Kx re-incarnate - easy LCD replacement with a 'how to'
Started Oct 24, 2017 | Discussions
Richard_CC Regular Member • Posts: 327
13
My first DSLR was the Kx, so I could keep using my old M lenses from MX/Program A days.  After a couple of years the LCD screen died.  It was 2 days before setting off from the UK to visit the deserts of the USA and then Yellowstone, so I quickly bought a Kr, body only, as a local store had one in stock.  (Remember when most camera shops stocked Pentax).
The Kr is technically better, especially the way it shows the focus point which was a shortcoming in the Kx, but somehow although it is hardy any bigger it didn't feel as good in the hand.  Some things - like the 135mm M lens, the Kx DSLR, and my old SAAB just have an undefinable rightness about them.
I knew the rest of the Kx was working, I used it tethered to a laptop to copy 3000 slides, since then it has been in a drawer unused.  You can use the viewfinder for some things, but you can't set the ISO without the main screen so it renders it useless.
Last week I saw LCD screens for £14 (so a bit less than $20) and thought what can go wrong......
Nothing did, took about 90 minutes working very carefully and methodically to change the screen and now it works.   Don't be afraid to try this yourself (but probably not on anything in warranty or worth a lot of money).
There is some information on screen replacement for a K10 on the dslrparts.com website.  The Kx is very similar but no soldering is required.
You will need a good quality tiny philips screwdriver, a pair of forceps helps here and there, and a fine flat screwdriver to pop up some connector tabs.  Good light and work somewhere so you can find any screws you might drop.
In summary - take off strap, lens (fit body cap), pull off rubber eyepiece, take out SD card, pop flash up (important) and take batteries out.
Take off bottom plate, 8 screws (as you go on you will find screws of different lengths so take notes as you go).
Then there is the one hidden screw, look in to the battery compartment and you will see a silver screw right at the bottom.  This has to come out so you can lift the top plate later.  Now work around the top plate removing the screws, including 2 which would be hidden by the flash, one on the Kx logo side,  and 2 under the viewfinder rubber.  You can now lift the top plate - no need to take it off or worry about wires, just lift it a bit.
Now 4 screws, 2 each side, and the back plate comes off.  Unlike some other models no screws are hidden beneath the vinyl.  There is a small multi plug on the main circuit board which just pulls off as the back comes off - remember to push it back on when you reassemble.
Its fairly obvious how to deal with the back plate and change the panel.  Both the panel connectors have thin brown 'pop up' tabs to release, just ease up with a fine screwdriver.
No soldering, no glue (one bit of sticky tape to peel off and refit) and it all goes back together very nicely.
Happy to have the Kx back and hope this might help others.
Pentax K-r Pentax K-x
codecxbox Regular Member • Posts: 106
Re: Kx re-incarnate - easy LCD replacement with a 'how to'
This is very useful, and if you can mention or post link where the LCD was purchased, would be better..
Thanks!
rmalbers Contributing Member • Posts: 529
Wow, great work, always nice when a repair comes out with a good outcome!
GPGeneralPhoto
GPGeneralPhoto Senior Member • Posts: 2,157
Good to hear that you got it working. I will always attempt a repair rather than just throwing it away. Parts can be hard to find for Pentax now. I remember buying parts from Pentax, but that was years ago.
I'm thankful to still be able to...
 GPGeneralPhoto's gear list:GPGeneralPhoto's gear list
Canon PowerShot SD400 Pentax K-01 Pentax K-5 IIs
OP Richard_CC Regular Member • Posts: 327
In UK
Got it from here:
http://stores.ebay.co.uk/euro-foto-33?_trksid=p2047675.l2563
Arrived quickly, 2 or 3 days, plain packaged no serial number or instructions and looked not very promising - but it worked fine.  The screen had a very thin barely visible protector on it, fortunately I ran a fingernail round the edge to test before fitting and peeled it off otherwise I might have fitted it with the plastic in place.
Tony_Boy50 New Member • Posts: 1
Hi
Im trying to replace the rear monitor (LCD) on a Pentax K-C. I have been following you instructions and the top plate and its appears to be stuck and I think its the  selector wheel holding the top in place do you have to remove it or do I try harder?
Tony
Phil A Martin
Phil A Martin Veteran Member • Posts: 8,363
well done
flektogon
flektogon Veteran Member • Posts: 6,226
Tony_Boy50 wrote:
Hi
Tony
Here is a better description (with pictures) how to remove top plate. The mode selector apparently doesn't need to be removed. Only 1 screw on each side, 2 screws (maybe only one on K-x) in the flash, 2 screws around the viewfinder and 1 screw from the battery compartment:
https://www.dpreview.com/forums/thread/2938140
Peter
