Fuji 56 1.2
Started Oct 23, 2017 | Discussions
Tarch1
Tarch1 Regular Member • Posts: 105
Fuji 56 1.2
Hello all
For portraits, how often do you shoot wide open at 1.2?
Thanks in advance
 Tarch1's gear list:Tarch1's gear list
Fujifilm X-T10 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm 50-230mm II +3 more
rwbaron Forum Pro • Posts: 14,345
Re: Fuji 56 1.2
Tarch1 wrote:
Hello all
Thanks in advance
I typically shoot at f2 with this lens for portraits. I usually want to ensure the subjects entire head is in focus and at f2 the background still has a nice pleasing oof rendering.
Bob
 rwbaron's gear list:rwbaron's gear list
Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +8 more
shakenmartini Regular Member • Posts: 348
Re: Fuji 56 1.2
I personally do not like the look of portraits shot fully wide open on *any* lens because part of the fact is out of focus.
On this lens, I gravitate toward f/1.8 to f/2.2 for portraits. It provides a good balance of bookeh and getting a face fully in focus.
I sometimes can get what I want at f/1.4. I rarely use the full f/1.2, but when I need the wide apertures, it is great to have them.
 shakenmartini's gear list:shakenmartini's gear list
Fujifilm X-T20 Nikon D810 Nikon D7200 Nikon D750 Fujifilm X-T2 +15 more
Simon Elwell Contributing Member • Posts: 556
Re: Fuji 56 1.2
As you'd expect with such a good portrait lens more than 50% of my shots with it are at 1.2.
You need to be careful with the focus - you can easily catch the tip of a nose or chin and leave the eyes soft; but with practice and care it's utterly brilliant
 Simon Elwell's gear list:Simon Elwell's gear list
Fujifilm X100S Fujifilm X-Pro1 Fujifilm X-Pro2 Fujifilm XF 14mm F2.8 R Fujifilm XF 35mm F1.4 R +7 more
tonyreidsma Senior Member • Posts: 1,288
Re: Fuji 56 1.2
Always, and I'm very pleased.
 tonyreidsma's gear list:tonyreidsma's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 56mm F1.2 R
d750guy Senior Member • Posts: 1,001
Re: Fuji 56 1.2
Tarch1 wrote:
Hello all
Thanks in advance
I'm pretty much at 1.2 all the time unless i'm doing really tight headshots.   The closer to the subject, the more I stop down, up to f4  for really tight headshots .
retroactivity Regular Member • Posts: 228
Re: Fuji 56 1.2
It's entirely relevant to distance to subject. If you are so close the head is filling the frame, then yes, 1.2 will render parts of tha face out of focus while others are in which is not usually desireable. But if they are backed off a bit so you get the whole torso and some background context, then 1.2 is fine if you nail the eyes.
 retroactivity's gear list:retroactivity's gear list
Fujifilm X-E1 Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 35mm F1.4 R +1 more
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 16,222
Re: Fuji 56 1.2
Tarch1 wrote:
Hello all
Thanks in advance
Depends on the subject and angle.  In the case of many cat portraits, I think very thin DOF can work well, as in this example, shot wide open at f1.2.  I prefer the greater subject isolation you get, however, the angle of the head as well as what's in the background will dictate greater DOF with a smaller aperture at times.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm X-H1 Carl Zeiss Touit 2.8/12 Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 10-24mm F4 R OIS +1 more
Alfonso Bresciani
Alfonso Bresciani Senior Member • Posts: 1,811
Re: Fuji 56 1.2
Tarch1 wrote:
Hello all
Thanks in advance
Always!
 Alfonso Bresciani's gear list:Alfonso Bresciani's gear list
Sony a9
