IS on E-PL6 body vs OIS on 12-32mm lens
Started Oct 25, 2017 | Discussions
jsaras Contributing Member • Posts: 610
Does anyone know which of the two stabilization systems is more effective?
Things have never been more like today than they are right now.
 jsaras's gear list:jsaras's gear list
Sony RX100 III Olympus PEN E-PL6 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH +10 more
Olympus PEN E-PL6
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: IS on E-PL6 body vs OIS on 12-32mm lens
Tested on my E-PL5 (has same internals as E-PL6) I generally get 3 stops of stabilisation with IBIS, with the 12-32mm I seem to get 3 stops of stabilisation at 32mm but only 2 stops at 12mm. Turn on Lens IS Priority and also have IBIS on as IBIS works as the master switch for stabilisation.
I definitely would rather use OIS with my E-PL5 if available, mainly because it works all the time and is quieter than E-PL5/6 IBIS (listen to IBIS when you do a 1 second exposure!).
The old 2 axis IBIS has a habit of adding a tiny amount of blur from what I've seen due to the way it works.
Regards..... Guy
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
My experience with the EPL5 and the 12-32 is that the Lens OIS is better than the body IBIS.
The EPL6 is basically an EPL5 with a couple of firmware changes.
Allan
OP jsaras Contributing Member • Posts: 610
Thanks for the input everyone!  OIS it is!
Guy Parsons
I've made a new page about stabilisation rules, have yet to add more details and any comments about what to use when. The E-PL5/6 is covered in the first two charts.
http://homepages.ihug.com.au/~parsog/olyepl1/30-oly-stabilisation.html
With E-PL6 and earlier, best to use OIS if possible, with E-PL7 and later then the IBIS would most likely be a better choice.
Except at say over 100mm where OIS always gives a stabilised live view, makes it easier to frame.
Regards.... Guy
