof background area. If not, then it has to be something with how my MacBook is rendering the image.
Peter Foiles
Peter Foiles Senior Member • Posts: 2,389
Re: 90mm Test Shots
What I see appears to be oof striped pattern on some fabric around a persons shoulders. When viewing the image at 100% on my 30 inch 4K monitor I don't see any other artifacts elsewhere in the image.
 Peter Foiles's gear list:Peter Foiles's gear list
Sony a1 OM-1 Fujifilm X-H2S Fujifilm X-H2 Sony a7R V +23 more
Re: 90mm Test Shots
Agreed. If there was animolication that the lens caused this pattern, I think he can rest easy on that. Lenses tint cause random unnnatural patterns in small patches of scenes.
rlx
rlx Senior Member • Posts: 1,375
Re: 90mm Test Shots
Is that what you are seeing. I can't see it myself but the pattern becomes apparent after some image filtering and it shows up in the FFT.
I would be surprised if the pattern was created by the lens.
Rawtherapee processing.
Part of the picture without the shirt and its FFT (ImageJ). The shirt itself has a pattern so I had to remove the shirt from the picture.
Re: 90mm Test Shots
rwbaron wrote:
myahya09 wrote:
Thank you
Hmmm..
Yes, I see it.  But I would not draw any conclusion from that.  It depends on what is back there out of focus.  Lenses do weird stuff — I just accept it.
